Parallel Transport: Constancy of Magnitudes & Angles Along Geodesic
The discussion revolves around the concept of parallel transport in the context of a Riemannian manifold, specifically focusing on the constancy of magnitudes and angles of vectors along a geodesic. The original poster presents a problem involving a vector field being parallely propagated along an affinely parameterized geodesic.
  • Participants raise foundational questions regarding the definitions of parallel transport, the meaning of "along the geodesic," and the definition of the angle between two vectors. There is also an attempt to clarify the conditions for parallel transport using the covariant derivative.
The discussion is in an exploratory phase, with participants seeking to clarify key concepts and definitions. Some guidance has been offered regarding the mathematical expression for the angle between vectors, but no consensus or resolution has been reached regarding the original problem.
There are indications of uncertainty regarding the definitions and implications of parallel transport and geodesics, as well as the mathematical framework involved. Participants are encouraged to clarify these concepts further.
latentcorpse
A vector field Y is parallely propagated (with respect to the Levi-Civita connection)
along an affinely parameterized geodesic with tangent vector X in a Riemannian
manifold. Show that the magnitudes of the vectors X, Y and the angle between
them are constant along the geodesic.
Some questions to get you started.
What is the definition of parallel transport?
What does along the geodesic mean?
How is the angle between two vectors defined?
The tensor T is parrallely transported along the curve with tangent [itex]X^a[/itex] if [itex]\nabla_X T=0[/itex]
Along the geodesic means along the affinely parameterised curve of shortest distance (think i may be a bit off here but hopefully you can clear it up!)
On a Riemannian manifold, the angle between two vectors is given by
[itex]\theta = \cos^{-1} \left( \frac{ g(X,Y) }{ ( |X||Y| ) } \right)[/itex] where [itex]|X|= \sqrt{ g(X,X)}[/itex]
So what is your problem?
  • · Replies 26 ·
  • · Replies 20 ·
