Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #151
rogerl said:
I just heard from CNN that the heat in nearby reactors could have evaporated the water that soaked the spent fuel in reactor #4 and the rods caught fire and release radioactive debris about 400 milliSiv inside the compound.
I'd like to confirm that. Unit 1-3 should not affect unit 4. Unit 4's upper containment seems intact - but I haven't confirmed that.
So how dangerous are spent fuel? If they are "spent", there should be few live nuclei left that can fission, isn't it. Or the decayed project is acting up and still radioactive? What elements?
Spent fuel is pretty dangerous! That's why it is normally handled with 30 feet of water or several feet of steel and/or concrete between spent fuel assemblies or rods and people. The objective is to retain the fission products in the fuel rods (enclosed by the ceramic fuel and Zr-alloy cladding tube), but that clearly is not the case at Fukushima.
Also about Reactors 1-3. Isn't it if you leave cyanide powder in the trash can with no wind in the room, it would stay there. If you instead blow it with air, it will spread. What I'm saying is that the fuel rods in reactors 1 to 3 are no longer live and just left over decay heat. So why don't they just stop putting water and releasing steam outside the plants which can spread radiation all over the country and instead just let the fuel rods rot or melt and let the mixture stay safely in the bottom of the containment shell just like cyanide power left in the bottom of the trash can and basically quarantined there? Stupid questions but this nuclear incident is unprecendented. Sorry and thanks
It seems they may be contemplated something like that - which is pretty much how Chernobyl ended up, with the possible exception that it is not yet clear the fuel actually 'melted', as opposed to simply breached or cracked (typical vertical or longitudinal cracks), and it is not clear that it will necessarily melt - assuming there is some form of coolant inventory.
The questions are not stupid. And yes - this event is unprecedented!
To give better or more definitive answers, I'd need better information. I'm working on that.
This is still not detailed enough, but . . .
http://www.world-nuclear-news.org/RS_Possible_damage_at_Fukushima_Daiichi_2_1503111.html
  • #153
Reactor #3 is said to use MOX, "a controversial fuel made with reprocessed plutonium and uranium oxides". Does it have larger thermal properties?
http://search.japantimes.co.jp/cgi-bin/nn20100823a7.html
"Fukushima reactor receives MOX
FUKUSHIMA (Kyodo) Tokyo Electric Power Co. on Saturday loaded a nuclear reactor in Fukushima Prefecture with MOX, a controversial fuel made with reprocessed plutonium and uranium oxides, as it prepares to become the leading power utility's first facility to go pluthermal.
The No. 3 reactor at Tepco's Fukushima No. 1 plant will be the nation's third pluthermal facility, but only the first to be refurbished since the plant was built 34 years ago.
Tokyo Electric plans to activate the reactor on Sept. 18 and let it start generating electricity on Sept. 23."
  • #154
Regarding fuel rods, including the MOX fuel rods:
Is it known if the spent fuel rods from reactor units 1, 2, and 3 stored in the containment pool for unit 4 or not?
If so, might there more danger from the contaminated steam coming off the "boiling" containment pool and fire at unit 4 than otherwise might be the case (ie, from plutonium release)?
If not, are there additional spent fuel rods from units 1, 2, and 3 stored in each of the reactor facilities? Where would fuel rod storage be located in a GE Mark I type reactor facility? Are they at risk?
Might contamination arising from the problems associated with failed cooling of the spent fuel rod storage sites yet be a bigger problem than cooling the reactor cores?
  • #155
Each unit has it's own spent fuel storage pool, so the spent fuel for one unit is stored in it's own pool. The SFP is located near the top of the primary containment.
The SFPs could be at risk. We are lacking the details on their status.
  • #156
Here's an example of one crazy media report: there are several obvious inaccuracies...
they seem to have "reactor" mixed up with "fuel storage pond" for one thing...
Can spent fuel in separate storage even "catch fire" if exposed from underwater ?
Japanese officials told the International Atomic Energy Agency that the reactor fire was in a fuel storage pond — an area where used nuclear fuel is kept cool and that "radioactivity is being released directly into the atmosphere." Long after the fire was extinguished, a Japanese official said the pool might still be boiling, though the reported levels of radiation had dropped dramatically by the end of the day.
...Late Tuesday, officials at the plant said they were considering asking for help from the U.S. and Japanese militaries to spray water from helicopters into the pool.
(Here the article apparently shifts from fuel storage to reactor discussion:)
That reactor, Unit 4, had been shut down before the quake for maintenance.
If the water boils, it could evaporate, exposing the rods. The fuel rods are encased in safety containers meant to prevent them from resuming nuclear reactions, nuclear officials said. But they acknowledged that there could have been damage to the containers. They also confirmed that the walls of the storage pool building were damaged.
