X Prize Clean Aviation: $10 million
  • Thread starter Thread starter mheslep
    Aviation clean
The discussion revolves around the proposed X Prize for Clean Aviation, which aims to incentivize the development of all-electric aircraft capable of completing a coast-to-coast flight in the United States without emitting greenhouse gases. Participants explore the technological feasibility, energy storage challenges, and implications of such a prize on innovation in aviation.
  • Some participants discuss the potential of electric ducted fan technology and advanced battery systems as crucial components for achieving the prize's goals.
  • One participant proposes modifying a Bombardier CRJ900 with ducted fans and estimates energy consumption metrics for the contest, suggesting significant battery weight requirements.
  • Concerns are raised about the practicality of energy storage solutions, with some arguing that the prize may not effectively stimulate interest in electric aviation.
  • Questions are posed regarding the efficiency of using electric motors for ducted fans versus traditional propellers, with differing opinions on the advantages of each approach.
  • Some participants express skepticism about the environmental benefits of electric aviation, arguing that it may merely shift pollution sources rather than eliminate them.
  • There are discussions about the efficiency of electric motors compared to gas turbines, with some highlighting the potential for high efficiency and reduced noise in electric systems.
Participants express a range of views on the feasibility and implications of the Clean Aviation X Prize. There is no consensus on the effectiveness of the prize in promoting electric aviation or on the technical approaches to achieving the goals outlined in the proposal.
Participants highlight limitations related to energy storage capabilities and the assumptions underlying the proposed technologies. The discussion reflects ongoing uncertainties in the field of electric aviation and the challenges of transitioning from traditional fuel sources.
  • #31
Ahh. I misread. I thought he somehow got latched on to the NASA teet.
  • #32
FredGarvin said:
Moller? All I can say is...meh.
Yes as Cyrus says Mark Moore is P.I. out of NASA Langley.
Cyrus is correct. Acoustics from that thing will be horrendous.
Is there a standard approach for characterizing the noise?
I'd read that increasing the number of blades and RPM increases the frequency signature which increases atmospheric attenuation - 8 blades shown here.
Re piloting VTOL, note this is not a tilt-rotor design, eliminating an additional control degree of freedom. I would expect that helps simplify control.
  • #33
Cyrus said:
Whenever someone claims "no service ceiling," you know instantly they either have no idea what they are talking about
I assumed that to mean no extension cord :smile:
Slighty on-topic.
Is there ANY circumstance in which a ducted fan is more efficient than a prop?
Sometimes they are more convenient for other reasons (lie the ducted rear rotor on helicopters)
  • #34
mheslep said:
I can't speak to the flow of technology from the X Prize. I worked on a team for DARPA's successful autonomous vehicle Mojave desert contest (~80 miles)...Thus a fairly large push has come about in the robo world, DARPA's goal, all at the cost of couple $2-3 million for DARPA.
I think this was the smartest thing DARPA has done in decades.
Compared to the old way of just paying General Dynamics a couple of $Bn for some secret project that never sees daylight.
Even including the 10x as much spent by the universities and sponsors the RoI is incredible.
  • #35
We're in VIOLENT agreement on this. Generally, the robotics performance of the military contractors is atrocious, despite being hugely expensive, in comparison to the commercial vendors (e.g. Irobot) and academia.
  • #36
For everybody else - there is an excellent and entertaining talk by Sebastian Thrun from Stanford's team.
http://video.google.com/videoplay?docid=8594517128412883394
  • #37
I am not quite sure what you mean by standard approach. There is the area of aeroacoustics in which we look at the noise contributions due to aerodynamic influences. It is a relatively new area but a fair amount is known. In this case, it was mentioned that loading of the blades is a factor, as is relative mach number of each blade and blade tip. The spreding/attenuation over distances is very custom for each application in that the speeds and frequencies are always different. Plus, since this is unshrouded you don't have issues arising from waveguides, i.e. ducts. Things are different when a blade tip is sonic or supersonic. I can only assume they would be sonic, which means they will naturally attenuate/decay with increasing radius from the source.
