View Single Post
Feb27-11, 05:21 AM   #65
Quote by Topher925 View Post
Do you have anything to back this up? There's good reasons why the most fuel efficient gasoline fuel vehicles don't have turbo chargers.
The reason that is becuase American car manufacturers have been horribly backwards with engine design. American manufacturers like cheap, with no regard to environmental cost. Turbocharged cars are complex and therefore are disregarded. They are stuck in a rut, American consumers hove your attitude to turbo motors, so manufacturer will make them for fear of not selling. The consumer can't buy them if noone sells a good turbo motor.
This however is changing. Get with the times. Engine downsizing is the trend within the industry to provide the power and meet emissions standard , you will find it in the vast majority of cars world wide. If not this generation, then the next generation of cars.
Ford is putting a 2.0L Turbo over it's V6 in the new Explorer. Similar power output with a boost in economy of aprox. 30%.
VW are replacing pretty much it's entire line with reduced capacity turbos. With the most extreme being the 1.4TSI putting out 150bhp. Audi as part of that group are doing it
http://green.autoblog.com/2010/04/09...se-fuel-econo/
Toyota are doing it
http://paultan.org/2010/11/24/toyota...tion-vehicles/
Volvo are doing it
http://green.autoblog.com/2010/12/03...rs-diesel-for/
Even Bentley are doing it in the next Continental GT.
http://www.frost.com/prod/servlet/ma...ocid=195091644
Market insight from a consultancy website regarding turbos and downsizing to meet emissions standards.
http://www.google.co.uk/url?sa=t&sou...FTqUwQ&cad=rja
A sort of technical pamphlet showing downsizing.
As I'm no longer at Uni I don't have access to the SAE papers archive. However there are a whole host of papers looking at cool stuff like variable vane turbos and direct injection to aid in downsizing.
http://papers.sae.org/2009-01-1472
http://papers.sae.org/2009-01-1053
I could go on, you can search the site on your own. There zillions of papers regarding this subject.
EDIT: You are doing a PhD iirc, your Uni is likely to have a subscription to the SAE paper database.
NO! This is a common misconception. The only advantages turbo's can have over super chargers in terms of efficiency is from near adiabatic expansion of exhaust gases (and that ain't much) and no losses from a belt or drive train. There are also a lot of "ifs" that come from compressor design and so forth. For example, a centrifugal compressor is much more efficient than a screw type compressor. Often a reason for turbo efficiency being greater than super charger efficiency is just that the impeller has a better design and is more efficient due to a much higher rpm. Its tough to build a gear train that can spin an impeller at 100K+ rpms.
The advantage comes from the fact that you are running the turbo (ie compressing the air) with something you would otherwise just throw straight out the exhaust and not something you want to use. It's like adding an LP turbine to a power plant to take advantage of the energy still left.
I was talking about system efficiency not component efficiency.
I would never buy a car with a turbo in it unless I was having a mid-life crisis. I'm not a big fan of fast cars and prefer something with good mileage and low emissions. Plus, turbo-ed engines suck in the cold.
Not only that, turbo cars a far easier to drive. As they have fat torque from the minute they come on boost. Leading to a wider power band.
http://autospeed.com/cms/title_Turbo...1/article.html
Some of the things in this link are a bit overly basic, but it gives a good indication of how a turbo alters the power band and how downsizing an engine but using a turbo to match performance works.
If you want something with good mpg and emissions, it's time to get yourself a new downsized turbo then isn't it.
