General relativity question on mass conservation integral
The discussion focuses on deriving the effective potential equation in the context of general relativity using an axisymmetric metric. The user has successfully applied the Euler-Lagrange equations to establish expressions for energy (E) and angular momentum (L) but struggles to manipulate these into the desired form: g_{rr}\left (\frac{dr}{d\tau} \right )^{2}+g_{\phi \phi}\left (\frac{d\theta }{d\tau} \right )^{2}=V_{eff}\left ( r,\theta ,E,L \right ). The key steps involve substituting the expressions for E and L into the metric equation and simplifying to isolate the effective potential. The user is advised to solve for dt/dτ and dφ/dτ algebraically to progress.
  • Understanding of general relativity and axisymmetric metrics
  • Familiarity with the Euler-Lagrange equations
  • Knowledge of proper time and invariant intervals
  • Ability to manipulate differential equations
  • Study the derivation of effective potential in general relativity
  • Learn about the properties of axisymmetric metrics in general relativity
  • Explore the application of the Euler-Lagrange equations in physics
  • Investigate the relationship between proper time and invariant intervals
Students and researchers in theoretical physics, particularly those focusing on general relativity, as well as anyone interested in the mathematical foundations of gravitational theories.
tcw
Starting off with a general axisymmetric metric:
[tex]ds^{2}=g_{tt}dt^{2}+2g_{t\phi }dtd\phi + g_{\phi \phi }d\phi^{2} +g_{rr}dr^2 + g_{\theta \theta }d\theta ^2...\left ( 1 \right )[/tex]
where the metric components are functions of r and theta only.
I have deduced (using Euler-Lagrange equations) that:
[tex]E=g_{tt}\frac{dt}{d\tau}+g_{t\theta }\frac{d\phi}{d\tau}...\left ( 2 \right )\\<br /> L=g_{t\phi }\frac{dt}{d\tau}+g_{\phi \phi}\frac{d\phi}{d\tau}...\left ( 3 \right )[/tex]
where E and L are constants.
I am required to derive:
[tex]g_{rr}\left (\frac{dr}{d\tau} \right )^{2}+g_{\phi \phi}\left (\frac{d\theta }{d\tau} \right )^{2}=V_{eff}\left ( r,\theta ,E,L \right )[/tex]
which is where I get stuck.
Dividing (1) by d(tau)^2 and substituting (2) and (3), and rearranging gives:
[tex]g_{rr}\left (\frac{dr}{d\tau} \right )^{2}+g_{\phi \phi}\left (\frac{d\theta }{d\tau} \right )^{2}=\left (\frac{ds}{d\tau} \right )^{2}-E\frac{dt}{d\tau}-L\frac{d\phi}{d\tau}[/tex]
upon which I am unsure how to proceed.
I tried solving (2) and (3) simultaneously but to no avail.
Any help is appreciated. Thanks.
You only need to solve (2) and (3) algebraically for [tex]dt/d\tau[/tex] and [tex]d\phi/d\tau[/tex]. You can deal with the [tex](ds/d\tau)^2[/tex] term by recalling the relationship between the invariant interval and the proper time.
  • · Replies 46 ·
