Solving the Clock Hands Problem: Find All Opposite Times
  • Context: Undergrad
  • Thread starter Thread starter Archosaur
    Clock
The discussion revolves around the problem of identifying all the times in a day when the minute hand of a clock is exactly opposite the hour hand. Participants explore various mathematical approaches and reasoning related to this problem, including both theoretical and practical aspects of clock hand positions.
  • Some participants suggest specific times such as 12:30, 1:35, and others, but there is contention regarding the accuracy of these times based on the positions of the hour hand.
  • One participant proposes that the problem involves an infinite sequence due to the continuous movement of the hour hand as the minute hand is adjusted.
  • Another participant mentions a simpler approach, suggesting that the hands are opposite 11 times in a 12-hour period, leading to a calculation of the intervals between these times.
  • There is a discussion about the mathematical relationship between the hour and minute hands, with some proposing equations to describe their positions.
  • One participant notes that the hands will not be opposite during the hour of 5, leading to a conclusion that there are only 22 instances in a day when the hands are opposite.
  • Several participants express confusion over the calculations and the relationships between the times, indicating a lack of consensus on the correct approach or solution.
Participants do not reach a consensus on the specific times when the hands are opposite, with multiple competing views and methods presented throughout the discussion. There is significant disagreement regarding the calculations and interpretations of the clock hand positions.
Some participants highlight the need for careful consideration of the hour hand's position, as it does not remain fixed at the hour mark. The discussion also reflects varying levels of mathematical rigor and understanding among participants.
This discussion may be of interest to those studying mathematics, physics, or engineering, particularly in relation to problems involving rotational motion and angular relationships.
Archosaur
Here's a cool problem. I thought I came up with it, but it turns out it's been a Google/Microsoft interview question. The solution is pretty cool.
Name all the times in a day when the minute hand is exactly opposite the hour hand of a clock.
Or you could do the similar problem, name the times when the hands are on top of each other.
And before anyone suggests moving this to the math forum, the reason I decided to put it here is that creative use of math is something that physics students need to practice and the guys in the math forum would tear through this with little benefit or amusement.
Mathematics news on Phys.org
60 x 24 right?
Edit: Nevermind, 24. I was thinking of the second hand.
12:30, 1:35, 2:40, 3:45, 4:50, 5:55, 6:00, 7:05, 8:10, 9:15, 10:20, 11:25
LostConjugate said:
60 x 24 right?
it would be 12:32.6, 1:37.6 and so on. At 12:30 the hour hand is exactly between the 12 and 1 so the minute hand would have to be past the six by the same amount.
That's incorrect. Hour hand doesn't stay at exactly the same spot. It's not exactly on 12 at 12:30. It's between 12 and 1 at 12:30, which means that angle between hands is less than 180°.
Think harder.
Still wrong.
bah! I am never going to get a job at google now :(
I'm too lazy to work it out but I guess it involves an infinite sequence, since if you start at 12:30, you have to move the minute hand a bit because then the hour hand is half way between 12 and 1, then you have to move the hour hand a little bit more since you just moved the minute hand, and so on.
OK now I have to try and work it out properly...
You could. It's an easy series to set up and sum over. 30/12 + 30/12² + 30/12³... But now you'd have to do this for each possible position.
There is a MUCH easier way.
Tomsk said:
I'm too lazy to work it out but I guess it involves an infinite sequence, since if you start at 12:30, you have to move the minute hand a bit because then the hour hand is half way between 12 and 1, then you have to move the hour hand a little bit more since you just moved the minute hand, and so on. ….
Like Hercules never catching the tortoise? :biggrin:
Physics is equations
write equations for the positions of the two hands, and then a third equation saying that they're opposite each other. :wink:
Oh cool, I got it from your hint, so it's at 6/11ths of the hour? (plus 5 minutes for each hour) That didn't agree with my series answer though, which was 2.5+5/11 minutes past half past 12, or 12:32.57.27, vs 12:32.43.64. I can't figure out what I did wrong... :(
Hang on I just realized... at 6 o'clock the minute hand is on 0, so you can't just add 5 minutes each time. It should be
t/60 = [(n+6)mod12]/11
Where t is the time after the hour in minutes, n is the hour.
It's not 5 minutes each time, because while the minute hand is catching up on these 5 minutes, the hour hand is still moving.
You're still over-complicating the problem.
To check yourself int the future, where is the minute hand at 6 o'clock?
to enlarge on this …
when the time is h hours and m minutes, where is the hour hand, and where is the minute hand? :wink:
I think you're all working too hard. If this were a linear problem, would anyone have any trouble with it?
How much faster is one hand moving than the other?
It's much simpler than all of this.
The hands are straight 11 times in a 12 hour period, so just divide 12 hours by 11 (=1.0909 hours) and the hands will be straight every 1.0909 hours. (=1hr 5min and 27.27seconds)
Start at 6:00:00, the next one is 7:05:27 and so on.
I think we should do the second problem first:1.The minute when this happens is linearly propotional to the hour number.
2.Round the clock(from 0:00 to 11:60),this happens 11 times(0,1,2,3...10).[tex]\therefore t_{min}=\frac{60n}{11}\ \ \ n\in\mathbb{Z}|\left[0,11\right][/tex]0:00,1:0545,2:109,3:1636,4:218...
Then first problem:
6:00,7:0545,8:109,9:1636,10:218...
Doesn't it just go past once every hour? So 24 times in a day?
Not quite. If you start with the hour of, say, 1am, you know that the hands will be opposite to each other somewhere in the ballpark of 01:35 to 01:40. Where exactly you can determine with some extra math, but you KNOW that somewhere between 01:35 and 01:40, the two hands will be directly opposing. Same thing with the hour of 2am-- the hands will be opposite somewhere between 02:40 and 02:45.
You can keep this up for a while, until you reach the hour of 5am. Between 05:00:00 and 05:59:59, the hour hand and minute hand are NEVER in opposition. Turns out they line up at PRECISELY 06:00:00.
So for every hour, the hour hand and minute hand are directly opposite once-- EXCEPT for the hour of 5 (5am and 5pm). Therefore, there are only 22 times of the day when this takes place!
Hence, it's pretty easy to see that the hands line up at direct opposite positions every 3927 and 3/11 seconds (3927.2727272727...). And since we know they're directly opposite at exactly 6:00 (am or pm), you can work backwards or forwards from there to figure out the exact times of day that this happens.
DaveE
  • · Replies 25 ·
  • · Replies 95 ·
9K
  • · Replies 115 ·
10K
  • · Replies 21 ·
  • · Replies 22 ·
  • · Replies 27 ·
