Formula Car Cooling: Benefits of Ultra Side Pods & Radiator Setup
  • Context: Automotive
  • Thread starter Thread starter Ranger Mike
    Car Cooling Formula
The discussion revolves around the cooling setup of a formula car, specifically focusing on the benefits and drawbacks of using Ultra Side Pods and different radiator plumbing configurations. Participants explore theoretical and practical aspects of cooling efficiency, air flow management, and the implications of design choices on performance.
  • Experimental/applied
  • One participant notes the switch from parallel to series radiator plumbing with an electric water pump, observing similar temperature outcomes.
  • Another participant suggests that parallel plumbing may provide better cooling capacity due to increased coolant flow, while series plumbing might be easier to install and maintain.
  • Concerns are raised about the impact of radiator flow rates on cooling efficiency, with emphasis on maintaining turbulent flow for optimal heat transfer.
  • Discussion includes the potential benefits of using insulation around the radiator core to improve air flow, though some argue that leaving it bare may enhance heat dissipation.
  • A participant mentions the splitter's role in directing air flow and questions its necessity based on common practices in their racing series.
  • One participant emphasizes the importance of understanding the specifications of the radiators and water pump before making plumbing changes, highlighting the risks of laminar flow and cavitation.
Participants express differing opinions on the advantages of series versus parallel plumbing configurations, with no consensus reached on which is definitively better. The effectiveness of insulation and the necessity of the splitter also remain points of contention.
Participants acknowledge that the effectiveness of the cooling system depends on various factors, including radiator specifications, pump performance, and flow rates, which are not fully resolved in the discussion.
Individuals interested in automotive engineering, particularly in race car design and cooling systems, may find this discussion relevant.
  • #31
Hi, Ranger. I think that an aggressive coolant flush is called for, to clean the interior surfaces of your radiators, then go back to clean water and wetting agent to maximize surface-wetting and heat transfer. You've got to flush the entire coolant system, since the glycol will have glommed onto the rough-cast surfaces in the block. You need maximum heat transfer not only at the radiators but from the block to the coolant.
Did you manage to get a couple of oil-coolers installed downstream of your oil filter? That will knock down the load on your cooling system.
  • #32
thanks turbo...am adding oil cooler before next outing and yes...i think flush is in order...wonder what i can flush to clean out all the antifreeze crap?
  • #33
if water and water wetter boil at 250 degrees F with a 15 psi radiator cap
what temp will this boil with a 18 psi radiator cap?
  • #34
You can get a flush kit from an automotive supply place. I believe that the stuff you add to your clean water after the initial flush is a caustic solution, like Drano, though it's probably buffered to prevent corrosion. You'd run that solution through the cooling system for a while, then drain and rinse several times with flushes of clean water, before filling with distilled water + wetting agent.
Ethylene glycol is very thick and slimy-feeling, and that can inhibit heat transfer both from the block to the coolant and from the coolant to the radiators.
  • #35
Oil coolers (unless with oil-air heat exchangers) won't help; in fact they'll make things worse. Oil coolers take heat from the oil (which would otherwise disspitate through the engine's surface area and exhaust) and put it to coolant, putting extra thermal load on your cooling system. An oil cooler can put anywhere between 2-20 degrees Celsius to coolant.
18psi vs 15psi, look up boiling point in a steam table. Mine's at work. I guess something in the region of 5-10 degrees Celsius.
  • #36
thanks guys,,,,this forum is priceless regarding the experience and wealth of information and sage advice. i was thinking of air finned oil cooler if i can find in line model.
i think we will be safe with the water wetter and 18 psi cap...it never boiled at 240 deg F
you guys are great,,,thanks
rm
  • #37
Air finned oil cooler would help. Check pressure drop at your required flow rate! And be careful with the uprated pressure cap; the coolant WILL be at a higher pressure as a result.
  • #38
Hey, RM, haunt the Harley-Davidson aftermarket dealers. They will carry compact air-finned oil coolers. You can hide them in your fairing behind the radiators, since even the warm air coming off the radiators is WAY cooler than the oil, and you'll cool the oil enough to take some load off the water coolant circuit. Remember that you'll want to send the oil through the oil filter first so you won't bottle-neck that filter flow with high-viscosity oil.
  • #39
For the boiling point of water vs. temperature, you can generate a chart from the NIST website.
Link to the thermophysical properties page: http://webbook.nist.gov/chemistry/fluid/
Link to a pre-made chart of what you're after, water boiling point w.r.t temp: http://webbook.nist.gov/cgi/fluid.c...nit=mph&VisUnit=uPa*s&STUnit=N/m&RefState=DEF
I attached a screenshot of the chart in case the link doesn't work. Keep in mind the pressure is absolute pressure, so you'll need to subtract 14.7 psi (1atm) to get the gauge pressure rating of a theoretical radiator cap. To put it another way, an 18psi radiator cap plus 14.7psi (atmospheric at sea level) equals 32.7psi absolute.
