Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #961
jensjakob said:
163.000 becquerels in soil northwest of Fukushima NPP:
http://www3.nhk.or.jp/daily/english/23_28.html
That is quite bad.?
Looking at the story it gives 163 000 becquerels/kg soil, which from the article I think they took from the top 5cm of the soil profile. The story also gives that 100 becquerels/kg is the upper limit of normal. Normal would be normal left over from 1960s global bomb test fallout I presume, (this would check out with my own experience of surface sediment typcally ranging from 1-200 becquerels 137 Cs/kg sediment).
Other naturally occurring radioisotopes 40K, 238U, 232Th and associated daughter products combined would probably add up to a 1000-10000 becquerels/kg soil I think (this can be considerably higher in some soils/regions) But even in the context of the total surface sediment activity it would appear the added 137Cs activity (I'm assuming it's recent reactor sourced fallout) is raising total soil activity by about 10-100 times..wow.
Makes me wonder about the 90Sr, 134Cs, 131I and other fission products in the soil too :frown:
Soil certainly isn't the only source of radiation to us humans but when I think about the other fallout nuclei that likely are also be present in large amounts in this soil such as 90Sr I'd be concerned. I don't know enough about human exposure issues to judge whether it crosses the line from meh to an increased longterm health risk for local residents though.
Anyone have a better take?
  • #962
[PLAIN said:
http://www.jaif.or.jp/english/news_images/pdf/ENGNEWS01_1300936513P.pdf[/PLAIN] ]
Steam like substance rose from all unit-1, 2, 3 and 4 were observed from NHK’s helicopter.
This is the first time that steam like substance rose from Unit-1. (09:30, March 24)
does not look good
  • #963
TCups said:
Thanks for your comments and translation, jlduh. Interesting Are there any more specific details in the report that might be pertinent?
EDIT: My comments below have been proven wrong by TCups
We are comparing apples with pears!
The radiation map (the pink one) is from Fukushima Daini NPS
Although I cannot read Japanese I can read the numbers on the reactors
which compares with the Daini plant
also http://www.digitalglobe.com/downloads/featured_images/japan_earthquaketsu_fukushima_daini_march12_2011_dg.jpg" confirms this look at the arrangement of access roads.
  • #964
Anton, RenoDeno:
Can you comment why the accumulation of NaCl from evaporated sea water poses such a concern and be more specific about where exactly that accumulation is likely to take place?
Will the irradiated NaCl be highly radioactive and highly soluble in water?
Does anyone know where are the off-shore currents likely to disperse the radioactivity initially?
  • #965
Are you indeed sure?! Look again at the "pink" map. The blocks, I think, indicate the ground space rather than the buildings. I see reactors 1 - 4 lined up in back of the steam turbine bldgs and match the outlying buildings and even the tower to the satellite photo of Daiachi, not Daini. Am I wrong? I must look again, but I don't think so.
  • #966
TCups said:
Anton, RenoDeno:
because the salt crystals will clog the system and encase the fuel rods thus decreasing cooling
capacity, and grind away the impellers of http://www.nrc.gov/reading-rm/basic-ref/teachers/03.pdf" and making these inoperative.
  • #967
Hello TCups
Yes - I edited original post with below sentance
  • #968
AntonL said:
TCups - hat off - you are right!
Also Daini reactor are all inline
Now go back and match the radiation readings to the debris fields we spent so much time on earlier. . .
I must get some sleep.
  • #969
So should I but you guys are so loud your keeping me awake. :rolleyes:
  • #970
Surface winds are due to temporarily turn onshore from the northeast @ the 25th :frown:
  • #971
http://www.cnn.com/2011/WORLD/asiapcf/03/24/japan.nuclear.reactors/index.html?hpt=C1
Nishiyama:
"The "vapor" rising near the No. 1 reactor at the plant is "only natural" and not a cause for alarm, he said, especially since water is now in that unit's nuclear spent fuel pool"
My comment: hmmmm, at least they are now telling us that #1 SFP is SERIOUS hot too... Has it been dry?
If I read the comment squarely, I could argue that he implies that before todays dousing, the pool was dry...
  • #972
2 nuclear plant workers sent to hospital
Japan's nuclear safety agency says 2 workers at the Fukushima Daiichi nuclear power plant were taken to hospital on Thursday after being exposed to high-level radiation at the plant.
