Is it possible to calculate hour-glass parameters using calculus?
  • Context: Undergrad
  • Thread starter Thread starter ashishvinayak
    Calculus Parameters
The discussion revolves around the feasibility of calculating parameters related to hour-glass devices using calculus. Participants explore the physical modeling of sand flow, the relationship between mass and timing, and the practicality of variable timing mechanisms.
  • Some participants question whether it is possible to calculate the mass of sand required for an hourglass and if it can be adjusted to function as a variable timing device.
  • One participant asserts that calculus does not inherently deal with mass and emphasizes the need for a physical model to approach the problem.
  • Another participant suggests that the mass of sand would influence the velocity of sand flow, indicating a relationship between mass and timing.
  • A proposed physical model involves the assumption that the sand flux through the hole is proportional to the pressure exerted by the sand above it, leading to a differential equation for sand level over time.
  • Some participants express skepticism about the realism of models that assume a direct relationship between sand mass and flow velocity, noting that increased mass may not necessarily lead to increased velocity beyond a certain point.
  • One participant mentions practical considerations, suggesting that actual hourglass makers typically rely on measurement and trial-and-error rather than theoretical calculations.
  • Another participant argues that a variable timing hourglass could still have practical applications, despite potential impracticalities.
Participants express differing views on the practicality of calculating hour-glass parameters and the realism of various physical models. There is no consensus on the best approach or model to use, and the discussion remains unresolved regarding the relationship between sand mass, flow velocity, and timing.
Participants note that measuring the volume of sand in a geometrically complex upper cone as a function of time presents challenges. Additionally, assumptions about the relationship between sand mass and flow velocity are debated, indicating potential limitations in the proposed models.
ashishvinayak
Is it possible to calculate "hour-glass" parameters using calculus?
The standard hour-glass model drops sand from the top cone to the bottom in an hour.
Is it possible to calculate the mass of sand that would be required for making an hourglass? Further, would it be possible to change the hour-glass into a variable timing device depending on how much sand is in it?
Calculus has no notion of mass.
To solve a problem like this, you need to assume some physical model of the sand first.
what is a physical model? I think that the mass would be related to calculate this, because it would be variable thus varying the velocity.
The physical model is what actually tells you which mathematical equations that govern the movement of the sand. The goal is to find a physical model that most closely approximates the real world.
One simple physical model (although a bad one) is to assume that the flux of the sand through the hole is proportional to the pressure in the sand at the hole, i.e. it depends on the weight of the sand above it. This will give you a differential equation e.g. for the sand level in the upper part as a function of time.
A more realistic model than that could be to model the sand as some kind of fluid with a very high viscosity. But then the problem gets difficult.
The hour-glass is already a variable time device, if you change the amount of sand in it. More sand and it will take longer for it to fall down to the lower part.
EDIT: You could do some measurements, and then draw e.g. a 30min line somewhere on the top glass "cone", or maybe even 15min marks. E.g. put a piece of transparent tape on it with marks, and check a few times if the marks are consistently correct. And see if it works also when the glass has been disturbed during the timing process.
Torquil
I get somewhat of what you say. In that sense, I was modelling it in terms of pressure of the sand. Thanks anyway!
I forgot to mention why I thought the first model I mentioned was unrealistic. As you increase the amount of sand in the upper cone, eventually the sand velocity through the hole will not increase even if you put more sand on top.
So if you model assumes that the sand velocity will double if the amount of sand is doubled, I would not expect that to be very realistic.
Actually, it would be interesting to know how the sand flux through the hole depends on the amount of sand in the upper cone. You would need to measure the volume of sand in the upper cone as a function of time, but that is not easy when the "cone" is a complicated geometric shape.
Torquil
I take it this is strictly an academic exercise? I say that because (1) actual hourglass makers can just measure, and do a little trial-and-error, to figure out how much sand is required to get a fixed time, and (2) a variable time hourglass would be prohibitively impractical for people to use.
I think the variable of interest is just the initial amount of sand in the upper cone, and we would measure the total time as a function of that. The initial sand mass could be measured on a balance before adding it to the cone, so that would not be a problem.
Why would the velocity not increase? Wouldn't the sand on top put more pressure on the bottom sand? In that case if the sand amount increases wouldn't the velocity increase almost linearly?
It wouldn't be that impractical on every occasion. It would help in keeping different times (not that a watch can't do that) but just for a matter of interest! :smile:
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 100 ·
