Block inside a spinning cone - Newton's 2nd Law problem
The discussion revolves around a problem involving a block inside a spinning cone, specifically applying Newton's 2nd Law. The original poster presents their attempt at a solution, including equations related to net force, weight, and normal acceleration in a circular motion context.
  • Mixed
  • The original poster questions the treatment of weight and normal force components in relation to the incline and circular motion, seeking clarification on when to use components for these forces.
  • Some participants suggest that friction acts down the slope and emphasize the importance of analyzing forces along different axes.
  • There is a request for further explanations regarding the use of components in force analysis, indicating some confusion remains.
Participants are actively engaging with the problem, providing insights and clarifications. Some guidance has been offered regarding the components of forces, but there is still a lack of consensus on the best approach to take. The original poster expresses uncertainty and seeks additional explanations.
The original poster references a previous method used by their professor, which may not directly apply to their current problem. There is an indication of differing interpretations regarding the components of forces in this specific scenario.
Bensky
Block inside a spinning cone -- Newton's 2nd Law problem
See attempt at solution. I have attached everything there.
F_net = m * a_n (net force)
W = mg (weight)
a_n = 4*pi^2 * R * f^2 ... formula for "normal" component of acceleration where R = radius, f = rotating frequency
Some questions I have about this problem (look at my work below first or these might not make any sense) --
1. Why is there only a vertical component for the weight? I thought weight always has 2 components whenever an object is on an "incline" which it appears to be here. Does this have something to do with the motion being circular?
2. Why does the normal force have two components if the weight does not? (Ncos(theta) and Nsin(theta))? And further, when exactly do you calculate the normal force or weight using components and when do you not? For example I know on all the incline plane problems I've done, the weight always has two components but normal force is just calculated as N - not using NSin(theta) or NCos(theta).
Basically, in my attempt below, I was just following the method my professor used to solve a similar problem (only difference was his problem had a sphere instead of a block and there was no friction) and I don't really understand why he calculated two above quantities the way he did. I did not get the correct answer so I'm trying to figure this out and having a hard time.
So here's my work:
Friction acts down the slope - this is where you messed up. That means
N sin(theta) + (mu)*N*cos(theta) = m*a
along the radius of the circular path.
Regarding weight's components . Components always along different directions regardless whether the body's on flat ground or a slope. Here your analysis is along the direction of gravity and normal to it - so there is no m*g in one eqn. and complete m*g in other. By the same token normal force has two components as it has some magnitude along both axes we analyse. Remember components are made for our convenience - it isn't that they actually exist uniquely. If I had chosen to analyse along different axes - say one down the plane and other perpendicular to it (which in fact I had) I would have had components of weight and not of the normal force.
I sort of understand your explanation. I'll have to read over it again, but thanks.
Btw - If I use N*sin(theta) + mu * N * cos(theta) I get frequency to be equal to .788, which is still not correct.
Here is a picture of the updated work:
You should also have a component of the friction in the y-plane.
Thank you, I don't know why I didn't see that. I now have the correct answer.
I'm still a little shaky on when you use components for certain things even after reading over aim's explanation again. Could someone else try explaining this in a different way if possible?
In this particular problem, we have the object accelerating towards the centre. It implies that the net force is towards the centre. If we were to separate the forces into components, one of which is in the direction of the net force, it would be more convenient, because one of them will yield a zero, the other will just be the net force. In this case, [tex]F_{y}=0 , F_{x}=ma_{c}[/tex]
Hope it helps.
  • · Replies 42 ·
