Calculate Moment of Inertia of Disc w/ Added Mass: 40 to 30 revs/min
  • Thread starter Thread starter tomwilliam
    Wheel
The discussion focuses on calculating the moment of inertia of a disc with an added mass, transitioning from 40 revolutions per minute (revs/min) to 30 revs/min. The conservation of angular momentum is applied, using the equation L = Iw, where I represents the moment of inertia and w the angular speed. The participant confirms their approach by stating I1w1 = (I1 + I2)w2, where I1 is the moment of inertia of the disc, I2 is the moment of inertia of the added mass, and the angular speeds are w1 and w2. The importance of checking calculations with conservation of energy is also highlighted, although the participant notes uncertainty regarding the mass of the disc.
  • Understanding of angular momentum conservation principles
  • Familiarity with moment of inertia equations, specifically I = (mr^2)/2 for discs
  • Knowledge of rotational dynamics and angular speed calculations
  • Basic grasp of energy conservation in rotational systems
  • Explore the application of conservation of energy in rotational motion
  • Learn how to calculate the moment of inertia for various shapes beyond discs
  • Investigate the effects of added mass on angular momentum in different systems
  • Study the relationship between angular speed and moment of inertia in practical scenarios
Physics students, mechanical engineers, and anyone interested in rotational dynamics and moment of inertia calculations.
tomwilliam
find the moment of inertia of a disc of diameter D that spins freely at 40 revs/min, then reduces to 30 revs/min when a mass m is added to the disc at x from the centre. I know m, x, both angular speeds, and the diameter of the disc.
L = Iw
I = (mr^2)/2 (moment of inertia of a disc)
I = mr^2 (moment of inertia of a particle a distance r from the axis)
I think this is a question about conservation of angular momentum. I've been assuming that because angular momentum (L) is the same before and after the mass falling, I can state:
I1w1 = (I1+I2)w2, where I1 is moment of inertia of the disc alone, w1 is angular speed before and I2 is the moment of inertia of the mass and w2 angular speed after the mass falls onto the wheel. I can calculate I2 = mr^2, so therefore calculate I1. Just to confirm, I have the angular speed before and after, I have the distance x and the mass m, I have the diameter of the disc also.
Can someone confirm that this is the right approach? I don't know how the diameter (or radius) of the disc comes into it, as it seems that this approach will calculate the value of I, so I don't need to find the mass and therefore find mr^2 to find I1. I also find that the values I've calculated so far seem pretty low, so I'm thinking I might have the wrong approach. Help appreciated - but please don't solve it for me! Just some pointers...
Thanks in advance
Welcome to PF, TomWilliam.
Your approach looks good to me.
It would be interesting to use conservation of energy as a check.
Thanks for that.
The idea of checking with rotational energy is a good one. I'm not sure how to do it though. I don't have the mass of the disc - so I would have to use the calculated value of I1 to check using Erot = 1/2 I w^2.
Also, I don't know about conservation of energy in these situations, because I don't know how much energy the (unknown) additional mass on the disc will add to the system. I'll have a go at calculating this, but if it were possible to solve the problem using conservation of energy, I would have thought it would be much easier!
18K
  • · Replies 40 ·
