Bypass current of parallel conected inductor/diode
  • Context: Graduate
  • Thread starter Thread starter hsinhui
    Current Parallel
The discussion focuses on the calculation of bypass diode current in a superconducting coil circuit involving an inductor (L) and a resistor (R). The user presents equations for coil current in both scenarios: without a bypass diode and with one connected, highlighting a discrepancy in energy conservation when the bypass diode is utilized. The stored energy of the inductor, calculated at 1.25MJ, cannot be dissipated instantaneously, indicating a flaw in the user's model. The response clarifies that the resistor acts as a dump resistor, essential for energy dissipation during a quench.
  • Understanding of superconducting coils and their behavior in persistent mode.
  • Familiarity with circuit analysis involving inductors and resistors.
  • Knowledge of energy conservation principles in electrical circuits.
  • Experience with mathematical modeling of electrical systems.
  • Research the role of dump resistors in superconducting coil applications.
  • Learn about energy dissipation methods in inductive circuits.
  • Study the effects of diode characteristics on circuit behavior in superconducting systems.
  • Explore advanced simulation tools for modeling superconducting circuits.
Electrical engineers, physicists, and researchers working with superconducting technologies, particularly those involved in energy management and circuit design.
hsinhui
Hello, good day!
I am stuck on the bypass diode current calculation on superconducting coil
The connection is as following.
->------Inductor(L)---Resistor(R)------>-
-->------Bypass Diode---->----
The resistor R is the increasing quenched zone resistance.
The inductor L is the superconducting coil self-inductance.
If there is no bypass diode and coil is in persistent mode.
L*(di/dt)+i*R=0, i:coil current, t: time
i=i0*exp(-Rt/L), i0: coil initial current @t=0
But if the bypass diode is connected.
L*(di/dt)+i*R=VD, VD: diode voltage
i=i0*exp(-Rt/L)*(exp(Rt/L)-1)*(VD/R)
I simulated the coil current with the equation above.
The coil current is bypassed to diode instantly.
But this scenario is not true for the energy conservation.
The inductor stored energy (1.25MJ) can not be consumed so fast.
I miss something in my model.
If anybody can help me to figure out what happens?
Thanks a lot!
Right. Your resistor is the dump resistor if the magnet quenches and "dump resistor" might be something like drums of water connected by a steel bar to dissipate the energy. It is true for energy conservation because the dump resistor is where the energy is dissipated.
  • · Replies 22 ·
  • · Replies 20 ·
