System of ODE Boundary Value Problem with 2nd Order Backward Difference
The discussion focuses on solving a system of ordinary differential equations (ODEs) using the Second Order Backward Difference formula in MATLAB. The equations presented are: du/dx = 998u + 1998v and dv/dx = -999u - 1999v, with boundary conditions u(0) = 1 and v(0) = 0 for the interval 0 < x < 10. The user encounters difficulties with the k-2 index in the backward difference equation, suggesting the potential use of a fictitious point. Ultimately, they consider employing the Runge-Kutta 4th order (RK4) method to initiate the numerical solution.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with MATLAB programming
  • Knowledge of numerical methods, specifically the Second Order Backward Difference formula
  • Experience with the Runge-Kutta 4th order (RK4) method
  • Implement the Second Order Backward Difference formula in MATLAB
  • Explore the use of fictitious or ghost points in numerical methods
  • Learn about the Runge-Kutta 4th order (RK4) method for solving ODEs
  • Investigate Neumann boundary conditions and their applications in numerical solutions
Mathematicians, engineers, and students working on numerical methods for solving boundary value problems in ordinary differential equations.
teknodude
[tex]{\frac {{\it du}}{{\it dx}}}=998\,u+1998\,v[/tex]
[tex]{\frac {{\it dv}}{{\it dx}}}=-999\,u-1999\,v[/tex]
[tex]u \left( 0 \right) =1[/tex]
[tex]v \left( 0 \right) =0[/tex]
0<x<10
[tex]{\frac {f_{{k-2}}-4\,f_{{k-1}}+3f_{{k}}}{h}}[/tex]
I'm trying solve this numerically in matlab, but can't seem to figure out what to do with the k-2 indice in the 2nd order backward difference equation, because it is outside the boundary. I was thinking of using a ficticious or ghost point, but I thought that only applies if a neuman boundary condition is given. The way i think of it, I have 4 unknowns and only 2 equations.
EDIT: ok after thinking about it. I think I have to use another numerical method to start the process, like RK4.
I think that's a good idea xD
  • · Replies 0 ·
