Lightest Fissile Element/Isotope/Nuclide?
  • Thread starter Thread starter sanman
The discussion centers on identifying the lightest element, isotope, or nuclide that could be used in a nuclear fission reactor for energy production. Participants explore theoretical and practical aspects of fission reactions, including the feasibility of using lighter nuclides than those currently employed in reactors.
  • Some participants propose that uranium-233 is the lightest isotope that has been used in controlled fission reactions, while others question the limitations of isotopes below uranium in sustaining fission.
  • Concerns are raised about the fission cross sections of lighter nuclides, with a participant suggesting that compression could enable a nuclide slightly below U-233 to sustain a fission reaction.
  • Another participant argues that while compression increases atomic density, it does not affect the microscopic cross-section, which is an inherent property of the nucleus.
  • Some participants discuss the potential for using a neutron seed to initiate fission in compressed materials, questioning whether this could lead to a sustained chain reaction.
  • There is mention of thorium and its ability to undergo fission with an external spallation source, with participants debating whether increased density through compression could similarly enhance neutron flux for fission.
  • One participant highlights that the total cross section of U-238 is higher than its fission cross section, suggesting that this may prevent achieving critical mass.
  • Discussions also touch on the practicality of achieving sustained fission reactions through methods like implosions or other compression techniques.
Participants express differing views on the feasibility of using lighter nuclides for fission, with no consensus reached on whether compression or neutron seeding could enable sustained fission reactions in these materials.
Participants note limitations related to the inherent properties of nuclei, the nature of neutron interactions, and the challenges of achieving a controlled and sustained fission reaction with lighter elements.
sanman
So I'd like to know - what is the lightest element/isotope/nuclide that could be feasibly/practically used in a nuclear fission reactor for energy production?
Has any research been done into this?
What is the lightest element that's actually been used in a controlled sustained fission reaction?
uranium-233 is the lowest that can and has been/is used. The isotopes of elements below uranium has very small fission cross sections.
And yet there are nuclides below that weight which are unstable, and have a high rate of decay. Why would a nuclide slightly below U-233 be unable to sustain a fission reaction, if it was compressed to suitably high density?
If U-238 can undergo an explosive chain reaction when compressed to supercritical density, then why can't a nuclide slightly below it even sustain a fission chain reaction if sufficiently compressed? Why would the nuclear cross-section be so much lower in that case, that a chain reaction would not be possible even under heavy compression?
By compressing to a suitably high density, does one mean compressing as in an implosion?
Compression does not affect the microscopic cross-section. That is an inherent property of the nucleus. The compression causes an increase in density, and the affects the macroscopic cross-section, which is proportional to the atomic density of the material.
In fact, U-238 fission more readily by fast neutrons, not thermal neutrons, and uranium fissile systems are enriched in U-235, which is more readily fissionable by thermal neutrons, as is U-233 and Pu-239.
The less heavy elements between Bi and Pa prefer to decay by beta or alpha emisson, rather than fission.
But even by increasing the bulk density, we are increasing the probability density of the neutrons traveling through that same space. And for a given nuclear cross-sectional area, more neutrons per unit space means more likelihood of collisions.
Furthermore, couldn't we provide some kind of seed trigger, by some initial dose of neutrons, to get more fissions happening? If that is timed with the implosion to achieve a sufficiently high density, then why can't we tilt the odds in favor of a chain reaction?
One could provide a seed of neutrons or neutron source, but that is not the issue.
The issue is that increased atomic density doesn't increase the number of neutrons, on the probability that any neutron in the material will react with a nucleus before it escapes.
Implosion are short term transients. The imploded material pushes back as it heats, and expands as applied pressure decreases.
Finally, even if neutrons are absorbed, the absorbing nuclei are more likely to undergo an (n, gamma) reaction in which the A+1 radionuclide de-excites by gamma emission, and does not undergo fission if it is a non-fissile nuclide.
Implosions could be repeated cyclically. The point is to get out more energy than you put in, just like with a piston engine.
Or even without implosions, it might be possible to compress a material very densely:
http://www.sciencedaily.com/releases/2008/03/080320095005.htm
(I also want to discuss this linked article in connection with muon-catalyzed fusion, but I'll do that in a separate thread)
Anyway, so suppose some nuclide not far below uranium could be suitably compressed and kept at high density for a sustained period. Then, regarding whether or not that nuclide would tend to absorb neutrons vs fissioning, would be determined by the stability of that nuclide. So just pick a nuclide that's suitably unstable, and therefore it would be more likely to break than to stay together while de-exciting by gamma-emission.
I can be wrong, but I think that the reason that you cannot make a critical mass (Astronuc referred to this) with pure U-238 is the following. The total cross section is higher by a factor of about 5 above the fission cross section in the 1MeV region (where it is in fact the closest). This factor is bigger than the average number of neutrons produced in a fission reaction. As such, with the number of neutrons produced in a fission, you will never produce 1 new fission or more.
In the attachment, the blue curve is the fission cross section while the red one is the total cross section (data from the sigma application on http://www.nndc.bnl.gov/ ).
And yet there are some materials such as Thorium, which are known to be able to undergo fission under a spallation source. They are thus subcritical reaction materials, only able to exhibit a fission reaction with the aid of the external spallator. But that spallation source is then not increasing Thorium's nuclear cross-section, but again only simply increasing the neutron flux in the material.
So for a material like Thorium then, couldn't a similar increase in neutron flux be achieved by increasing the density of the material through compression?
Even if we're only talking about a brief compression, like an implosion, could it not then achieve a sustained fission chain reaction for that brief duration?
Or if there was some way to apply a sustained high compression, such as with the buckyball confinement example I gave, then could this not improve the neutron flux enough for a sustained chain reaction?
