Building a matrix using while loops? (MATLAB)
The discussion focuses on building a matrix using "while" loops in MATLAB, specifically addressing an issue with the inner loop not resetting the variable 'j'. The user, Mike, encounters a problem where only the first row of the matrix 'S' is being calculated due to 'j' retaining its last value after the inner loop completes. A solution is provided, which involves resetting 'j' to 1 at the start of each iteration of the outer loop. Additionally, the suggestion to use "for" loops is presented as a more efficient alternative for this task.
  • Understanding of MATLAB programming language
  • Familiarity with matrix operations in MATLAB
  • Knowledge of control structures, specifically loops
  • Experience with function m-files in MATLAB
  • Learn about MATLAB "for" loops for matrix manipulation
  • Explore MATLAB function m-files and their usage
  • Investigate debugging techniques in MATLAB to identify loop issues
  • Study best practices for optimizing MATLAB code performance
MATLAB programmers, data analysts, and anyone looking to improve their skills in matrix manipulation and control structures within MATLAB.
mikeph
Building a matrix using "while" loops? (MATLAB)
Hello
Here is my code:
Code:
i = 1;
j = 1;
S = zeros(11,11);
while i < 12
    while j < 12
        S(i,j) = Test1(a(i,j),b(i,j),c(i,j));
        j = j + 1;
    end
    i = i + 1;
end
a,b,c are all 11x11 matrices and Test1 is a function m-file which outputs a number. (I have tested it for all the values that a(i,j), b(i,j) and c(i,j) take).
My code is only calculating the first row of S, ie. S(2,1) = 0 still. I don't know why the program is ending without adding 1 onto i and repeating the loop, I can only imagine the "while" loop is the wrong way of going about this?
Thanks for any help,
Mike
A better choice is a for loop for each of your loops.
Code:
for i=1:11
  for j = 1:11
     %% loop body
  end
end
You can do what you're doing with while loops, but they are in a sense more primitive control structures, so you have to do more of the work in your code. I think what might be happening is that after the inner loop has gone through a complete set of iterations, and i is now 2, you still have the last value of j (=12) in your inner loop. A fix for this problem might be like so:
Code:
while i < 12
    j = 1   %% added this line
    while j < 12
        j = j + 1;
    end
    i = i + 1;
end
  • · Replies 41 ·
11K
11K
