OmCheeto
- 3,615
The motor is a 1 hp 12vdc permanent magnet type which I mated up with a 1.5 hp lower unit. It was done purely as an experiment to collect data. I've never had a 1 hp gas motor so I can't really compare the two. I can only tell you that overdriving the motor with 24vdc pushed me along at 3.57 mph, and overheated the motor to an estimated 400'F. Ouch. Lessons learned: Install a thermometer. Motor is too small for my needs. Cost of fuel for the 30 minute, 1.7 mile round trip would have been 8 cents, had the panels not been the original source of energy. Cost with my 40hp ICE would have been about 1/4 gallon of gasoline, but would have taken only 3 minutes. The batteries were not matched. About an hour after the test, one of the batteries voltage indicated that it was nearly 70% charged. The other was dead. I already knew the batteries should be matched, but was surprised at the difference.mheslep said:Om - Did you build the motor yourself? Conversion? If so I'm interested in a similar DIY project and am wondering how well the HP rating on the piston engine matches w/ the HP rating on the electric motor in regards to actual boat speed.
But the point of my post was not that either vehicle could be directly driven by the panels, only that they are a non-fossil fuel source of energy. The automobile had lost the serpentine belt tensioner that drove the alternator. The panels only replaced the alternator to drive the 13 miles home such that repairs could be made. (I was actually surprised that it worked.)
The boat mod was inspired by Myles Twete's "http://www.evalbum.com/492"". Which is actually moored where my electric boat experiment took place.
(Ooops. I see I'm https://www.physicsforums.com/showpost.php?p=1948388&postcount=27". Senility Now!)
Yes. It took me a while to clean up all the drool when you posted that the other day.Edit: also - since LiIon is getting pretty cheap in some places, you might look at upgrading those lead acid bricks.
https://www.physicsforums.com/showpost.php?p=2513502&postcount=199
But that motors days as a boat pusher are over. It's now mated to an old alternator doing new experiments.
I'm also considering pulling the gas engines off of my lawnmower and rototiller and putting in quick disconnects such that the motor can be swapped between the two. Thus eliminating two more gas guzzlers, and putting my usually idling panels to work. In the summer that is. I hate these stinking tree hugging neighbors of mine...
Though I've 4 firs over 100 ft tall on my plot, so I'm sure my neighbors to the north say the same thing about me.