There is a FAR (I can not remember the number off the top of my head) that governs the testing of noise signatures around airports. It is pretty detailed and measurements are required to simulate an aircraft arriving and departing and at altitudes, of I believe, 400 ft. It has been a while since I have read that FAR. I think it wouldn't be a killer for this application, but it would definitely be a concern.
  • #38
Seen it many times.
Thrun's team setup next to ours in the semi-final, so I had the opportunity to talk him and his team over several days. He's a fantastic engineer, great sense of humor.
  • #39
I was asking for indulgence in explaining how characterization of prop acoustics - fundamentals. Googling wasn't providing any useful fundamentals. This is a start:
Well eventually I wanted to estimate dBl / distance given some prop assumptions. E.g. vehicle developing ~1000 lbs thrust at take off, RPM x, tip speed sonic, etc, add in latest
prop noise reduction techniques, then compare with known noise of 200HP turbine or piston engine.
  • #40
mheslep said:
Thrun's team setup next to ours in the semi-final, ... He's a fantastic engineer, great sense of humor.
Rather letting the side down, as a German engineering prof though - stereotype-wise ;-)
  • #41
Well he's been in the US for a long time. Then, Einstein apparently had a silly streak.
  • #42
mheslep said:
Sorry I don't follow. What source of power are you suggesting, if not an electric motor? Edit: Perhaps you are asking: why use an electric motor instead of a traditional gas turbine? Electric motor can be >95% efficient, is quiet, as you mentioned above, and can run on electric charge that may have been generated on the ground and stored in the aircraft.
Post #2, for purposes of this prize. 11 metric tons of battery per 850 mile leg.
I would suggest obtaining a formal education in the subject before making such outlandish claims. That 95% efficiency won't do you much good if it comes with a huge weight penalty. Gas turbine engines are really unparalleled when it comes to thrust/weight ratio and energy density.
  • #43
Thanks, I think I have a pretty good one, and a license to use it, though it is limited on the subject of aerodynamics. To be constructive, could you show how those numbers (11 metric tons / 850 miles) are outlandish? I think I've crunched and shown the basic numbers if you backtrack the post.
Gas turbines are not an option for the prize, hence the thread topic "CLEAN AVIATION". Please see the https://www.physicsforums.com/showpost.php?p=2535479&postcount=1":
UK Drives and Controls said:
Superconducting motors operating with almost no losses could achieve power densities of 10–20kW/kg (and perhaps even higher) and torque densities of more than 35Nm/kg (compared to 10Nm/kg for the best conventional motors), the US researchers say.
Edit: maybe gas turbines hold the trophy for thrust/weight; the above challenges power/weight.
Maybe also see another thread for existing HTS propulsion research.
https://www.physicsforums.com/showpost.php?p=2292842&postcount=14
  • #44
I took issue with a statement made by many of these articles: namely, that you don't need air intakes because it's electric. This is hog-wash because anyone that has flown an electric airplane knows they get very hot (battery, motor, and electronics). Cooling them is absolutely an issue. I do not buy that they don't need 'air intakes' for this vehicle. There will be significant power losses in the form of [tex]i^2R[/tex].
Also, how is this thing 'stealth' with big spinning rotors?
  • #45
You mean RC airplanes? That's the 'because'?
Cooling them is absolutely an issue. I absolutely do not buy that they don't need 'air intakes' for this vehicle. There will be significant power losses in the form of [tex]iR^2[/tex].
I think the point here is that the air required for combustion, on the order of liters per second per HP*, completely dwarfs any air flow required for dissipating the couple hundred watts from this one man aircraft. Given the stated battery load (45kg) for Moore's VTOL, the [STRIKE]maximum[/STRIKE] continuous power is probably ~11kW (15HP). Though a small intake would suffice, no air intake at all is required dissipate 5% of that power as heat, just air flow over sufficient dissipative surface. I've built enclosed electronics boxes that conduct/convect away 500W from a two cubic foot box.