For a 15psi cap + 14.7psi atmospheric (29.7 absolute): Boiling point is 249.8 fahrenheit
For a 18psi cap + 14.7psi atmospheric (32.7 absolute): Boiling point is 255.4 fahrenheit
EDIT- keep in mind some antifreeze mixtures also modify the boiling point of water. The numbers above are for pure water only.
  • #40
BTW, RM, you can get screw-in converters for Harleys (maybe Jagg) that are threaded the same as the oil filter, and have a female thread for your standard oil filter to thread into. The converter features a nipple to allow you to route the oil after it goes through the filter to your oil coolers, and another nipple to route the cooled oil back to the engine. If you have enough outboard clearance at the filter location to allow this, it's a really slick conversion. The converter is a couple of inches thick and IIR, it costs only about $90. If you're lucky, they have a similar converter for your oil-cooler application.
  • #41
Thanks Mech Engineer...i think if it gets to 255 weare cooked anyway...but i go some margin to play with..
thanks turbo...i sure will check it out...good idea
rm
  • #42
Ranger Mike,
Looks like we have a $180 M track (+ over run expenses of course) coming to Austin Tx. If all goes according to plan it will complete in 2012. Will you run in a class that brings you to this track ?
I know very little about this class of racing and a quick glance at the rules of formula 1 racing makes it clear the power-train is held to very tight standards. How much room in methods of cooling is there for making changes ?
If you can get wild and crazy, I might can throw something out to you that let's the side coolers be removed completely and a method of heat removal that can be variable based on a number of different things. I think water can be replaced with some kind of refrigerant which might produce a much better thermal transfer delta and a fan design that will allow all other heat exchangers to be removed.
If rules are not too restrictive and you care to look deeper into what I'm thinking, send a PM to me. I got the impression from one post, that you might have a shop and resources to carry out the research and development should the design and numbers look right.
Who knows ?
RonL
  • #43
SCCA is sanctioning organization that we race in. about 250000 members in USA...is probably the largest part time race club in world with road course tracks all over the country. we race MID OHIO and many others in Indiana, Michigan..Kentucky is supposed to have blue grass race way but its not opened yet..my driver has won at them all .. Watkins Glen, Road America, Virginia International Raceway..and many many Mid Ohio checkers...love to trailer to Texas but will see how economy is...ref: cooling idea..heck yes..always looking for new wrinkle ..send me message and we can look over..thanks Ron L
  • #44
think i got the cooling problem fixed. plumbed radiators in series..used water wetter and distilled water. we ran it two days in 75 degree beautiful weather..it got to 95 degrees C and no hotter. i did go with red line synthetic oil which is super trick and costs $ 10 per quart...last resort was to add an oil cooler but this would add weight and there just is not a lot of room under the fiberglass body for it. we won one race, got second in last race...some new young kid ran 4 seconds quicker than us and the kid never been on the track before...hummmm, and my driver been track champion last 6 years? makes you wonder...right?
  • #45
hello everyone,
Im a student participating in Formula SAE event, i want a little help on Radiator connection on my teams, we are using 1.0L S-TEC II I4 petrol engine of Chevy Beat,as it consists of 1 radiator we want two radiator concept having on sidepods,how to make connections as I have seen radiators without caps on this forum and I am also facing problem on height issue as in passenger cars radiator is placed slightly above or parallel to engine height as in our prototype model we used two stock radiators on side pods with parallel connection but after filling radiators water was not reaching to engine and engine started becoming hot..
basically i want to know how customization of radiators are done & how connection is made properly using 2 radiators,,pls reply
  • #46
welcome ..in my opinion , for the guy starting out, plumb the dual rad system in series to avoid air pockets. I think if you are NOT running an electric water pump. you should have bleeders at each radiator as a minimum. These can be simple petcock fittings. You need a radiator cap at the max height of the system and attached to the water expansion tank ( burp can). Finally you need an over flow can as well.
  • #47
it means that i will have to use 2 radiators with perfect calculation having lateral flow,Without radiator cap arrangement on it, with only water inlet and outlet present and should be connected in series connection, And place the water expansion tank having radiator cap at max height,..
and what is bleeders at each radiator and the expansion tank is a can with radiator cap arrangement on it and hollow frm inside with one inlet & one outlet for water on it?? -explain...
  • #48
First, why are you planning to run 2 radiators over running 1?
It's implied that you are going to use 2 of the current radiators.
Have you worked out how much cooling you will need?
You've got to be careful not to overcool, as an engine that doesn't get up to temperature isn't going to run as well as one that does.
  • #49
Each and every calculation is done, and how much water is required,And even the optimum size of radiators has also been calculated,,we are using 2 radiators on both sidepods to balance the weight on either side..
only connection arrangement parts are left to be done.
  • #50
If you run radiators in parallel, care must be taken to ensure one isn't flowing 90% of the fluid while the other does almost nothing.
  • #51
  • #52
expansion tank has inlet and outlet and radiator cap
note the overflow tube under the radiator cap mount
.also temperature sensor mount should be provided
petcock permits bleeding air from radiator and lines
