Dielectric Effect of H2O in Hollow Silicone Tube
  • Context: Graduate
  • Thread starter Thread starter Foxdove
    Dielectric
The discussion centers on the dielectric effect of distilled water (H2O) within a hollow silicone tube, specifically a tube with a 7 mm diameter and a wall thickness of 1.5 mm, containing two copper foil plates of 64 mm² each. The dielectric constants are noted as k = 2.85 for silicone and k = 80 for distilled water. It is established that the presence of distilled water will significantly influence the capacitance of the system, resulting in a measurable change compared to the capacitance without water.
  • Understanding of capacitance and dielectric materials
  • Familiarity with the concept of dielectric constant (k)
  • Basic knowledge of fluid dynamics in electrical applications
  • Experience with measuring capacitance in experimental setups
  • Research the impact of dielectric materials on capacitance in various configurations
  • Explore experimental methods for measuring capacitance changes in fluid-filled tubes
  • Investigate the effects of different fluids on capacitance and dielectric properties
  • Learn about the applications of capacitive sensors in fluid monitoring
Electrical engineers, physicists, and researchers interested in capacitive sensing, fluid dynamics in electrical systems, and the effects of dielectric materials on capacitance.
Foxdove
Consider having a hollow silicone tube of 7 mm diameter and a wall thickness of 1.5 mm. There are two copper foil plates that are both 64 mm^2 in area. Will a fluid, such as distilled water, passing through said tube have an measurable influence on producing a change in capacitance?
Note: k = 2.85 for silicone and 80 for distilled H2O. Will said capacitance be different before and during the presence of the H2O?
Where are the copper plates? Whose capacitance?
  • · Replies 19 ·
11K
24K
  • · Replies 21 ·
10K
