How to Rescale the X-Axis in Mathematica?
  • Context: Mathematica
  • Thread starter Thread starter olietc
    Mathematica
The discussion revolves around how to rescale the x-axis in Mathematica plots, specifically when plotting a function with respect to a variable T. Participants explore different methods to achieve the desired axis labeling and scaling.
  • One participant seeks assistance in plotting a function with an x-axis that displays values from 0 to 3 instead of 0 to 30, with the intention of labeling the axis as T/10.
  • Another participant suggests using the Plot function with a modified range and axes label: Plot[function, {x, 0, 3}, AxesLabel -> {T/10, y-label}].
  • A third participant provides a function with zeros at specific points and demonstrates two methods to change the x-axis units to x/10, using either a transformation of the function or custom ticks.
  • A later reply expresses appreciation for one of the proposed methods, noting its effectiveness in keeping the function unchanged while achieving the desired axis scaling.
Participants appear to agree on the need for rescaling the x-axis, but multiple methods are presented without a consensus on a single best approach.
Some methods depend on specific definitions of the function and the desired appearance of the plot, which may not be universally applicable.
olietc
Hi guys
I am trying to plot a function with respect to T, but I want to rescale my axis.
For example my range right now shows 0, 10, 20, 30. But I want it to show 0, 1, 2, 3 and so that I can then put an x-axis label of T/10.
Can anyone help?
Try with:
Here's a function that has zeros at x=10 and x=20.
Code:
f[x_]:=(x-10)(x-20)
and it's normal plot
Code:
Plot[f[x],{x,0,30},AxesLabel->{x,f}]
Here's two different ways to change the x-axis units to x/10:
Code:
Plot[f[10x],{x,0,3},AxesLabel->{x/10,f}]
Code:
Plot[f[x],{x,0,30},Ticks->{Table[{i,i/10.},{i,0,30,5}],Automatic},AxesLabel->{x/10,f}]
Thanks so much!
I like that last option Simon_Tylor, it keeps the function the same. Up until now the only thing I could think of was changing the x inside the function like you did in your first example..
Not a problem olietc!
  • · Replies 18 ·