The agency says the workers' feet were accidentally exposed to 170 to 180 millisieverts of radiation while they were working in the turbine building of the Number 3 reactor.
A third worker was also exposed to radiation but apparently did not require treatment.
Thursday, March 24, 2011 15:43 +0900 (JST)
http://www3.nhk.or.jp/daily/english/24_39.html
  • #973
The austrian news http://www.orf.at/stories/2049349/2049348/"
The Austrian news service orf.at reports said:
Die Arbeiten I am Atomkraftwerk Fukushima I gehen nur langsam voran: Immer wieder müssen Arbeiter abgezogen werden, weil die radioaktive Strahlung zu hoch wird. „Nach gegenwärtiger Lage dürfen wir nicht zu optimistisch sein“, sagte Regierungssprecher Yukio Edano am Donnerstag auf einer Pressekonferenz in Tokio. Ausgerechnet die Kühlung, die langsam Wirkung zeigt, könnte zum neuen Problem werden.
Translated means:
The work at the nuclear power plant Fukushima I going slowly: Time and again, workers must be withdrawn because the radiation is too high. "According to current situation we must not be too optimistic, " said government spokesman Yukio Edano on Thursday at a press conference in Tokyo. Of all the cooling, showing slow action might become a new problem.
Is he referring to salt problem addressed earlier - and what does "we must not be too optimistic" mean?
  • #974
Jens - that would be the building in front of Unit 3 with the holes in the roof (and with radioactive debris now on its floor?).
http://s306.photobucket.com/albums/.../?action=view&current=Picture2-3.png&newest=1
  • #976
Lots of information was release regarding the situation at the plant this morning (GMT)
I'll try to get a proper translation...
The Underground of the turbine room linked to the unit 3 was flooded with 30 cm watter , the worker doing stuff there related to pump had there feet in the watter "radioactive" those were the worker rushed to the hospital (radiation exposure about 180 mSv)
edited
  • #977
  • #978
jensjakob said:
How can ANYONE go into a building with water in the basement below a reactor and SFP being cooled by dousing - and not think "WOW - bad idea, bad idea"?
Where are the disaster-management in this NPP?
I could accept it if they were working in the basement (high risk), and a pipe rupture - that would be an accident - but if the water was there already - then I read this setup as a quite bad example of disaster management...
An idea that might even be worse is waiting too long to get the situation under control. I have a feeling the workers were aware that they were taking risks, but were weighing the consequences of further delays. There have been a lot of delays. Delays at this point are not good.
P.S. An NHK spokesman even implied the workers might not be wearing the safety equipment properly, but I doubt that.
  • #979
Well, my personal FEELING is that there is what is being said which (tries to) give the impression that some things are under control, like the personnel management concerning radiations. I'm not so confident with this, but only time will tell the true story and the reality behind this. There are always the words and the numbers on one side, and on the other side there is the "real thing". My work as an environmental expert for court and environmental management teached me that sometimes the two ones fit together. Sometimes.
We live more and more in a world of words, numbers and images, but reality still continue to exist and PREVAIL. With time, the two tend to better fit though. We are all here trying to fit words, numbers and images on a reality which we are not experiencing on the ground (fortunately for us) and this is always a tricky game (especially when these words, numbers and images are not from us but from other people!), we have to recognize the limit of this, even if obvioulsy we still can get a feeling of what's going on.
This moment, like every disaster, is a big come back to reality in a world where virtuality or "augmented reality" (hummmm!) seemed to replace the true experience of reality.
By the way, but i won't go further with this here, the guy talking in the CNN interview has a point of view which is typical of this tendency, as his conclusions is basically that the japanese would rather build psychiatric hospital than a sarcophagus to deal with the health consequences of the accident (to summarize it in a few words!). This is a strange way of dealing with reality. Military troops are always subject to psychic trauma of course but I'm not sure this trauma would be the same if they were fighting moving pixels with electronic weapons actioned by a keyboard/joypad in front of a 30 inch flat screen... This is a strange way of trying to describe the reality, yes.
