Impedance of a parallel RC circuit?
The discussion revolves around calculating the impedance of a parallel RC circuit connected to a battery during its charging phase, where the input voltage is not pure DC due to ripples. The user seeks to eliminate the imaginary component from the capacitor's reactance to simplify calculations for the series resistance. It is clarified that the complex part cannot be disregarded, especially since the circuit experiences AC characteristics due to the ripple. The correct approach involves modeling the voltage source as a combination of DC and AC components, with the ripple frequency impacting the calculations. Ultimately, to find the series resistance, the total impedance can be derived from the measured voltage and current, accounting for the ripple effects.
jak9
Hi there,
I have a circuit in which consists of a resistance (rs) in series with parallel combination of capacitor and resistance(rc). I want to calculate value of rs. So i did this by calculating total impedance Ztotal which is V/I and then substracting impedance of parallel rc circuit.
Ztotal=rs+Zcrc where Zcrc is the impedance of the parallel rc.
I know the impedance for the parallel rc circuit but i want to get rid off the jth term which is present in the reactance term of the capacitor. How it can be done??
Xc=1/jwc
then here how to eliminate the jth term because i will subtract this impedance of parallel rc circuit from the total impedance to calculate rs.
thanks
For a fraction with a complex value in the denominator, multiply both the numerator and denominator by the complex conjugate of the denominator. This will result in a real value in the denominator.
thanks but is it ok if i square the equation and then finally square root to get the Xc back?
Xc^2=1/(jwc)^2=-1/w^2*c^2
Xc=-1/wc ? is it right?
No. You need to keep the complex part of the equation. You can use the trick that Phrak described to get the more normal form of A + jB for the complex number. Unless you are talking about DC, the capacitor will affect the voltage division, so you can't just get rid of the complex part of the voltage divider.
thanks but actually i am calculating this impedance of a battery circuit. The input voltage is not a pure dc due to some ripples in the signal so how i should treat this signal as sc or dc? if dc then can i get rid off the complex jth term??
thanks
Maybe you should describe the circuit you are interested in, in more detail. A battery itself, or a battery associate Rs and Cs will not have an AC voltage component after it's settled down, so it's difficult to know what you are talking about. Is there a switch or another source of emf?
thanks... Actually i have an equivalent circuit of a car battery (during charging phase) which consists of a resistance(r1) in series with parallel combination of capacitor and resistance(r2). The input is voltage and current from the rectifier but its not a pure dc as it has ripples. So should i consider the circuit as ac or dc?
the reason is i am struggling with the impedance component of the parallel rc circuit. If it is dc then what will be the reactance formula. I know the reactance term will be infinite because of zero frequency but i calculated the frequency from the voltage signal and its varying. So if we use Xc=1/jwc then should this jth term to be considered or not?
My final aim is to calculate r1 and my idea of doing it is calculating the impedance. So my logic is
Ztotal=r1+Zxcr2
i.e. total impedance Ztotal= V/I
r1=series resistance and
Zxcr2=Impedance of parallel r2 and c
r2=r2;
Xc=i/jwc
so what is the right way of calculating r1 if all other terms are given?
thanks
If you have ripple you don't have zero frequency.
First of all you want to model your unregulated voltage source as Vdc + Vaccos(2 pi f t) together with a series resistance. The series resistance could be negligable. I don't know.
The voltage source has both AC and DC parts so the AC ripple may be a concern. It's difficult to tell at this point.
It's not that hard to deal with R and C in parallel. w = 2 pi f, where f = frequency.
In general, for Z1 in parallel with Z2: Z = (Z1 Z2)/(Z1+Z2). Just like resistors in parallel.
Z1=R
Z2=1/jwC
Z = (R/jwC)/[R+(1/jwC)]
To simplify the bottom, multiply the top and bottom terms by jwC.
Z = R/(jwRC+1) = R/(1+jwRC)
Now we do the complex conjugate thing to get a real denominator by multiplying top and bottom by 1-jwRC.
Z = R(1-jwRC)/[(1+jwRC)(1-jwRC)]
Z = R(1-jwRC)/[1+(wRC)2]
Dear phrak thanks a lot for an awesome reply...but what do you mean by:-
"First of all you want to model your unregulated voltage source as Vdc + Vaccos(2 pi f t) together with a series resistance? "
do you mean that if the incoming voltage is 14v then
14+14cos(2pift)??
if yes then
pi=3.14 and what will be t?? the current time during the simulation or something else?
yes you are right that the series resistance would be negligible but my concern is to find the series resistance(r1) only.
the values that i have to my model circuit is the continuous value of incoming voltage and current from the rectifier.
So if i divide incoming voltage by incoming current then is it the total impedance of the circuit?
14+14cos(2pift)??
OK, so your DC value is 14 volts in average. But you have a bit of ripple. Measure the ripple. Do you have an oscilliscope? Let's say it ripples from top to bottom 1.2 volts. Then your voltage source is 14 + 2 cos( 2 pi f t).
Tell me. what is your ripple frequency and what is the value of C?
ok to make it more clear my circuit is dealing with battery charging and as the voltage is not constant because of ripples. So the frequency i calculated is by f=1/t and its around 100hz or sometimes more or less by 10. The capacitor is a double layer capacitor and the value i got is 207360F which is unacceptable and the new value of the capacitor now is 0.6678F.
so in short
C=0.6678,
f=100hz
and by the from where this 2 comes
14+2cos(pift)??
