Question on deformations of members under axial loading
  • Thread starter Thread starter jeash
    Axial Members
The discussion centers on the deformation of a 250-mm long aluminum tube under axial loading, specifically when a solid brass rod is inserted. The aluminum tube has an outer diameter of 36mm and an inner diameter of 28mm, while the brass rod has a diameter of 25mm. The total deformation of the system is calculated to be 3.75E-4 mm, derived from the pitch of the threaded screw cover. The confusion arises from the expectation that the outer tube's tension and the inner rod's compression would result in a difference in deformation, contrary to the professor's assertion that the total deformation is the sum of both components.
  • Understanding of axial loading and deformation principles
  • Familiarity with material properties of aluminum and brass
  • Knowledge of threaded screw mechanics and pitch calculations
  • Ability to perform basic elongation calculations for cylindrical objects
  • Study the mechanics of materials, focusing on axial loading and deformation
  • Learn about the properties of aluminum and brass, including Young's modulus
  • Research threaded fasteners and their mechanical advantages
  • Explore advanced deformation analysis techniques, such as finite element analysis (FEA)
Mechanical engineers, materials scientists, and students studying mechanics of materials who are interested in understanding deformation under axial loads and threaded connections.
jeash
N/A
A 250-mm long aluminum tube of 36mm outer diameter and 28mm inner diameter may be closed at both ends by means of single threaded screw on covers of 1.5mm pitch. With one cover screwed on tight, a solid brass rod of 25mm diameter is placed inside the tube and the second cover is screwed on. Since the rod is slightly longer than the tube it is observed that the cover must be forced against the rod by rotating it one-quarter turn before it can be tightly closed. Determine the deformation of the rod and of the tube.
I have no problem calculating the elongations of each part, but wonder in the end why they add up to 3.75E-4 (the total deformation of the system as found from the threaded screw) when I thought the outer tube is in tension and the inner rod is in compression. Wouldn't this mean the total deformation of the system would be the difference between the two values? Our professor says no, but I am confused as to why.
Any help is appreciated/if you have more info as to the solution let me know.
With other given values I calculated delta rod=0.1325mm and delta tube=0.1325, which adds up to delta total=3.75E-4 (found by multiplying .25 turn* the pitch of 1.5mm)
Can you explain your statement: "delta rod=0.1325mm and delta tube=0.1325, which adds up to delta total=3.75E-4"? The final length of both the tube and the rod is 250.1325 mm? Or not?
