Optimizing CO2 Flow in an IR Curing Oven: A Technical Analysis
  • Thread starter Thread starter sciencegen
    Co2 Ir
The discussion focuses on optimizing CO2 flow in a 4ft IR-curing oven using a McMaster Carr 5191K27 air knife. The air knife, operating at 80 psi, amplifies air by 30:1 and injects gases at 40.8 CFM. To achieve a CO2 concentration of 0.5% in the oven, the input PSI to the air knife needs to be calculated based on the existing natural CO2 level of 0.387%. Accurate results require testing on the actual system, as the air knife's performance is influenced by pressure and geometry.
  • Understanding of gas flow dynamics in industrial ovens
  • Familiarity with air knife technology and its amplification effects
  • Knowledge of CO2 concentration measurement techniques
  • Basic principles of fluid dynamics and pressure calculations
  • Research the impact of air knife geometry on gas flow performance
  • Learn about CO2 concentration measurement methods in industrial applications
  • Investigate the effects of varying PSI inputs on air knife output
  • Explore fluid dynamics principles relevant to gas mixing in confined spaces
Manufacturing engineers, process optimization specialists, and anyone involved in the design and operation of curing systems seeking to enhance gas flow and concentration accuracy.
sciencegen
Hello all!
I'm a sales rep here at << company name removed by moderator>>, we manufacture conformal coating/curing systems. Normally, i'd just ask one of our engineers this question, but production as been shut down for the week as we move to a new facility, so I am out of contact.
A customer just asked me this question about his system.
The customer has one of our 4ft IR-curing ovens. Basically, its a long rectangular box with a conveyor running through it with two open ends.
On top of the conveyor, we have a 12 inch air knife (McMaster Carr 5191K27) that allows for the injection of in this case 100% CO2 into the oven. The air knife amplifies incoming air by 30:1 and @80psi injects gases at 40.8CFM (3.4 SCFM/inch)
On the conveyor we have a 300CFM exhaust blower that pulls plain air through the side holes, allowing air to flow over the product, and then out a vent hole in the bottom.
So...the customer asked me what PSI the input to the Air Knife should be to create a flow of through the oven (from the current provided by the exhaust) that contains 0.5% CO2.
Now, I know the naturally occurring amount of CO2 that would be flowing naturally is 0.387% (i think).
So the other .4613% CO2 has to come from the air knife i would think...i just don't know at what PSI input to the air knife would allow an CFM output from it that would mix with the flowing air from the exhaust that would create a .5% CO2 flow.
Any help/answer/advice would be greatly appreciated!
That is not a simple question. The easiest and most accurate way would be to test it on the actual apparatus in question and test samples of the resulting mixture. I wouldn't expect that anyone here would be capable of giving you an answer without spending a significant time on analysis of the whole geometry and technical specifications of the product.
The reason for this is the amplification effect of the air knife would be very dependent on the pressure and geometry of the device in question. You will need to talk to one of the companies engineers who have likely already done this type of analysis.
