Which type of kite is better for low wind conditions: LEI or foil?
The discussion centers on the comparison between Leading Edge Inflatable (LEI) kites and Foil kites for low wind conditions in kitesurfing. LEI kites feature large inflatable bladders and a curved shape, resulting in less drag, while Foil kites are closed-cell RAM air parachutes with a flatter design, offering a higher aspect ratio and lighter weight. Participants debate the aerodynamic efficiency of both types, with some asserting that Foil kites perform better in low winds due to their design, while others argue for the advantages of LEIs. The conversation also touches on the physics of lift and drag, highlighting the complexity of kite aerodynamics.
  • Understanding of kitesurfing terminology, specifically LEI and Foil kites
  • Basic knowledge of aerodynamics, including lift and drag equations
  • Familiarity with the concept of aspect ratio (AR) in kites
  • Awareness of fluid dynamics principles as they apply to kite performance
  • Research the aerodynamic properties of LEI kites and their performance metrics
  • Study the design and functionality of Foil kites, focusing on their bridles and aspect ratio
  • Explore the physics of lift and drag in fluid dynamics, particularly in relation to kites
  • Investigate the use of wind tunnels for testing kite performance under varying conditions
Kitesurfers, kite designers, and aerodynamics enthusiasts seeking to understand the performance differences between LEI and Foil kites in low wind conditions.
Marshall10488
just wanted to say hi first as this is my first post.
I will explain the story...
There is an ongowing debate within the Kitesurfing world regarding the aerodynamics of LEI (leading edge inflateable) kites and Foil (like RAM aim parachutes) kites.
LEI Kites:
They have large inflateable 'bladders' that keep the shape of the kite and also make it float. they are single skin and the foil shape comes from the leading edge's cylndrical shape. They have only a few 'bridle' lines on the leading edge with a thickness of about 3-5mm. very curved shape so projected area is not same as surface area
http://www.boardlife.sk/userfiles/16-North_Rebel_2007_12m2_a_North_Rebel_2008_10m2.JPG.311008_122249_11.JPG
some links to LEI companies
http://www.northkites.com/public/content/index_eng.html"
http://www.naishkites.com/en/index.html"
Foil kites:
closed cell RAM air parachutes. twin skin. lots of bridles, the majority of which are about 1-2mm. then some 3-5mm and 2 5-8mm. very flat so projected area is close to surface area. very light.
http://www.flysurfer.com/gallery2_code/d/141624-2/SPEED3+Deluxe+mit+Bridles.png
main water re-launchable foil company
http://www.flysurfer.com"
Ok so the argument is that some beleave that foil kites are better in low wind as they are lighter, tend to have a higher AR. Others that LEIs are better as less drag etc.
My thinking is: Lift needed to fly it L=ma
Lα1/M
Lα V[squared]
Lα Lift coefficient
L α Area
But i need to add in the drag equation so lift needed to fly:
l=ma + 0.5 Cd ρ V[squared] a (don't know if this is right)
so by equating i get that the velocity to beed gravity and drag
v=Root[(2ma)/(ρ(Cl Ak-Cd Ab)
Where Cl is lift coefficient
Ak is area of kite
Ab is area of bridles
Cd is drag coefficient
knowing that Cl = [2(pi)(AoA)]/[1+(2pi)/AR]
AoA= Angle of attack
AR = Aspect ratio
is there another equation for Cd without simply just rearaging the drag equation?
anyone who knows more about parachute/kite physics/fluid dynamics have a definitive answer to this discussion?
Thanks
Ben
Those are cool!
I suspect your simplified analysis is not worth doing; those look like very complicated shapes (you must consider the full 3-D problem) and the wind conditions are highly variable in time. Wind tunnels are used for a reason.
i'm not looking for exact just estimate, to prove either way. the big problem i have is the drag from the bridles due to harmonics.
  • · Replies 17 ·
