Can I Create a Dummy Load on a 120VAC Circuit That Draws .3A?
  • Thread starter Thread starter Medalcraft
    Load
The discussion revolves around creating a dummy load on a 120VAC circuit that draws 0.3A. Participants explore various methods to achieve this, including the use of resistors and light bulbs, while addressing safety and technical considerations.
  • One participant suggests using a resistor and emphasizes the importance of understanding Ohm's law for safety when working with 120VAC.
  • Another participant proposes using four 100-ohm resistors in series to achieve the desired resistance and current, providing calculations for total resistance and power dissipation.
  • A participant shares their experience of using a 1K resistor, which failed due to insufficient wattage rating, highlighting the need to consider power ratings for resistors.
  • One suggestion includes using a 120-volt 40-watt lamp bulb, which would draw approximately 0.33A, noting that it might be easier to wire up compared to resistors.
  • Concerns are raised about the variability of a light bulb's resistance based on temperature, suggesting that this could affect the accuracy of the load, and recommending experimentation with different configurations if precise resistance is critical.
  • Another participant mentions that the initial cold resistance of a light bulb can be significantly lower, leading to a higher startup current before stabilizing at the desired 0.3A.
  • Discussion includes the idea that medium to high power resistors are not expensive and may provide more stable resistance values compared to light bulbs.
Participants express various methods to create the dummy load, with some favoring resistors and others suggesting light bulbs. There is no consensus on the best approach, and concerns about safety and accuracy remain unresolved.
Participants note the importance of considering wattage ratings for resistors and the variability of resistance in light bulbs based on temperature. The discussion reflects different assumptions about the requirements for the dummy load and the acceptable range of current draw.
Medalcraft
I need to create a dummy load on a 120VAC circuit. The load must draw .3A. How can I do this?
A resistor?
If you don't know Ohm's law to work out the resistance and how to work out the power in the resistor are you sure you should be playing with 120VAC?
We aren't trying to be difficult but if you are an 8year old kid somewhere who has decided to learn electricity with potentially lethal line voltages because they don't have a spare AA battery we don't really want to be responsible
You could get four 10 watt 100 ohms resistors and put them in series.
Total resistance = 4 * 100 = 400 ohms
Current = 120 volts / 400 ohms = 0.3 amps
Power dissipated in each resistor = 0.3 A * 0.3 A * 100 ohms = 9 watts
Total power = 0.3 A * 0.3 A * 400 ohms = 36 watts
Thank you. That is what I thought, 400 ohms. Just wanted to make sure. I tried a different resistor that was here, 1K - magic smoke.
Forgot to factor in wattage rating for resistor.
Medalcraft said:
I tried a different resistor that was here, 1K and it must have been bad (magic smoke).
No it wasn't powerfull enough.
A regular little resistor can dump about 1/4 watt of heat - any more than this and it will just melt
A 10W resistor is a larger more expensive lump of metal it wil look something like this
It's also going to need mounting to some sort of heatsink to dump the 40W of heat
Thank you again. I forgot about the wattage values for resistors. Been quite a few years since I last dealt with resistors.
If 0.33 amps would be OK, you could use a 120 volt 40 watt lamp bulb.
Power = voltage * current
so current (in amps) = power (in watts) / voltage
Current = 40 watts / 120 volts = 0.33 amps.
vk6kro, I bow to your Alexander-esque knot-chopping abilities. To the OP, this might also be easier to wire up, since you can go down to your local hardware store, buy a light socket, and then use wire nuts to connect it to your circuit (if applicable).
The only snag with using light bulbs is that you can't be certain of their resistance at anything other than their normal operating temperature. The resistance varies over a range of ten to one from hot to cold. You may need to experiment a bit and even use two in series (one high wattage and one low wattage) to get the resistance you want - if its value is critical. You can also buy very low wattage heaters which don't operate at white heat and will have more stable resistance values.
This is a 120 volt lamp being used on 120 volts. It should be OK unless the slight increase in current (0.33 A vs 0.3 A ) matters.
Well that 'cold' low resistance holds for only ~.1 seconds, after that time rated current and wattage is expected. So yes there will be a ~10X startup current for the OP, then quickly settling to 0.3 A and staying there absent extreme ambient conditions.
My comment really related to the possibility of the supply volts not always being the nominal value - the resistance varies right over the filament temperature range. Medium / High power resistors are not expensive are they? It all depends on the accuracy required, in any case.
11K
  • · Replies 25 ·
18K
