Thermal expansion of a glass bottle
The discussion focuses on calculating the change in height of the mercury column in a thermometer due to thermal expansion, specifically addressing the contributions from both mercury and glass. The thermal volume expansion coefficients are given as 18 x 10-5 for mercury and 2 x 10-5 for glass. The correct approach involves calculating the volume expansion of mercury and subtracting the volume expansion due to glass to find the effective expansion. The final solution for the change in height, h, is determined to be 3.1 cm.
  • Understanding of thermal volume expansion coefficients
  • Familiarity with the geometry of cylindrical and spherical shapes
  • Basic algebra for solving equations involving volume and temperature changes
  • Knowledge of units and conversions in physics
  • Study the principles of thermal expansion in liquids and solids
  • Learn how to derive and apply the formula for volume expansion
  • Explore the impact of temperature changes on different materials
  • Investigate the design and function of thermometers, focusing on fluid dynamics
Students in physics, engineers working with thermal systems, and anyone involved in the design or analysis of thermometric devices will benefit from this discussion.
a077456
A typical mercury thermometer is made up of a thin, cylindrical capillary tube with a diameter of 0.0040 cm, and the spherical bulb with a diameter of 0.25 cm. If we DON'T Neglect the expansion of the glasas, find the change in height of the mercury column for a temperature change of 30 degree.
In the solution, it was given that the thermal volume expansion of mercury = 18 * 10-5 and the thermal volume expansion of glass = 2 x 10-5
I have attempted to solve the problem, however, I don't really know which volume expansion value should I use in the problem.
I have setup:
[tex]\Delta[/tex] V = Vexpansion
(V0 + [tex]\Delta[/tex]A) * [tex]\Delta[/tex]h = V0 + V0 * volume expansion value * [tex]\Delta[/tex] Temperature
[tex]\Pi[/tex] *(0.0040 cm/2)2 + [tex]\Pi[/tex] *(0.0040 cm/2)2 * ( thermal expansion of "what material?" * (30 degree) * ([tex]\Delta[/tex] h =( ([tex]\frac{4}{3}[/tex] * [tex]\Pi[/tex] * (0.25cm/2)3 ) + ([tex]\frac{4}{3}[/tex] * [tex]\Pi[/tex] * (0.25cm/2)3 * (volume expansion of "which material" ) * (30 degree)
I have tried to solve with both thermal expansion number, however, I have got 650 cm and 631cm.
The solution of the problem is [tex]\Delta[/tex] h = 3.1cm...
I wonder where did I do wrong? Whcih volume of expansion should I choose?
Firstly I assume the volume expansion for glass and mercury are given in the correct units. [here using cm to be consistent with the other units in the question]
You are on the right track...
You start by calculating the volume expansion of the mercury and subtract from it the expansion due to the glass. This gives the effective expansion of the mercury into the tube.
The volume expansion is found by multiplying the original volume by the rise in temperature and the expansion coefficient.
Equate this volume expansion to the volume of a length L in the tube.
Volume in tube is A x L where L is what you want to calculate. A is the cross section area.
  • · Replies 67 ·
21K
