Further questions on the basics of Lie Algebras
  • Context: Graduate
  • Thread starter Thread starter vertices
    Basics Lie algebras
The discussion revolves around foundational concepts in Lie algebras and Lie groups, specifically addressing questions about the connected component of the identity, the relationship between the Lie algebras of special orthogonal and orthogonal groups, and the topological properties of the SU(2) Lie group in relation to spheres in three-dimensional space.
  • One participant inquires about the "connected component of the identity," suggesting it is the largest subgroup that is also a connected topological space, and notes that connectedness for Lie groups may relate to path connectedness.
  • Another participant explains that the Lie algebra of matrix Lie groups can be defined by the condition that exp(tX) is in the Lie group for all real numbers t, asserting that both Lie(SO(n)) and Lie(O(n)) consist of traceless hermitian n×n matrices.
  • There is a discussion about the isomorphism of the SU(2) Lie group to a sphere in 3D, with one participant clarifying that it is not Lie group isomorphic but rather homeomorphic and possibly diffeomorphic, suggesting a proof involving continuous bijections from SU(2) to S3.
  • A later reply presents a computation attempt regarding the matrix representation of SU(2), expressing confusion about the dimensionality of the resulting parameters and questioning whether it should belong to a 4-sphere.
  • Another participant responds by clarifying that the determinant condition leads to the definition of a 3-sphere, explaining the dimensionality of spheres in relation to manifolds.
Participants express differing views on the isomorphism of SU(2) and its topological properties, with some clarifying distinctions between homeomorphic and Lie group isomorphic. The discussion remains unresolved regarding the dimensionality of the parameter space derived from the matrix representation.
There are unresolved assumptions regarding the definitions and properties of connected components, as well as the implications of the determinant condition on the dimensionality of the spheres involved.
vertices
I'm reviewing my Group theory notes at the moment. I have a few questions.
1)what is the "connected component of the identity"? (How would you go about working this out?)
2)Why is Lie(SO(n))=Lie(O(n))?
3)Why is the SU(2) Lie group isomorphic to a sphere in 3D?
The largest subgroup that's also a connected topological space. I think that for Lie groups, "connected" is equivalent to "path connected", which means that what you have to check is that for each g in the group, there's a continuous curve from the identity to g.
For matrix Lie groups, we can use the simple definition of a Lie algebra: A matrix X is in the Lie algebra if exp(tX) is in the Lie group for all real numbers t. This condition implies that for both Lie groups, the Lie algebra is the real vector space of traceless hermitian n×n matrices.
Note that since det(exp(tA))=exp(tTr(A)), both the conditions ±1=det(exp(tA) and +1=det(exp(tA)) imply the same thing, that Tr(A)=0.
This book can tell you the details.
Not Lie group isomorphic. Just homeomorpic (topological space isomorphic) and probably diffeomorphic (manifold isomorphic). What you're supposed to prove is that there's a continuous bijection from SU(2) into S3, and this is just a tedius calculation. Write down the most general complex 2×2 matrix U and find out what relationships between its components you can derive from the conditions [itex]U^\dagger U=I[/itex] and [itex]\det U=1[/itex]. You should end up with the condition that defines the unit 3-sphere.
Thanks Fredrik for your help in this and other threads. Hope you had a good Christmas:)
I attempted this computation as you suggested. I get matrix elements that look like this (sorry I don't know how to do matrices in Latex):
a b
-b* a
So there are two parameters, a and b. But because a=x+iy and b=w+iz, that's 4 parameter in total. So should it not belong to a 4-sphere?
The fact that the determinant of the matrix must be =1 gives you [itex]w^2+x^2+y^2+z^2=1[/itex]. That's the definition of a 3-sphere. Note that a 2-sphere is a sphere and a 1-sphere is a circle. The number indicates how many dimensions the manifold has. A circle is a 1-dimensional manifold because its coordinate systems are maps into [itex]\mathbb R[/itex], not into [itex]\mathbb R^2[/itex].
Matrices start with \begin{pmatrix} and end with \end{pmatrix}. End each line except the last with \\, and put & symbols between the elements. For example, \begin{pmatrix} a & b\\ -b^* & a\end{pmatrix}
[tex]\begin{pmatrix} a & b\\ -b^* & a\end{pmatrix}[/tex]
Use vmatrix instead of pmatrix if you want a determinant.
  • · Replies 19 ·
  • · Replies 22 ·