Experts noted that much of the leaking radiation was apparently in steam from boiling water. It had not been emitted directly by fuel rods, which would be far more virulent, they said..."
http://news.yahoo.com/s/ap/as_japan_earthquake
  • #157
Japan rocked by fresh blast at Fukushima nuclear plant• New explosion at Fukushima's second reactor
• Partial meltdown 'may be underway' (How was this conclusion made??)
• Tokyo asks international community for help
Share887 Justin McCurry in Tokyo, Tania Branigan in Beijing and Ian Sample The Guardian, Tuesday 15 March 2011
Non-essential technicians were evacuated from the facility after radiation levels around the Fukushima No 1 power plant briefly rose four-fold in the wake of the blast, which appears to be the most serious to date.
The plant operators said its reading had reached 8,217 microsieverts per hour – described by broadcaster NHK as equivalent to eight times the radiation a person would usually experience in a year. It later fell sharply, the broadcaster said. The peak was still far below the level which would cause immediate damage to health.
http://www.guardian.co.uk/world/2011/mar/14/japan-nuclear-fukushima-third-reactor
  • #158
High radiation levels in and around the plant can be partially caused due to the use of seawater to cover the RX core and the production of short lived thermal neutron Sodium activation. Activated Sodium gives off a healthly gamma. Some can be carried off in the off-gasing from the Dry Well or leaks from the Torus. Fission fragments and noble gases will be the primary source of radiation.
  • #159
Dear Astonuc:
"The SFPs could be at risk. We are lacking the details on their status."
Try an educated guess. Didn't Building #1 and #3 completely explode? Where are the spent fuel rod pools? Are they in the core container or outside of it? We know they are just below the roof, which incidentally has been vaporized. After these massive explosions, we are to believe that these pools are intact. How many rods in each pool, 3000 maybe? We are also to believe that there has been no loss of containment but somehow we are detecting increases in ambient radiation levels. So which one is it? Where is the radiation coming from? Where are the elevated levels of cesium and iodine measured outside the containment coming from?
In the larger explosion of Unit #3 the smoke is clearly dark and there are massive chunks of debris (core perhaps) flung 3000 ft. in a couple seconds. The initial explosion at #3 is an orange and black cloud (doesn't look like hydrogen combustion to me). The building is gone, but we are to believe that there is no damage to containment or any of the machinery that would allow for emergency response. Didn't the problems start with the impact of the tsunami? Do you think the containment vessels were tested for a 7.0 or an 8.0 earthquake, let alone a 9.0? I don't know of any of these tests from GE or the Japanese themselves on the Mark-I design. Do you? What was the Richter equivalent to the core containment of a massive building explosion all around it?
No amount of technical word play semantics can diminish the seriousness of what is going on. All this talk about low levels of radioactive contamination is irrelevant. The problem will get much, much worse before it gets better, if ever. Our governments will continue to downplay this disaster even when people are puking in the streets and cancer rates 10-15 years from now explode.
We had the same word play around the Chernobyl disaster, and to this day we are still finding out the massive health effects from that. It will be the same if not worse with Fukushima.
Expect full meltdown of all reactors at Fukushima. It's game over for Fukushima.
  • #160
Sure would like to see the radiochemistry results from the reactor vessel, drywell, torus, and secondary containment. Hope their reactor accident and core coolant sampling system perform as designed. My hat really goes off to the operators in that they must have nearly soiled themselves during the violent explosions that surely rippled through the control rooms and remote control stations. Truly an unprecedented occurrence that is not in the reactor operator training mock ups.
  • #161
Xe, Kr, Cs (radioisotopes of Xe decay to Cs), and I would be coming from the fuel; they are fission products as well as decay products. According to the limited schematics, the spent fuel pools are in top the reinforced containment structure, but the water is exposed to at the surface or floor of the metal structure that was damaged in the explosions. If the water remains, it's not a problem. If the water evaporates then there could be additional release of gaseous and volatile fission products. The concrete containment is intact, but they have been venting steam with fission products to relieve pressure in containment, so that the containment doesn't fail.
The orange flame would be the case where combustion wasn't stoichiometric - i.e., it's not a pure mix of hydrogen and oxygen. There is nitrogen and water vapor as well, and maybe some Xe and Kr. The massive chunks of debris was the sheet metal and insulation, and whatever has accumulated on top of the roof - e.g., dust.
The containment held in the quake - as far as we know. The reactors scrammed. The EDGs operated for one hour. However, the problem arose when the fuel system was compromised and the EDGs lost their fuel supply, or water was transferred into the EDGs. They stopped. Then the batteries ran for sometime, but were depleted. I lack the details of what happened after that.
