Physical observables determined by quantum numbers: n, l, ml, ms
The discussion focuses on the physical observables determined by the quantum numbers n, l, ml, and ms in the context of a hydrogen atom. The principal quantum number n defines the energy state of the atom, while the azimuthal quantum number l relates to the orbital angular momentum, determining the angular momentum state. The magnetic quantum number ml is associated with the angular momentum's orientation, and ms pertains to the electron's spin, indicating that spin +1/2 does not inherently result in higher energy without an external magnetic field. The hydrogen atom is considered in a simultaneous eigenstate of the operators &hat;H, &hat;L², &hat;Lz, and &hat;Sz.
  • Understanding of quantum mechanics principles
  • Familiarity with quantum numbers and their significance
  • Knowledge of operators in quantum mechanics, specifically &hat;H, &hat;L², &hat;Lz, and &hat;Sz
  • Basic grasp of eigenstates and eigenvalues in quantum systems
  • Study the implications of quantum numbers on atomic structure
  • Learn about the role of external magnetic fields in quantum mechanics
  • Explore the concept of degeneracy in quantum states
  • Investigate the mathematical formulation of quantum operators and their eigenvalues
Students of quantum mechanics, physicists specializing in atomic theory, and educators seeking to enhance their understanding of quantum numbers and their physical implications in atomic systems.
indie452
exam practise question:
what are the physical observables determined by the quantum numbers n, l, ml and ms of the electron in a hydrogen atom.
most places just give the equation or the name not the physical observable determined.
so is this right?:-
n = principal number determines the energy state that th atom is in
l = azimuthal number i know is to do with the orbital angular momentum, does this determine the angular momentum state?
ml = magnetic quantum number associated with angular momentum
ms = magnetic quantum number associated with spin and if we have spin +1/2 then the electron will have a higher energy then if it was -1/2
and that's all i know.
any help would be great.
This considers that the hydrogen atom is in a simultaneous eigenstate of operators ##\hat{H}##, ##\hat{L}^2##, ##\hat{L}_z## and ##\hat{S}_z##.
  • ##n## is the principle quantum number and is related to the eigenvalue of ##\hat{H}##, as ##E_n = - \frac{ m_e e^4}{2 ( 4 \pi \epsilon_0)^2 \hbar^2 } \frac{1}{n^2} ##.
  • ##l## is the (orbital) angular momentum quantum number, as the eigenvalue of ##\hat{L}^2## is ##\sqrt{l (l+1)} \hbar##. For a given ##n##, the possible (integer) values are ##0 \leq l < n##.
  • ##m_l## is the (orbital) angular momentum magnetic quantum number and comes from the eigenvalue of ##\hat{L}_z##, which is ##m_l \hbar##. It is an integer ##-l \leq m_l \leq l##.
  • ##m_s## is the spin magnetic quantum number and comes from the eigenvalue of ##\hat{S}_z##, which is ##m_s \hbar##, with values ##m_s = \pm 1/2##.
No. In the absence of an external (magnetic) field, there is no preferred direction for spin and the eigenstates are degenerate.
  • · Replies 16 ·