*quick math for gasoline combustion at 30HP requires 1 liter O2/sec, 5 liters air/sec, STP
How does one calculate the dBls / distance from these rotors?
  • #46
How does the fact that a UAV is RC scale, or large scale, change the fact that there *will* be power losses by the engines that pose a thermal problem?
Please explain why you think this is not the case.
Also, what calculation did you do to get this 15HP number from? I don't believe this for one second.
Also, I did not say 'quiet' I said 'stealth': as in, radar cross signature.
  • #47
Let's do a simple calculation using the momentum theory equation of an *ideal* rotor. A real rotor will inevitably require more power:
[tex]P = \frac{T^{3/2}}{\sqrt{2 \rho A}}[/tex]
Assuming:
[tex]\rho = 0.002378[/tex] slug ft^-3
[tex]A = 28.27[/tex] Assuming a generous 6' rotor diameter
[tex]T = 300lbs[/tex] (Assume 600lb GTOW)
That gives a power of about 25.7HP, very close to the claim on SIAM article of 60HP total (30HP each)!
  • #48
Because the efficiency of electric motors and battery packs varies considerably. Larger motors can hit 95-98% efficient, but it is difficult to do that at small scale. Also I wouldn't imagine there is much room or effort made for thermal dissipation made on an RC, at least not the couple small ones I've toyed with. Small motor/battery mounted on poor heat conductors - plastic/composite - so yeah they'll get hot.
SIAM said Moore's using a 45 kg battery load. Li Ion puts out http://en.wikipedia.org/wiki/Lithium-ion_battery" continuous (above I said maximum and corrected that to continuous) Edit: maximum battery discharge rate is typically be 10x (250W) for very short periods, i.e. peak up to 150HP. The motor would undoubtedly be the limiting factor - SIAM suggests it is 60HP.
Wasn't the 'stealth' reference in SIAM was on thermal signature? Obviously electric will be low compared to combustion.
Yes:
SIAM said:
n addition, since electric motors are so efficient, they also generate far less heat. This not only gives them a lower thermal signature for military stealth, but means they don't need anywhere near the same amount of cooling air flowing over them that internal combustion engines do,...
  • #49
Assuming:
Thanks. How does one estimate the acoustic output of such a prop?
  • #50
Want a PhD? Hehehe, honestly, I think its all empirical. The equations look like the NS equations: no closed form solutions.
  • #51
  • #52
Yes silly question but I thought some rough bounds could be put on the maximum noise. For instance, if 60HP is converted completely to audible sound (of course its not) how loud is that, assuming no resonance or amplification.
  • #53
I'll ask someone I know about a relationship to noise. I think its something like the log of the disk loading.
  • #54
mheslep said:
For illustration:
NEMA electric motor efficiency requirements
Power
(hp) Minimum Nominal Efficiency
1 - 4 78.8
5 - 9 84.0
10 - 19 85.5
20 - 49 88.5
50 - 99 90.2
100 - 124 91.7
> 125 92.4
I suspect the typical RC motor is 0.1 to 0.01 HP. You get the idea.
http://www.engineeringtoolbox.com/electrical-motor-efficiency-d_655.html
On takeoff, my motor would draw almost ~750W. The speed controller was rated at 100A max.
  • #55
What's rated power of the motor? That's a nice thing about electrics - they can peak well above rated (5x at least).
  • #56
http://www.allerc.com/z40all.htm
~1100W
  • #57
~1100W
I don't see efficiency or output power, only input, but its still impressive. 3kW/kg (input) continuous in 1.9" OD case. That compares to, say, 4kW/kg (output) in the much larger Tesla AC induction motor.
  • #58
You asked for it. I scanned this in from one of my references. The mB notation refers to the mth harmonic/mode and B is the number of blades. The rest should be somewhat decipherable.
  • #59
Boy let me tell you, those guys get HOT.
  • #60
So do the lithium batteries most of them use for power.
  • · Replies 0 ·
  • · Replies 0 ·