No one here is playing semantics or diminshing the seriousness of the situation.
The Russians certainly minimized Chernobyl. I have not heard anyone here minimizing the Fukushima event. However, you've made unsubstantiated conjectures.
How bad it could or will get depends on the source term (which is currently unavailable to those of us outside the plant) and what happens between the core and the environment.
It is a very serious situation. However, we can do without the sensationalism and unsubstantiated conjecture.
  • #162
the spent fuel pools are in top the reinforced containment structure...,
Ah, now I see how the media got things mixed up...I thought they would be outside...
Is storage within the containment structure pretty standard??
  • #163
Truly statements from someone that is "uneducated" at best, and exceptionally in nuclear operations, plant design or health physics, and has no factual idea of what really is going on or the future consequences for the people of Japan. Fear mongering is best left to CNN, FOX, etc., but maybe you can get on full time with them to spout your nonsense.
BTW, just how much worse can it get considering the state of affairs in the other parts of Japan? Answer: Minuscule when compared to the destruction and carnage in the other quake and tsunami stricken areas of Japan.
Dean Chaney, CHP
  • #164
I got an email from the Nuclear Engineering department at my University. They forwarded a message from NEI:
UPDATE AS OF 8:30 A.M. EDT, TUESDAY, MARCH 15:
Fukushima Daiichi
Units 1 and 3 at Fukushima Daiichi are stable and cooling is being maintained through seawater injection. Primary containment integrity has been maintained on both reactors.
The Japan Atomic Energy Agency reported an explosion in the suppression pool at Fukushima Daiichi Unit 2, at 19:14 EDT on March 14. Reactor water level was reported to be at 2.7 meters below the top of the fuel. The pressure in the suppression pool decreased from 3 atmospheres to 1 atmosphere. Radiation readings at the site increased to 96 millirem per hour.
Dose rates at Fukushima Daiichi as reported at 21:22 EDT on March 14 were:
Near Unit 3 reactor building 40 rem/hr
Near Unit 4 reactor building 10 rem/hr
At site boundary 821 millirem/hr.
Kitaibaraki (200 km south of site) 0.4 millirem/hr.
We are working on getting updated information on radiation and dose rates at and near the plant. Station personnel not directly supporting reactor recovery efforts have been evacuated, leaving approximately 50 staff members at the site. Operators are no longer in the main control room due to high radiation levels. Safety relief valves were able to be re-opened and seawater injection into the reactor core was restarted around 1 a.m. EDT on March 15 and is continuing. At Unit 4 on March 14 at approximately 8:38 p.m. EDT, a fire was reported in the reactor building. It is believed to have been from a lube oil leak in a system that drives recirculation water pumps. Fire fighting efforts extinguished the fire. The roof of the reactor building was damaged.
Fukushima DainiAll four reactors at Fukushima Daini are being maintained with normal cooling using residual heat removal systems.
  • #165
Astronuc:
Do I have this right -- I believe so. The cutaway shows an access tunnel where fuel rods can be transported into the reactor (1), lifted by the crane (2) and either transported to one of two pools of water (3), (4), or dropped into/taken out of the reactor vessel when refueling.
In principle, then, if the cooling pools were low on water or dry, either from boiling off water that wasn't being replaced, or from damage and leakage secondary to the explosion(s), the stored fuel rods (are they pictured in (3)?), could overheat in much the same way that the rods in the reactor are overheating -- not at a "critical" level of a sustained chain reaction, but hot enough to potentially damage the metal casings of the fuel rods and release, along with steam, the same contaminants that might be released when steam is vented from the reactor vessel?
It appears from the pictures of Unit 1, that the superstructure damaged was all above the level of the storage pools. I can't find any picture of unit 4 that might indicate whether the pools and rods stored therein are still intact or potentially scattered about.
Edit: Actually, as I look at the rails on the floor for the crane, they don't seem to extend over (4), so that may be a coolant storage reservoir.
  • #166
Here is a nice table that summarizes what is happening
  • #167
this morning when there were reports of 40 Rem/h at the station, and 800 mR/h at the station boundary... what kind of radiation/isotopes might cause that? Short-lived stuff that will decay away quickly? Noble gas cloud type radiation, or particulates? Obviously the levels have come down drastically since then, so does this mean at this point there is a low probability of long-lived ground contamination existing after the emergency subsides?
ie; as it stands now, should people be able to move back home or will there likely be an exclusion boundary long term?
  • #168
I'm just a dumb economist and would love to have someone lay out three scenarios and implications: Best case, Most Likely and Worst Case. So far, it seems like this is a recoverable event and financially manageable but all the reporting I'm hearing makes me want to run screaming to the exits. Thanks. this would be greatly appreciated.
