Solve Energy Dissipation in Resistor: I = 0.09 A, R = 80.0 Ω
  • Thread starter Thread starter roam
    Current Energy
The total energy dissipated as heat in a resistor with a resistance of 80.0 Ω and a current of 0.09 A over a duration of 1 minute is calculated using the formula for electric power, P = I²R. The power dissipated is 0.648 W, leading to a total energy dissipation of 38.88 J when integrated over the time period of 60 seconds. This calculation confirms that the energy dissipated can be derived directly from the power and time.
  • Understanding of Ohm's Law
  • Knowledge of electrical power formulas (P = IV, P = I²R)
  • Basic principles of energy calculation in electrical circuits
  • Familiarity with units of measurement for power (Watts) and energy (Joules)
  • Study the derivation of the energy formula from power and time
  • Learn about the relationship between voltage, current, and resistance in circuits
  • Explore practical applications of resistors in electrical engineering
  • Investigate thermal management techniques in electronic devices
Students studying electrical engineering, physics enthusiasts, and anyone interested in understanding energy dissipation in resistive components.
roam
What is the total energy dissipated as heat in a resistor of resistance R = 80.0 Ω when a current of I = 0.09 A passes through it for 1 minute?
From the given values I can work out the potential difference, but I'm stuck here because I don't know what formula to use with energy in it. But I know that electric power can be found from P=IV=I2R, but I don't know how this helps to find energy. Of course I know that [tex]P=\frac{dU}{dt}[/tex], but I don't see how to solve for the energy... :confused:
It seems you have the answer hiding right in front of you...
If you know that the power drop across a resistor is (I^2)(R) then you can calculate that given the values.
Next if you assume that it drops all that power through heat 'U' over that 1min and you know that P=U/t then...
  • · Replies 16 ·
13K
