Solve Cos(x)=-2: Step-by-Step Guide
  • Thread starter Thread starter GreenPrint
The discussion revolves around the equation cos(x) = -2, exploring its implications within the context of complex numbers versus real numbers. Participants are examining the validity of solutions derived from complex analysis and the definitions of trigonometric functions in different domains.
  • The original poster attempts to solve cos(x) = -2 using complex exponential forms and quadratic equations, questioning the validity of their approach. Some participants clarify that cos(x) is typically defined within the range of [-1, 1] for real numbers, while others suggest that solutions exist in the complex domain.
Participants are actively engaging with the original poster's reasoning, with some agreeing that the exploration of cos(x) in the complex plane is valid. There is a recognition of the multi-valued nature of logarithms in complex analysis, and discussions are ongoing regarding how to express solutions appropriately.
There is uncertainty about whether the problem should be approached strictly within the real number system or if complex solutions are acceptable. Participants note that the original poster has not been explicitly instructed to limit their work to real numbers, leading to a broader exploration of the topic.
GreenPrint
I was trying to solve that problem ignoring what people say about it not being defined and got a number strangely. I showed step by step so you can tell me what I did wrong as I don't think I did anything wrong what so ever.
In work below
e^(ix) = cosx + i sinx = cisx
e^(-ix) = cosx - i sinx = cis(-x)
cis(x) + cis(-x) = cosx + i sin x + cosx - i sinx = 2cosx
from which
cosx = (cis(x) + cis(-x) )/2
from which I set it equal to -2 and began to solve
cosx = (cis(x) + cis(-x) )/2 = -2
Multipled by 2 on both sides
cis(x) + cis(-x) ) = -4
Multipled by cisx on both sides
cis^2(x) + 1 = -4cis(x)
set equal to zero by adding -4cis(x) to both sides
cis^2(x) + 4cis(x) + 1 = 0
solved the quadratic for cis(x)
(-4 +/- sqrt(4^2-4(1)))/2
= -2 +/- sqrt(16 - 4)/2
= -2 +/- sqrt(12)/2
= -2 +/- (2sqrt(3))/2
= -2 +/- sqrt(3)
cis(x) = -2 +/- sqrt(3) = e^(ix)
solved for x took natural log of both sides
ln(-2 +/- sqrt(3)) = ln( e^(ix) )
took out exponents and used ln(e) = 1
ln(-2 +/- sqrt(3)) = ix
divided through by i
ln(-2 +/- sqrt(3)) /i = x
simpified for +/-
for +
ln(-2 + sqrt(3)) /i = x
for -
ln(-2 - sqrt(3)) /i
factored out negative one
ln(-(2 + sqrt(3))/i
used the fact that ln(xy) = lnx + lny
( ln(-1) + ln(2 + sqrt(3)) )/i
used the fact that ln(-1) = i pi
( i pi + ln(2 + sqrt(3)) )/i
canceled out the i
pi + ln((2 + sqrt(3)) )/i = x
(Post removed. Completely misunderstood the question.)
I wouldn't say you did anything wrong, rather, you are talking about a different function.
People who tell you that cos(x) = -2 has no solution, are talking about the function from [0, 2pi] to [-1, 1] and then they are right.
If you consider the function defined from C to C (in general) by 1/2(cis(x) + cis(-x)) then you will indeed obtain the answer you got.
[edit] Actually I can kinda agree with you. The definition of the exponential on the complex plane can be rigorously given (in several ways, just avoid the one with sin(x) and cos(x) of course :D) and then defining cos(x) and sin(x) as being the restrictions of (exp(ix) +/- exp(-ix))/2 to the real number is rather reasonable.
Actually I don't know I just have been told... so I treid it for myself and got a number... so therefore it does exist no?
What do you mean from C to C what is C?
