IQ questions: Patterns in shapes and arrows
  • Thread starter Thread starter mlsbbe
    Iq
The discussion revolves around two IQ questions involving patterns in shapes and arrows. Participants explore various interpretations and potential answers, focusing on reasoning behind their choices and the nature of the patterns presented.
  • Some participants suggest that the second arrow is rotating clockwise while moving counterclockwise, proposing that the next arrow should point down in the lower right corner (C).
  • Others argue that the second arrow could also be A, as it is pointing downwards.
  • One participant notes that the first question seems random and admits that multiple answers could be justified creatively.
  • Several participants arrive at E for the first question and C for the second, while expressing skepticism about the validity of the questions.
  • One participant provides a detailed breakdown of the patterns in the first question, focusing on size, fill, and shape, suggesting A as a potential answer.
  • Another participant emphasizes the importance of considering both shape and size in the first question, leading them to conclude A as well.
  • Some participants mention alternative possible answers for the first question, indicating that there may be more than one valid interpretation.
  • One participant humorously suggests that the question could be a "complete Fail" for an IQ test.
  • Another participant outlines a pattern of shared shapes and colors in the first question, concluding that A is the correct answer based on their reasoning.
Participants express a range of opinions on the answers to both questions, with no consensus reached. Multiple competing views remain, particularly regarding the first question, where several potential answers are proposed.
Participants note the ambiguity in the questions and the possibility of multiple valid answers, highlighting the subjective nature of interpreting patterns in the given shapes and arrows.
mlsbbe
Hi Guys,
Got these two IQ questions...
Anybody know the answers to?
Not too sure about the answers to both...
For the second one, the arrow is rotating clockwise while moving counterclockwise.
The next one should be pointing down in the lower right corner, ergo C.
The first one seems to be completely random to me, I can come up with an explanation for most of the possible answers.
why can't the second one be A? its also pointing downwards...
mlsbbe said:
Hi Guys,
I come up with E for the first and C for the second.
These are pointless questions though, and I'm sure several answers could be justified by a sufficiently creative mind.
Sure it could be, as steven notes.
But C seemed more logical to me, if you also take the position (not just the orientation) into account: center top, left top, left middle, left bottom, center bottom, so the next one should then at the bottom right.
Yea, I got E for the first as well
I went for C at first, too. Guess I'm not smart engouh. :-p
For the first it’s
B
Here’s how:
Top shape: S-UF-…→ B-F-SS→ B-F-DS→ B-F-SS→ S-UF-SS→ S-F-DS
Bottom shape: B-F-…→ B-UF-DS→ B-UF-SS→ S-UF-SS→ S-F-DS→ S-F-DS
Where: S=small size; B= big size; F=filled; UF= unfilled; SS=same shape; DS=different shape.
There’s one other possible choice, which is [S-F-SS] for the top shape and [S-F-SS] for the bottom one, but it’s not an option. :biggrin:
For the second it’s
C
UR→ LD→ CL→ LU→ DR→ CD
The first letter represents the side on which the arrow occurs, the second is the direction of the arrow.
How does that sound? :biggrin:
AMENDED..on second thoughts...
For the first one:
Ignore the sizes because there is no repeating sequence observable..., and focus on the whether or not its filled and the shapes
The pattern for the top and bottom row is like this:
(1) Square, square, square, circle, circle..
(2) Big, Big, Big, Small, Small
So the next in the sequence is A.
You can't neglect the shape, can you?
For the first one:
drizzle said:
For the first it’s
B
Here’s how:
For the second it’s
C
The answer to the 2nd one is obviously C.
I annotated the 1st one binarily by shape and size, and came up with A as the answer.
Though I think you are right about there being possibly more answers.
01 (no shape change, yes to size change)
01
obviously a Rotating Left binary shift, leading only to one answer
00 = A
I think the shading was only there to fool you. Though if the shading in A were reversed, it would have been much more logical, as there was another pattern:
1 4
4 8
8 8
8 6
6 2
solution:
2 x
I don't know why people bad mouth IQ tests. These are fun.
:smile:
For the first one:
I can so relate with this post.
If I've told my staff at work once, I've told them a thousand times:
"Listen to what I'm thinking, not what I'm saying."
:wink:
Oh, another possible choices, [S-F-SS] for the top shape and [S-F-DS] for the bottom one, or vice versa, but again it’s not an option. :biggrin:
:smile:
Yeah, just for fun though. I do get mad if someone tells me it measures my intelligence quotient. :biggrin:
Ha Ha! D is also a correct answer.
That means someone has picked each at least once.
So the answer was: all of the above
:smile:
A new shape color size combination object was introduced into each of the first 5 panels, there was also a color change within each panel. Only the small black square and large white circle were left to add. But 'B' had no color change. Hence D was the right answer. Along with A, B, C, and E of course. :-p
Can I still change my mind and switch to F?
(That is, F for "complete Fail to make a sensible IQ test question")[/size]
1 is definitely A.
The 2 shapes gradually become more alike, then the 2 step sequence starts over and repeats.
There are 3 variables in play: shape, size, color.
1: Same shape, Diff size, Diff color
2: Diff shape, Same size, Diff color
3: Same shape, Same size, Diff color
4: Same shape, Diff size, Diff color
5: Diff shape, Same size, Diff color
So it's obvious the 2 need to be the same shape and same size and cannot be the same color...hence A.
Case closed. :)
Here's how I justified number 1 (if somebody has said this already in the thread my bad - I just skimmed it)
Each successive box contains a shared shape with the box before.
12 share black large circle
23 share white large square
34 share black large square
45 share white small square
this makes me think a small black circle(since the small square has already been shared) will be in the next box (barring D and E) and since we never have the same colors we can forget about B.
Now the sharing goes in a pattern like so:
Diagonal, bottom, top, diagonal,...
So the next box would be a bottom share (further evidence for A or C). We also notice that the box after a bottom share has the same shape but different color so I can conclude that A is the correct answer.
  • · Replies 33 ·
  • · Replies 21 ·
13K
  • · Replies 60 ·
11K
  • · Replies 19 ·
41K
  • · Replies 71 ·
18K