  • #169
Fukushima Daiichi
I can't believe that Japanese authorities still use units like rem and Roentgen. Are you sure these infos are not from Burkina Faso?
  • #170
Do yourself a favor and shut off your TV. NEI has been posting good updates here, http://nei.cachefly.net/newsandevents/information-on-the-japanese-earthquake-and-reactors-in-that-region/ which seem to contain the latest, most accurate information without any of the grossly incorrect, purely speculative, sensational and fear-mongering reporting that you'll find on the major network "news" outlets.
  • #171
Unfortunately the media decided to tell a Hollywood blockbuster story at a time when they could reassure and educate the masses. Just read through this entire thread, it will quickly change your perspective.
In future though, take mainstream populist news channels with a pinch of salt.
  • #172
Which is very scary reading. Operators have abandoned the control room: nobody in the driving seat anymore.
  • #173
DrDu doesn't seem very impressed with the ''scientific data'' being presented on the nei.cachefly.net site.
The reported decline in radiation levels to 60millirems/hr is over 2000 x background radiation levels, suggesting ?? ongoing emissions from the No.2 reactor steam venting? or from a leak in the No.2 reactor containment? or contamination of the ground area by emissions from the No.4 spent fuel pool fire? According to http://english.kyodonews.jp/news/2011/03/78352.html
''The utility firm said later in the day the massive radiation amount of 400 millisievert per hour, or 400,000 microsievert, was recorded around debris in front of the No. 3 reactor and that the material may have come from the nearby No. 4 reactor.''
As far as best, most likely, and worst case scenarios, as economic theory claims, accurate information is costly, especially when agents have incentives to conceal it (http://www.guardian.co.uk/world/2011/mar/14/japan-radiation-leak-cover-up?CMP=twt_gu), so there is not sufficient information to make anything but speculations about most likely scenarios. For best case check the nuclear engery promoters opinions eg http://bravenewclimate.com/2011/03/12/japan-nuclear-earthquake/ and for the worse case scenario see the anti-nuclear environmentalists opinions eg http://www.ucimc.org/content/meltdowns-grow-more-likely-fukushima-reactors .
Seems that the No.1 and No.3 reactors are toast and will have to be de-constructed and recycled. The No.2 reactor may be recoverable after a 3 or 5 year down period for inspection and repair. Haven't seem much about the likely costs ...
  • #174
The advice to ignore populists news channels is what I am trying to do. Hence, this is why I am here. I have read this complete thread and have not found a concise Best case, Most likely and Worst case outcome in layman's terms. Responses so far have not been useful. There is a lot of interesting info here but its is fragmented. Could really use the help. Thanks
  • #175
Summary of each Fukushima Daiichi NPP reactor as of late Tue 15th Tokyo time.
http://www.jaif.or.jp/english/news_images/pdf/ENGNEWS01_1300189582P.pdf
Looks like No.2 is being cooled with seawater -- so will be non-recoverable.
  • #176
I wonder how much function they actually lose by abandoning the control room. It seems the site is still in "blackout", with no off-site or on-site electricity available to power any RHR or ECCS pumps or systems. Additionally, from reports it seems that their instrumentation is questionable as well, (RPV/containment level vs. pressure vs. radiation not agreeing). I am guessing that their current priorities are to make sure they keep the portable fire pumps fueled, ensure adequate seawater in the suction pit for the pumps and make sure they vent containment/RPV so as to prevent an overpressure situation and keep pressure low enough to be able to keep on pumping into those areas. On top of this they maybe trying to figure out how to get water back into one, or several spent fuel pools to prevent overheating. What's really concerning is unit 2 and the extent of the damage to the primary containment.
God bless the operators and workers still at the site. These people are heroes!
  • #177
Thanks Marwood. These weren't of much use. I'm looking for rational analysis not emotion.
  • #178
The problem is there is not enough information on what has happened or what is currently happening at the site to make any useful predictions.
Additionally, there is no video feed into the reactor. Operators determine the state of the reactor through measurements of temperature, pressure, fluid flow, surrounding area radiation, etc. This information feeds into the control room.
Edited incorrect and speculative comments.
  • #179
If they abandon the control room it is for a good reason. They then go to the emergency remote control room. Most of the fuel within the spent fuel pool has been cooling for 1.5 to 3 years or more. The spent fuel pool does also contain fuel rods that have been removed from fuel bundles due to damage detected during a previous refueling, and reconstituting of a fuel bundle.
Here is a time line html of some interest: http://online.wsj.com/article/SB100...project=JREACTOR0311&articleTabs=interactive"
  • #180
US NRC issues analysis of Japanese actions:
http://www.nrc.gov/reading-rm/doc-collections/news/2011/11-049.pdf"
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
