Finding equation of curve from simple graph
  • Context: High School
  • Thread starter Thread starter hurliehoo
    Curve Graph
The discussion revolves around finding an equation for a symmetrical curve based on its graphical properties, specifically a maximum at y=0.5 and zeros at x=0 and x=7.5. Participants explore various mathematical approaches to derive a suitable equation, including polynomial forms and factored equations.
  • Some participants suggest that it is generally impossible to find a unique equation for a given graph, but one can construct equations that exhibit certain properties of the graph.
  • One proposed approach is to assume the curve is a parabola, leading to the form y=ax^2+bx+c, with specific conditions derived from the maximum and zeros provided.
  • Another participant argues that the equation can be expressed in a factored form y=kx(x-7.5) for some constant k, using the symmetry of the parabola and the maximum point.
  • There are discussions about the calculations for coefficients a, b, and c, with some participants expressing confusion over the rearrangement of equations and the implications of certain steps.
  • Several participants engage in correcting and refining each other's calculations, with some expressing uncertainty about the methods used and the results obtained.
  • One participant notes that using the factored form is simpler and avoids potential mistakes that arise from more complex methods.
There is no consensus on a single method or equation, as participants present multiple approaches and express differing levels of understanding and confidence in their calculations. The discussion remains unresolved regarding the best method to derive the equation.
Participants highlight potential confusion in the mathematical steps, particularly regarding the rearrangement of equations and the implications of certain values. There is also mention of the tediousness of some methods compared to others.
hurliehoo
Hi can anyone please tell me how to find an equation from a graph.
It's a fairly simple graph. A symmetrical curve with a maximum at y=0.5, and y=0 at x=0 and x=7.5 ... any suggestions appreciated!
Mathematics news on Phys.org
Generally, it is impossible to find a unique equation describing some particular graph.
What you might do, is to construct equations that show SOME of the properties of the graph.
You say you have a symmetric curve with maximum at (0,0.5) and a zero at (7.5,0).
Well, is it a parabola, perhaps? I don't know. It might as well be the graph of a fourth-order polynomial, or some other function.
If it IS the graph of a parabola, i.e, that it is a graph of a second-order polynomial, we might make some headway:
1. We have that:
[tex]y=ax^{2}+bx+c[/tex], and we are to determine a,b,c.
From your info, we have that the maximum occurs at x=0.
Since, in general, we have that the maximum will occur at [tex]x=-\frac{b}{2a}[/tex], we see that b=0 in your case.
2. The zero:
We know this occurs at x=7.5, therefore we have, using the info in (1):
[tex]0=a*7.5^{2}+c\to{c}=-a*7.5^{2}[/tex]
3. Preliminary expression:
We now have that:
[tex]y=a*(x^{2}-7.5^{2})[/tex]
4. Value at maximum:
We have that at x=0, y=0.5, we therefore get:
[tex]0.5=-a*7.5^{2}\to{a}=-\frac{0.5}{7.5^{2}}[/tex]
5. Final expression
We have now strictly determined how a second-order polynomial that fullfills all the given info looks like, namely, for example:
[tex]y=-\frac{1}{112.5}(x-7.5)(x+7.5)[/tex]
arildno you've misread the info. Assuming it's a parabola, it's given that the zeroes are x=0 and x=7.5 and the maximum is at y=0.5
So far we can conclude it will be of the form y=kx(x-7.5) for some constant k. Since y=0.5 is a maximum and this occurs when x is in between the roots 0 and 7.5 - because parabola's are symmetric about their turning point, we can substitute in x=3.75 and y=0.5 to find k.
1. We have that:
2. The zero:
We now have that:
5. Final expression
Sorry I didn't make it clear the midpoint maximum for this symmetrical curve is at (3.75, 0.5).
Yes it's a parabola though, and your answer is very helpful so thank you very much indeed!
Oh, you are right! Me being overhasty, contradicting my entish motto..
Anyhow, it seems that the OP has gotten the gist of the idea..
Sorry I'm having another look at this and I'm not so sure I understand it now. Some questions about the method ...
What does the arrow signify ?
How can 0.5 = -0.5/7.5^2 ?
The arrow is just like another line, you're re-arranging the equation.
So rather than
[tex]x+2=5[/tex]
[tex]x=3[/tex]
We instead have
[tex]x+2=5 \rightarrow x=3[/tex]
It's not, take a look at the arrow :smile:
Ok in that case I am definitely doing something wrong here. Using my understanding of the above method :
1--> max occurs at (3.75, 0.5). Therefore if x = -b / 2a then b = -7.5a
2--> 0 = (7.5^2)a - 7.5a + c therefore c = 7.5a - (7.5^2)a
3--> y = a((x^2) - (7.5^2) + 7.5)
4--> 0.5 = a((3.75^2) - (7.5^2) + 7.5)
so a = -.0144
and I can then get b and c from there, however this seems to be completely wrong.
What's this line? Particularly, what is the a in front doing there?
The equation is [tex]y=ax^2+bx+c[/tex]
and you've already found that
[tex]b=-7.5a[/tex]
and
[tex]c=7.5a - (7.5^2)a[/tex]
[tex]c=7.5(1-7.5)a[/tex]
[tex]c=7.5(-6.5)a[/tex]
[tex]c=-48.75a[/tex]
So now, knowing that the point (3.75,0.5) satisfies the equation, plug this into the general form of the equation and use these values of b and c to find a.
[tex]0.5=a(3.75^2)-7.5a(3.75)-48.75a[/tex]
You would then solve to find a, then use another point like (0,0) to find c (which would be 0) and then find b with (7.5,0).
This is a pretty tedious method though. You already know that the parabola cuts the x-axis at 0 and 7.5 so you should instantly turn it into a factored parabola of the form [tex]y=kx(x-7.5)[/tex] for some constant value k, which you can easily find by plugging in the other known point (3.75,0.5).
Note that plugging in (0,0) or (7.5,0) won't work because then you end up with 0=0 and that doesn't help find the value of k.
[tex]b=-7.5a[/tex]
and
Regarding my first working, which I posted, of the first (agreed tedious) method I forgot to include the x for b (duh), however the next time I tried I got a similar working to yours ... this didn't work due though, I think because c=-48.75a makes it non-zero. So even when c=0, which it has to for the other two coordinates, I got y = -0.00796x^2 + 0.0597x, which when plugging in x=3.75 gives y=0.11194 instead of 0.5
Anyway ... your second method was infinitely simpler and does indeed work very well. Thanks!
Oh yes that's right, I totally missed that part too!
We found that b=-7.5a and used the point (7.5,0)
[tex]0=a(7.5)^2+(-7.5a)(7.5)+c[/tex]
[tex]c=0[/tex]
We screwed up the bx part, we substituted b=-7.5a but forgot about the x=7.5 haha ^^
Yeah, better if you stick to the simpler method... saves you easily making an inevitable mistake like we both did :wink:
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 22 ·