C = set of complex numbers
Hi GreenPrint! :smile:
(have a pi: π and a square-root: √ and try using the X2 icon just above the Reply box :wink:)
Starting with your final answer, which is cos(π + ln(2 + √3)/i),
(and since cos(-A) = cosA, and we can always add any whole multiple of 2π, and since1/i = -i, the general solution would be: cos((2n+1)π ± i ln(2 + √3)),
we can immediately use cos(π + A) = cosπcosA - sinπsinA = -cosA, to get:
[STRIKE]cos(i ln(2 + √3)),[/STRIKE]
-cos(-i ln(2 + √3)).
ok, let's check that answer, using cosx = (eix + e-ix)/2:
[STRIKE]cos(i ln(2 + √3)) = (e-ln(2 + √3) + eln(2 + √3))/2
= (1/(2 + √3) + (2 + √3))/2 = ((2 - √3) + (2 + √3))/2 = 2.
hmm :confused: … something seems to have gone wrong. :redface:[/STRIKE]
-cos(i ln(2 + √3)) = -(e-ln(2 + √3) + eln(2 + √3))/2
= -(1/(2 + √3) + (2 + √3))/2 = -((2 - √3) + (2 + √3))/2 = -2. :biggrin:
So if I'm not specifically told we are in the set of real numbers or it's not implied any where or have never been told in class that we will always be in the set of real numbers then indeed I had to solve for cosx = -2 ? So am I justified in solving for it because it's a summer assignment and so I've never been told to always assume we are in the set of real numbers so I should leave that as a solution on my paper and put "Assuming we are also in set of complex of numbers.." or something?
C means in the complex numbers. When people say it's not defined, they mean it's not defined in the real numbers. In the same way one asks where does the graph y=x2+1 and the x-axis cut each other, well, not at any real number, but it does in the complex numbers.
Now, just to get a bit picky, the log function in the complex plane is multi-valued, so the answer is actually [tex]x=2\pi n +\pi +ln(2+\sqrt{3})/i[/tex]
But you can do better than this. Can you manipulate the above to be in the form x=a+ib?
Rather than dividing by i, it's more conventional to multiply by i.
we can immediately use cos(π + A) = cosπcosA - sinπsinA = -cosA, and 1/i = -i, to get:
cos(i ln(2 + √3)),
and then since cos(-A) = cosA, and we can always add any whole multiple of 2π, the general solution would be:
cos(nπ ± i ln(2 + √3)).
hmmm let me look at that... also is that n symbol another symbol for pi or is it suppose to be pi just wounder I'd rather use n for pi then the other symbol...
cos(i ln(2 + √3)),
No no no! He had the right answer, you multiplied by i when he divided by i! :-p
Oh and it wouldn't work for n=2,4,6... rather the formula is [tex]x=\pi(2n+1)+ln(2+\sqrt{3})/i[/tex]
Sorry to be so harsh hehe
hmmm interesting your right... so just multiply threw by i? let's see...
pi i (2n + 1) + ln(2 + sqrt(3) )
I delved into the complex numbers back in high school when we were learning about quadratics. My teacher got really pissy at me :biggrin:
But ever since I would just act like a smart-xxx on my assignments and get into way more detail than required, just for the laughs. So be my guest!
Nope, what I mean is to multiple the fraction [tex]\frac{ln(2+\sqrt{3})}{i}[/tex] by i in both the numerator and denominator so nothing changes. The denominator will become a real number :wink:
well that would give i^2 in the denomenator or simply -1 and i in the numerator
-i ln(2+ sqrt(3))
don't see how that is a real number hmmm
By definition, as you previously did:
[tex] \cos(z) \equiv \frac{e^{i \, z} + e^{-i \, z}}{2}, \; z \in \mathbb{C}[/tex]
So, one can try and find the inverse function [itex]w = \arccos(z)[/itex] by solving with respect to [itex]w[/itex]:
[tex] z = \cos(w) = \frac{e^{i \, w} + e^{-i \, w}}{2}[/tex]
[tex] e^{2 \, i \, w} - 2 \, z \, e^{i \, w} + 1 = 0[/tex]
This is a quadratic equation with respect to [itex]e^{i \, w}[/itex], with a solution:
[tex] e^{i \, w} = z + (z^{2} - 1)^{1/2}[/tex]
where the square root has two branches. Taking the logarithm (an infinitely valued complex function):
[tex] w = \arccos(z) \equiv = -i \, \log{\left(z + (z^{2} - 1)^{1/2}\right)}[/tex]
ok so your also saying that
pi (2n + 1) - i ln(2 + sqrt(3) ) = - i ln (2 + sqrt(3) ) I don't see how?
