Determine the power required to forge a cylinder
  • Thread starter Thread starter Gelate
    Cylinder Power
The power required to forge a 100 mm diameter, 50 mm tall low-carbon steel cylinder at 1200°C, reducing its height to 15 mm with a constant flow stress of 80 MPa, can be calculated using the formula: Power = Force x Velocity. Given the efficiency of 60%, the necessary calculations involve determining the forging force based on the cylinder's dimensions and material properties. The final power output will be adjusted to account for the efficiency factor.
  • Understanding of mechanical metallurgy principles
  • Familiarity with flow stress concepts in materials
  • Knowledge of power calculations in mechanical systems
  • Basic proficiency in using equations related to force and velocity
  • Study the equations for calculating forging force in cylindrical shapes
  • Learn about the effects of temperature on flow stress in low-carbon steel
  • Research efficiency factors in mechanical processes and their impact on power calculations
  • Explore resources on mechanical metallurgy for foundational knowledge
This discussion is beneficial for mechanical engineering students, particularly those specializing in metallurgy and materials processing, as well as professionals involved in forging operations and power calculations in manufacturing.
Gelate
Hi, can anyone help me on the following problem? Thanks a lot in advance!
A 100 mm diameter, low-carbon steel cylinder, 50 mm tall, is forged at
1200°C at a velocity of 1m/s until its height is reduced to 15 mm.
During forging it is assumed that the flow stress is constant at 80 MPa.
Assuming an efficiency of 60% determine the power required to forge
the cylinder.
I do not know what equations to use. I do not have many references (books or website) to look at. I never learned mechanical metallurgy before and this is my first year in graduate school. in a panic...
I know force times velocity is power. I would assume that this is what you need to use.
EDIT: oops didn't realize how old this thread was.
  • · Replies 19 ·
  • · Replies 44 ·
9K