A spallation source is an external neutron source which has to added to the thorium to get a neutron flux. Thorium fueled reactors need U-233 or U-235, but the Th-232 does capture an neutron becoming Th-233 which eventually transforms to Pa-233 which transforms to U-233, and thus one can do a thermal breeder reactor as opposed to a fast breeder.
The point of accelerator driven systems is that they put a lot of energy in from the outside, as opposed to within the fissile system, and IIRC the point is to make them subcritical.
If one had a mass of Thorium surrounding a neutron source, e.g. highly enriched fissile kernel, the an implosion might work, but the reaction is very brief, i.e. explosively so, and that is not a practical energy source. The idea of a chain reaction is a sustained and well-controlled 'steady-state' process - not a pulsed detonation.
One still needs a substantial mass of fissile material to maintain a steady and well-controlled chain reaction, and the buckyballs would be destroyed by the fissions.
Well, the idea of burning a candle is a steady combustion. But the idea of a piston engine is a pulsed combustion. Both can be harnessed for useful purposes.
It's possible to imagine a cyclical pulsed process, which briefly achieves high compression, over and over again.
Perhaps there could be some kind of moderator material in between the buckyballs and the thorium inside them.
Or alternatively instead, the buckyballs could be continuously "healed"/repaired by electromigration under strong electrical current. Or perhaps some other high-temperature carbonaceous/hydrocarbon material could be flowing around the buckyballs' exterior.
Buckyballs can themselves be formed from a feedstock of ethylene gas at high temperature, can they not?
Try - piston combustion engines work on a cycle detonation process - but they are relatively small scale - and more importantly - they don't produce fission products!
What is the size and structure of a buckyball? Then think about what a 50-80 MeV atom (fission product) would to do the atoms in a buckyball. A strong electric current in a large reactor is going to use a lot of energy, and I'm quite sure it won't do much to repair buckyballs in a high radiation environment.
Every material with a fission cross section can undergo fission (of course) ; the point is that to get any hope of having a net generation of energy, you need a serious amplification of the neutron flux (that is, the neutron flux in the core needs to be a serious factor (say, 20) higher than the incoming neutron flux from the accelerator/spallation. In a normal nuclear reactor, this "amplification factor" is infinite (it is a self-sustained chain reaction), while in a sub-critical reactor, this amplification factor is finite. In a critical reactor, the "k-factor" is 1, while in a subcritical reactor, this is slightly less than one (say, 0.95 for an amplification of 20). But you still need a k-factor very close to 1. And *that* is something that can only be achieved with certain materials.
Now, the k-factor is obtained by considering how many fissions are obtained by the neutrons released by one single fission (you understand that if, for each fission, we cause another fission (k=1), then the reaction is self-sustaining). In the calculation of k, one finds of course:
- the average number of neutrons produced by a fission (A)
- how many of them get lost by other processes, like capture, before causing fission (B)
- how many of them get lost by "geometry" (C).
A is a property of the fission process (and is slightly dependent on the spectrum of the neutrons) ; B is given by the RATIOS of the cross sections and the mixture of different elements. C is given by the size and the density of the material.
Now, if you consider an INFINITE amount of material, then nothing gets geometrically lost, and we have k-infinite. For a specific setup, we have k = k-infinite x g where g is a geometry factor between 0 and 1. If one compresses a material, then one brings g closer to 1. It is the trick one uses in an implosion atomic bomb: k-infinite is of the order of 2, and the g of the non-compressed material is less than 0.5, while the g of the compressed material is close to 0.8, so the k-factor goes from less than 1 (subcritical) to more than 1.6 or bigger (fast divergence).
But if k-infinite is less than 1, no compression can ever achieve criticality.
Nope, because for thorium, the k-infinite is less than 1.
You are confusing unstable with fissile. All elements heavier than bismuth are unstable and decay with varying propensity thru alpha or beta emissions. A number of nuclides are fissionable in that they will fission when struck by a neutron. But only four isotopes are fissile such that they have a high probalility of fissioning when a neutron is absorbed. These are U233, U235, Pu239 and Pu241. All other fissile isotopes are almost impossible to make in weighable amounts or have too short of a half-life to be accumulated as fuel. Thorium has only one naturally occurring isotope Th232 and it is NOT fissile. It's fission crossection is half a billion times smaller than U235.
Compressing (bringing nuclei closer together) has absolutely no effect on the fissile propensity of the nuclei. It simply makes it less likely for neutrons to escape the mass. But, if the material is not fissile, no amount of compression will make it so and it will not sustain a chain reaction.
Only U233, U235, Pu239, and Pu241 are useful for sustained (or pulsed) fission chains. Th232 can be used to breed fissionable U233 in an operating reactor that has already been fueled with sufficiently enriched fissile fuel.
U238 is fissionable (not fissile) with 14 Mev neutrons from fussion reactions but that is not a fission chain reaction.
To add to what the others have said:
The problem with other isotopes isn't that they can't fission, it is that they can't form chain-reactions. Yes, thorium has a small fission cross-section, however it has a much larger absorption cross-section. This means that when a neutron is absorbed, the most likely reaction is capture (ie (n,gamma) ) without releasing other neutrons to continue the reaction. For the isotopes mentioned above, the probability that it will fission producing multiple neutrons is high enough to over come those neutrons lost by capture.
Increasing the density decreases the probability a neutron will not react, but doesn't change the ratio of fission to capture. Most isotopes simply will not support a chain reaction.
There are many other isotopes that can support chain reactions, however they are not of practical significant because they are generally formed in such small quantities.For example, Am-242m.
  • · Replies 36 ·
9K
9K
  • · Replies 16 ·
  • · Replies 0 ·
