Why Is the Electric Field Zero Between Uniformly Charged Parallel Plates?
  • Thread starter Thread starter LonghornDude8
    Parallel Plates
The discussion revolves around the electric field produced by two large, uniformly charged parallel insulating plates. The original poster questions why the electric field is zero between the plates, despite the presence of charge density on both plates. They express confusion regarding the behavior of the electric field as one approaches the plates and the implications of charge density on the resultant electric field.
  • Participants discuss the application of Gauss's Law and the nature of electric fields generated by uniformly charged plates. Questions arise about the integration of electric fields and the relevance of Coulomb's Law in this context. There is also a focus on the construction of a Gaussian surface and its implications for calculating the electric field.
The conversation is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the use of Gauss's Law and the importance of symmetry in the charge distribution. However, there remains a lack of consensus on the application of Coulomb's Law and the correct approach to understanding the electric field behavior.
Participants are navigating the complexities of electric field calculations, including the distinction between point charges and continuous charge distributions. There is mention of a need for clarity on the role of Gaussian surfaces in the application of Gauss's Law.
LonghornDude8
Electric Fields/Gauss's Law: Parallel insulating plates
Here's the question: Two large, parallel, insulating plates are charged uniformly with the same charge density σ. What is the magnitude of the resultant electric field E ?
The correct answer: zero between the plates, σ/E0 outside
My question: Why is the field between them zero? I understand that there is at least a point in between them where the field is zero, but why is the whole field zero. As you get closer to one plate the force from that plate increases (whether it be attractive or repulsive) and the force from the other decreases. This means that the electric field is changing (the only way to get an unbalanced force). In addition, if the two add together, why do you get σ/E0 for the answer. Shouldn't each have a field vector of σ/E0 and when they add, 2σ/E0? I don't really see how they get σ/2E0 for each plate when they each have a charge density of σ. Finally, why does the field not vary with the distance? Is it just a property of a plate or am I just missing something?
Yes, you are missing something. You are missing the approach you need to take to solve the problem. You can not just guess what the field is going to do with distance, you should calculate it using concepts you have learned.
What useful concept/theorem could you use to calculate the electric field from a nice, symmetric distribution of charge, such as in this problem?
I'm guessing you are talking about Gauss's Law, but if you integrate, you get the integral of 2ko<pi>dr/r2. Therefore the force does vary by difference, that's Coulomb's Law
I'm not saying you're wrong, but I'm just finding things conflicting with each other
No, that's not correct. Do this carefully, and one step at a time. If you use Gauss' Law correctly, you end up having to do little or no integration. And in any case, please be as descriptive as possible in explaining yourself.
First, when applying Gauss' Law, you need to begin by constructing a Gaussian surface. What is the shape of the surface, and where is it constructed? Then what's the next step?
The Gaussian surface is a plane (flat plane) and I actually just found the powerpoint from my teacher and there was a slide on this. I understand what you need to do to solve the problem, I just don't really understand why Coulomb's law does not apply.
Coulomb's Law does apply, so long as you apply it correctly. What is important about Coulomb's Law is that it applies only to a single point charge. To calculate electric fields from a distribution of charges via Coulombs law, you would have to integrate the electric field (which is a vector quantity, so you have to be careful with this) due to each of the charges spread out over the entire surface containing them. This can be a messy thing to do, which is why it is often easier to utilize the symmetry of the problem and apply Gauss' Law.
Furthermore, the Gaussian surface, is not a plane. Gauss' Law tells you about the flux through a closed surface, and a plane is not a closed surface. Look up "Gaussian pillbox".
  • · Replies 18 ·
