A saturated mixture is heated, volume is doubled and pressure remains the same.
The discussion focuses on a thermodynamics problem involving a saturated water mixture heated from an initial state with a pressure of 200 kPa and a volume of 0.3 m³ to a final volume of 0.6 m³ while maintaining constant pressure. The initial temperature T1 was not provided, but the final temperature T2 was calculated to be 120.12°C using pressure tables and interpolation. Additionally, the internal energy can be determined by calculating the specific volume at state 2 and referencing the internal energy values from the tables.
  • Understanding of saturated water mixtures and phase changes
  • Familiarity with thermodynamic tables, specifically pressure and temperature tables
  • Knowledge of specific volume calculations
  • Ability to perform interpolation for thermodynamic properties
  • Study the use of thermodynamic tables for saturated water mixtures
  • Learn about the calculation of specific internal energy in thermodynamics
  • Explore interpolation techniques for thermodynamic properties
  • Investigate the relationship between pressure, volume, and temperature in phase change processes
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in heat transfer and fluid mechanics who require a deeper understanding of saturated mixtures and their properties.
allly
A saturated water mixture is heated.
P1=200kPa
m=0.5kg
V1=0.3m^3
V2=0.6m^3
find
T1
T2
Internal Energy
2. The attempt at a solution
Using the pressure tables and interpolation I found T2=120.12
stuck on T2 and internal energy.
Since you have the mass, for state 2, you can get the specific volume v2 by using v2=V2/m and read that off from the table.
Your table will also have values for specific internal energy, which when multiplied by mass, gives the internal energy.
  • · Replies 19 ·
9K
  • · Replies 16 ·
32K
