Falling Objects: Calculating Climbers' Force of Impact
  • Thread starter Thread starter JBP
    Falling
The discussion focuses on creating a simulator in Excel to calculate the forces involved in a climber's fall, specifically addressing the need for formulas related to the dynamics of climbing ropes. Key variables include rope length, fall factor, rope dynamics, and climber weight. Participants highlight the importance of Young's modulus and the spring constant of the rope to accurately model the forces at play. The conversation emphasizes the need for precise calculations to ensure safety during climbing falls. Understanding these physical properties is crucial for developing an effective simulation.
JBP
Hi there,
I've spent some hours on trying to make a simulator (in Excel) for calculating the forces involved in a climbers fall.
I've found the following link (http://toad.stack.nl/~stilgar/calc.php ) but can't figure it out - Maybe because my grades back in high-school were terrible :rolleyes:
Could anyone please help me making the formulas?
The following variables will be available:
- Lenght of rope (in meters)
- Fall factor / Height of fall
- Dynamics of rope (in percent @ 80kg)
- Weight of climber (in kg)
Thanks in advance
JBP said:
Hi there,
Thanks in advance
You weren't clear as to what you were asking. I assume that you're asking what force a rope would exert on a person when the person, who has the rope tied around his waist falls and is prevented from falling all the way to the ground by the rope. That force is F = dp/dt where p is the momentum of the person who is falling and dt is the time inteval during which the person's momenum changes by the amount dp. I also don't know what you mean by "Dynamics of rope (in percent @ 80kg)". you need to know the properties of the rope such as Young's modulus for the rope.
Pete
Pete
Hi Pete,
When I look at Your answer I can see that what I'm missing is the Young's modulus for the rope.
So let's start with that. I've found this formula:
E = (L*F)/(l*A)
E: Young's Modulus
L: Length of the rope
l: Change in lenght
F: Force
A: Area of the rope
I don´t know what units to use, please correct me in this example:
L = 100 meters
l = 7 meters (dynamics = 7%)
F = 784,8 Newtons (80 kg x 9.81)
A = 314,29 mm^2 (10mm x 10mm x pi)
E = 35,67 (100*784,8 / 7*314,29)
doesnt the rope act as a spring, it decelerates the faller. Dont you need the ropes spring coefficient?
Nenad,
I see Your point - do You know how to find/calculate the spring effect?
well, you need to know the spring constant (k). This is in N/m. Then you can use the equation E = 1/2kx^2, where k is the spring constant, and x is the amount of strech from the resting possition of the rope. The force exerted on the object being stopped by the rope would be F = -kx. You can play around with there equations and find the right constant so the g-force on the person is not too high.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
