Proving the Limit of f(x)=0 in Calculus with Spivak's Problem
  • Context: Graduate
  • Thread starter Thread starter Bleys
    Calculus Limit
The discussion revolves around proving the limit of the function f(x) as x approaches a, where f(x) is defined based on a collection of disjoint sets A_n within the interval [0,1]. Participants explore the limit definition in the context of calculus, specifically addressing the behavior of f(x) as it relates to points in and out of these sets.
  • One participant suggests that for any neighborhood around a, there are finitely many elements of A_n, leading to the conclusion that f(x) can be made arbitrarily small.
  • Another participant proposes a proof assuming f(a)=0 and discusses the existence of a delta such that the neighborhood around a does not intersect with a finite union of sets B_N.
  • There is a clarification regarding the smallest n being the one such that A_n has an element in the neighborhood of a.
  • Some participants discuss the implications of whether a is in any A_n and how that affects the limit proof, emphasizing the need to consider both cases.
  • One participant mentions the importance of the delta-epsilon definition and how to choose delta based on the distance to the nearest elements of the sets A_n.
  • Another participant provides an intuitive visualization of the proof, suggesting that the intervals between a and elements of A_n are always present due to the density of real numbers.
Participants generally agree on the approach to proving the limit but express differing views on the specifics of the proof, particularly regarding the treatment of cases where a is in or out of the sets A_n. The discussion remains unresolved on certain details of the proof structure.
Some participants note the need for clarity on the properties of the sets A_n and the implications of the delta-epsilon definition, indicating that assumptions about the behavior of f(x) in relation to these sets may not be fully articulated.
Bleys
I came across a problem in Calculus by Spivak, and I'm having trouble formalizing the proof.
Let [tex]A_{n}[/tex] bet a set of finite numbers in [0,1], and if [tex]m \neq n[/tex] then [tex]A_{n}[/tex] and [tex]A_{m}[/tex] are disjoint. Let f(x) be defined as
f(x)=1/n if x is in [tex]A_{n}[/tex] and f(x)=0 if x is not in any [tex]A_{n}[/tex]. The question asks to prove the limit as x goes to a of f is 0 for any a in [0,1].
Now I thought: given an n, there are only finitely many elements of [tex]A_{n}[/tex] in a neighborhood of a. Choose the smallest such n, say [tex]n_{0}[/tex]. Then [tex]f(x)\leq1/n_{0}[/tex]. Restrict the neighborhood further so that none of the elements of [tex]A_{n_{0}}[/tex] are in the interval. Then choose the next n such that it's minimal. Obviously [tex]f(x)\leq1/n\leq1/n_{0}[/tex]. Successively doing this, for arbitrarily small x, f(x) will tend to 0.
I don't know how to prove this using the limit definition; can someone help me out with what [tex]\delta[/tex] to choose?
The smallest such n with what property? You're not very clear about that. Here's a proof: I'm going to assume f(a)=0; the other case is only a slight modification and should be instructive for you to think about. Fix [tex]\varepsilon>0[/tex], then there exists N > 0 with [tex]1/N < \varepsilon[/tex]. Let [tex]B_N = \cup_{ n = 1 }^N A_n[/tex], so B_N is a finite set, and [tex]a \not \in B_N[/tex] (why?). Now, let [tex]\delta > 0[/tex] be such that [tex]( a - \delta, a + \delta ) \cap B_N = \emptyset[/tex] (why does such a [tex]\delta[/tex] exist?). Then if [tex]| a - x | < \delta[/tex], either [tex]x \in A_m[/tex] for m > N, or f(x) = 0. In either case, [tex]|f(a) - f(x)|<1/N<\varepsilon[/tex], as desired.
you're on the right track, you should break this down into 2 parts:
1) if a is in a set An
2) if a is not in a set An
given an epsilon larger than 0, you must consider all f(x) = 1/n that fails ( larger than epsilon). Suppose you consider all 1/n/f(x) >= epsilon, then you can consider a union of sets (S) An such that f(x) >= epsilon for any element in a set An. Now you've reduced the problem to taking delta to be the min distance between the members of that set (S) and a (the distance between the greatest lower bound of (S) and a). If a is a member of the set itself, then you can use the exact same argument, since we are only concerned with behaviour as x APPROACHES a. Also, you know that you can always use this general argument because the interval between any numbers is always infinitely dense.
Sorry, what I meant to say was the smallest n such that the set [tex]A_{n}[/tex] has an element in the neighborhood of a.
so B_N is a finite set, and (why?)
f(a)=0 iff a=0, by definition of f, and this is iff a is not in any An.
Because B_N is finite.
Did you assume f(a)=0 because you had [tex]( a - \delta, a + \delta )[/tex]? Would [tex]0 < | a - x | < \delta[/tex] solve that? After all, since we are looking at the limit 0 then the expression [tex]|f(a) - f(x)|<\varepsilon[/tex] becomes [tex]|f(x) - 0|=|f(x)|<\varepsilon[/tex], since the value of f at a doesn't matter.
So since S will be finite (since there will be an n such that [tex]1/n<\varepsilon[/tex]) then that delta will work. Can I just not consider whether a is in the set or not. After all like you said, we're interested in the limit, not continuity. So [tex]0 < | a - x | < \delta[/tex] would solve that.
Ok I think I get it. I was having trouble formulating all this with the [tex]\delta - \varepsilon[/tex] definition. Thanks for all your help!
Did you assume f(a)=0 because you had [tex]( a - \delta, a + \delta )[/tex]? Would [tex]0 < | a - x | < \delta[/tex] solve that? After all, since we are looking at the limit 0 then the expression [tex]|f(a) - f(x)|<\varepsilon[/tex] becomes [tex]|f(x) - 0|=|f(x)|<\varepsilon[/tex], since the value of f at a doesn't matter.So since S will be finite (since there will be an n such that [tex]1/n<\varepsilon[/tex]) then that delta will work. Can I just not consider whether a is in the set or not. After all like you said, we're interested in the limit, not continuity. So [tex]0 < | a - x | < \delta[/tex] would solve that.
It's a good idea to say how the limit works in both cases, you need to show that you've considered that case (it is a significant case). But in the end, it uses the same argument.
The delta you are taking is the min ( |a-x| : x [tex]\in[/tex] [tex]\cup[/tex] n=1 to i An )
Here is an intuitive version of the proof:
|A1||A15||A20||A4|<----a------>|A7||A9||A10000||A124921894381241|
Any x's will be dispersed into different sets An, so take delta to be the min distance between a set and the point a. This interval between a and any x in sets An will always exist, since an interval of real numbers is always infinitely dense
  • · Replies 24 ·
  • · Replies 24 ·
