Cheapest way to produce electricity
  • Thread starter Thread starter otomanb
    Electricity
The discussion revolves around the various methods of electricity production and their associated costs. Participants explore different energy sources, including fossil fuels, nuclear, and renewables, while considering factors such as initial investment, maintenance costs, and regional availability.
  • Some participants argue that coal power is generally the cheapest for large-scale generation, while others highlight the high initial costs and environmental concerns associated with coal.
  • Natural gas is mentioned as a cheaper and quicker option to build compared to coal, but its historical cost relative to coal is debated.
  • Several participants propose that renewable sources like wind and tidal energy have low running costs, although initial setup and maintenance costs are noted as potentially high.
  • There is a suggestion that nuclear energy could be a cheap option once the plant is built, but concerns about regulatory approval and public perception are raised.
  • One participant emphasizes the importance of scale in wind energy production, noting that larger installations can harness significantly more energy.
  • Disagreements arise regarding the operating and maintenance costs of various energy sources, with some participants questioning the validity of cited cost estimates.
  • Some participants express skepticism about the long-term economic viability of renewable energy compared to traditional fossil fuels.
Participants do not reach a consensus on the cheapest method of electricity production, with multiple competing views on the costs and benefits of coal, natural gas, nuclear, and renewable energy sources remaining unresolved.
Participants highlight various assumptions, such as the availability of resources, regional policies, and the timeframe for capital costs, which influence their perspectives on electricity production costs.
otomanb
As we know there are different methods are used in different countries to produce power. What do you think which one near you is the most cheapest way to produce power.
Thanks
Coal power is generally the cheapest for large-scale generation.
Complicated question.
Depends on the market, do you need a large central plant that can run for years, or a plant that can handle quick changes in load.
What lifetime are you considering the capital cost over - and what interest rate are you paying.
what politics are involved in getting different kinds of plant approved in your country?
What fuel sources do you have.
If you have coal then coal is cheap - but the plants are big and expensive.
If you have natural gas then that's cheap and the plants are quick and cheap to build.
If you don't have fossil fuels and your government/people are sane then nuclear is cheap.
Once you've built the plant, then hydroelectric is cheapest to run.
near me using natural resources like coal and petrol for the generation of Electricity is not so good bcaz they are present in limited amount. I think wind and tidal way is very cheap and almost free running cost, what do u say?
in coal there is a big problem where to dispose off Coal's ash
Wind and tidal are very expensive. Initial cost of seting up the generators is expensive, then when you have them set up maintenance is expensive. Imagine major maintenance if you ran your car not on one 100 hp engine, but on 100 1hp engines. These costs may go down with time, but right now they are prohibitive.
Cheap energy. I would invest into nuclear.
Cheers
For wind? Source?
@ mheslep
for wind the source will be wind. very interesting question.
Maintenance cost is not so high bcaz no fuel involve & no wast disposal problem. Nuclear is also a very very cheap way to produce power as well but i hope USA will not get against. :shy:
Are we talking about renewable energy?
Wind is probably the cheapest, but only if you build it on a large scale. Solar, for example, is a fixed amount of energy for a unit area of radiation collection. The energy available from wind goes up with the square of the captured area and with the cube of the wind velocity. So 10mph winds have 8x the available energy as 5mph, and a rotor with a 100 foot radius has 100x the available energy as a rotor with a 10 foot radius. The fixed costs with wind would be the tower construction and the fabrication process. After that, if you can build one large enough you can harness huge amounts of energy in the right location.
If you are interested in building your own wind turbine I have put together a tutorial on how to do it, along with links of it in operation and how to carve your own blades. It is http://www.mindchallenger.com/wind" .
Historically natural gas is more expensive than coal per kWh(e). Natural gas plants are not very intrusive and cheaper than coal to build, so utilities throw up many of them but avoid running them unless they need them, e.g. peaking power.
As of 2006, least to most expensive, in the US
To Build, assumes no backup power ($ per kW):
Natural Gas Combustion Turbine $670
Natural Gas Combined Cycle $730
Wind $1750-2400
Coal $2080-2740
Solar Thermal $3150-5700
Nuclear $3500-7000, Biomass $3500
Solar PV $8100
To Operate and Maintain only, per unit energy generated (cents / kWh)
Solar Thermal (1), Wind (1.7 ), Solar PV (4.1) , Hydro
Nuclear (3-4 cents, 2015 est)
Coal ()
Natural Gas (2-3X coal)
Levelized Cost: Build and Operating costs combined (cents / kWh)
Coal 7.5
Gas Combined Cycle 8.6
Gas Turbine 17
Nuclear 13 in 2016
Edit: adding in actual O&M costs as I find them.
http://www.psc.state.fl.us/utilities/electricgas/RenewableEnergy/Full_Report_2008_11_24.pdf
Sorry I didn't phrase it very well.
Meant to say IF you have coal then that's cheap but IF you have natural gas fields then that's cheap.
The economics of the stations is also a factor. coal = big expensive to build, gas = stations are quick and cheap to build. So it also depends on the timeframe and what you are paying as an interest rate.
Wind $1750-2400
Coal $2080-2740
Solar PV $8100
Coal ()
Coal 7.5
Gas Turbine 17
Nuclear 13 in 2016
I find those numbers highly suspect. For example, nuclear shows a difference of 9 cents between operating cost and combined building/operating costs. This would allow the original building cost to be payed off in around 9 years. If you assume a nuclear plant only lasts 9 years then the 13 cents per kwh is valid, but life expectancy is >40years.
Also, solar thermal and wind power have very low operating costs. Has this been definitively established? The way those numbers read, solar thermal and wind power have the potential to drastically lower electricity costs. Is there any proof that this has actually happened? Last I checked paying for green energy was much more expensive than the dirty alternative. I would love cheap and clean energy, but I have yet to actually see it.
Maybe, but it doesn't make financial sense to use the huge 40+ y amortization period, the interest simply dominates. Consequently, I have the impression that current nuclear plants, capital costs paid off long ago, are huge cash cows, running 94% of the time.
I don't know what definitive means in this context, but I can't imagine what would drive solar thermal O&M costs, and the US has some ~20GW of wind installed now so I expect the experience is in place. The source above was an FP&L report, largest wind utility. Note: I can't determine whether of not the Production Tax Credits (PTC) are part of the wind costs.
The report notes that new transmission costs are left out of the calculations, but we know that remote solar and wind will need more of that. Another cost is fossil / nuclear baseload backup for the wind and solar when their offline - not a problem yet but as the they grow it increasingly will be.
  • · Replies 27 ·
  • · Replies 0 ·
  • · Replies 38 ·
  • · Replies 38 ·
