Integrating along the imaginary axis
The discussion revolves around proving a result related to complex line integrals along the imaginary axis, specifically involving the function f(z) and the integration paths I_{1} and I_{2}. The scope includes mathematical reasoning and exploration of complex analysis concepts.
  • Exploratory, Mathematical reasoning
  • One participant expresses confusion about how to prove the result involving the integrals I_{1} and I_{2} and the function f(z).
  • Another participant suggests drawing the contour and emphasizes the need to parametrize the integrals I_{1} and I_{2} based on the definition of the complex line integral.
  • A participant proposes a parametrization of I_{1} as kiR for -∞ < k < ∞, questioning its validity.
  • Another participant corrects this by stating that I_{1} runs from iR to iε, indicating that the parameter should not range over the reals.
  • Further discussion leads to uncertainty about the correct parameterization, with one participant suggesting kiR where ∞ < k < ε, while another later retracts and suggests ik where R < k < ε.
Participants do not reach a consensus on the correct parameterization for the integrals, and multiple competing views remain regarding how to approach the proof.
There are limitations in the discussion regarding the assumptions made about the parameterization and the definitions of the integrals involved, which remain unresolved.
Cairo
I'm really confused with how to prove this result...could anybody help please?
Let I_{1} be the line segment that runs from iR (R>0) towards a small semi-circular indentation (to the right) at zero of radius epsilon (where epsilon >0) and I_{2} a line segment that runs from the indentation to -iR.
Define
f(z)=\frac{e^{2\pi iz^{2}/m}}{1-e^{2\pi iz}}
Prove that
I_{1}+I_{2}=-i\intop_{\varepsilon}^{R}e^{-2\pi iy^{2}/m}dy
How can I do this?
Cairo said:
Define
[tex]f(z)=\frac{e^{2\pi iz^{2}/m}}{1-e^{2\pi iz}}[/tex]
Prove that
[tex]I_{1}+I_{2}=-i\intop_{\varepsilon}^{R}e^{-2\pi iy^{2}/m}dy[/tex]
How can I do this?
First, draw out the contour. It's clear you're going to have to work from the definition of the complex line integral. So, how would you parametrize I_1 and I_2?
Would it be kiR for -oo<k<00 ?
I_1 is a segment running from iR to [itex]i\varepsilon[/itex] right? So it wouldn't make sense for your parameter to range over the reals.
Hmmmm...
I'm not sure how to proceed here then. Would it not be valid to have kiR where
oo<k<epsilon?
This would give the line segment, right?
I'm talking nonsense! Forgive me!
Would it be ik where R<k<epsilon?
  • · Replies 71 ·