I don't understand what you are trying to do here? :confused:
Hang on, let's stop at [tex]x=\pi(2n+1)-iln(2+\sqrt{3})[/tex]
This is correct, now don't change anything drastically. Just use the rules you know. This can be simplified a bit further. Use the log rule that [tex]-ln(x)=ln(x^{-1})[/tex] and then rationalize the denominator inside the log function. It's not changing the answer, just making things look a little more neat I suppose :smile:
If you use the definition, you will have:
[tex] -i \, \log{(-2 + \sqrt{3})}[/tex]
[tex] -i \, log{(-2 - \sqrt{3})}[/tex]
Then, you need the definition of the complex logarithm. It is the inverse function of the complex exponential Let [itex]z = \rho \, e^{i \, \theta}[/itex] and [itex]w = u + i \, v[/itex] and [itex]z = \exp(w)[/itex]. Using the properties of the exponential function:
[tex] \rho \, e^{i \, \theta} = e^{u} \, e^{i v}[/tex]
This means that:
[tex] \rho = e^{u} \Rightarrow u = \ln{\rho}, \; \rho > 0[/tex]
[tex] v = \theta + 2 \, n \, \pi, \; n \in \mathbb{Z}[/tex]
So, a complex logarithm is a multiple valued function (with infinite number of branches):
[tex] w = \log{z} \equiv = \ln{\rho} + i \, \left(\theta + 2 \, n \, \pi), \; z = \rho \, e^{i \, \theta}, \; \rho > 0, \; n \in \mathbb{Z}[/tex]
ok then
pi(2n + 1) + i ln(2 - sqrt(3) )
hmmm
I get a different solution with the imaginary part with the opposite sign. Also, there is another branch of the square root that you hadn't considered.
I don't understand why
pi(2n + 1) + i ln(2 - sqrt(3) ) = i ln(2 - sqrt(3) )
i get that it has branches but
pi(2(5) + 2) + i ln(2 - sqrt(3) ) does not equal i ln(2 - sqrt(3) )
If you look at my definition of the arc cosine, you will see that your right hand sides are not in accordance with it.
-i ln ( -2 + sqrt(3) )
raised to -1
i ln( (-2 + sqrt(3))^-1 )
simplified
i ln( 1/(-2 + sqrt(3)) )
Multiplied by conjerget
i ln( (-2 - sqrt(3))/( (-2 + sqrt(3))(-2 - sqrt(3)) ) )
simplify
i ln( (-2 - sqrt(3))/(4 + 2sqrt(3) - 2sqrt(3) - 3)
i ln( (-2 - sqrt(3))/(4 - 3)
i ln( (-2 - sqrt(3) )/1)
oh wow let me see here let me reread
(what happened to that π and √ i gave you? :confused:)
Mentallic was right … I got a minus in the wrong place. :redface:
I've edited my last post to correct it.
Don't SIMPLIFY anything! Just follow the formulas. Also, why don't you try clicking on some of my formulas to see what the latex code looks like. It helps a lot in terms of readability of your equations.
wow ok the thing confused there is that the value that I solved for was actually a side length and you are solving for an angle now? That's kind of werid but I made sense fo the formulas after realizing that... my only question is why didn't you use +/- and just used +
  • · Replies 105 ·
13K