  • #980
Back to interpreting words and numbers and images, i would like to add this:
1) no doubt the radiation map (whatever the way it arrived on the net, but it "looks" original...) is from the DAIICHI plant. But this has been agreed later by ANtonL. I can GUESS from what's is written that measurement are in millisieverts/h and that the date would be the 20th of March at 17h30.
2) there are other things maybe of interest in the IRSN reports but i can't translate everything of course. One thing is that from the very beginning, they have always added a paragrah in bold letters saying that they are very (i sumarize in a few words) concerned by the risk of cristallization of salt in the reactors which could block various things and reduce the efficiency of the cooling process in the short term. They also urge the japanese to shift as quickly as possible to fresh water cooling (which is obvious!).
3) one thing is clear: a lot of things are not clear! If you read the various statements of various organisations or experts, you find huge contradictions amongst the number of them and over the time being. The situation of the pools is a good example. But this is understandable: autorities are saying things which they think are true, and they may also say things that they know are wrong... If you multiply this uncertainty by the numbers of organisms dealing with the accident in japan but also abroad, you get a idea of the floating world of words and number over the crude reality (back to my previous post). But with time again, the smoke is going to fade and the real picture is going to appear...
  • #981
Personally I am very frustrated by the fear of smoke!, surely working in such radioactive conditions a new appearance of smoke should not be their first reason for evacuation and they should continue the work to cool the reactors and spent fuel.
The smoke indicates exactly where the radioactive particles are being carried (if it's radioactive smoke) and they should only evacuate when dose meters indicate to do so... not just assume that all smoke is going to be radioactive.
  • #982
I do respect your feelings on the subject, but don't discount the ability of the people Japan to rise above simple mortal efforts and achieve the near impossible. For an industrialized nation Japan seems to have retained a very strong sense of community, honor and duty. We could all learn from that as well.
  • #983
jlduh said:
I extracted a "print screen" of the page of interest of the Tepco document with their screwed calculations and conclusions of max wave at 5,7m and a schematic representation of the plant on the platform. T/B is for turbine building, R/B for reactor building. S/B is... i don't know! Safety Buildings (generators)? This will clarify the configuration of the global layout i think.
http://www.monsterup.com
Many thanks. Very interesting.
  • #984
Ok, I'm going to summarize quickly what is said (and especially what is new) in the latest report from IRSN (published 4 hours ago).
( http://www.irsn.fr/FR/Actualites_pr...Seisme-Japon_Point-situation-24032011-08h.pdf
All the daily reports can be accessed from here:
http://www.irsn.fr/FR/Actualites_presse/Actualites/Pages/201103_situation_au_japon.aspx#1 )
1) NEW: the pump for cooling the pool (NOT THE CORE) of N°5 reactor has stopped "automatically" and has now to be repaired. So no more cooling in the pool of reactor 5.
2) NEW: Concerning the reactor 3, they talk about the grey smoke of yesterday and add this sentence:
"Important smoke production has been observed. IRSN is evaluating the potential causes for confinement damages on reactor n°3. One hypothesis reviewed by IRSN is the possibility of the rupture of the reactor vessel followed by an interaction between the corium and the concrete at the bottom of the confinement well".
This the first time the word Corium is put in their reports. Of course everybody knows how serious is this possible scenario (I sent a mail to IRSN 4 days ago about this hypothesis but got no answer so far... except this new sentence of course!), especially when we know that any abrupt contact with a fair amount of water would then probably trigger a big steam explosion (not really different in essence with a phreatomagmatic explosion) with all the consequences we can imagine in terms of radioactive contamination of the air at a certain altitude depending on the magnitude of the explosion and also in terms of "domino effect" towards the rest of the installations and the other reactors. This is my BIG FEAR since the very beginning and would result in a much much bigger mess...
This is only a scenario at this time being, but the scary thing is that they confirm that it is not only a movie scenario it seems.
3) this is not new but i wanted to mention that since their report of 19th March (I double checked when this statement appeared), they consider that the "biological protection over the reactor well n°3 has disappeared" (which is then constantly reported on their satellite picture with annotations added to the report). There is maybe a slight contradiction in their 19th of march report because they both considered in this report:
a) in the paragraph related to the pool: that the "anti-missile protection" (so the concrete plug i think) has been " "probably destroyed" during the H2 explosion of the 14th of March (leading to leaks from the pool and to a reduced maximum water level in the pool).
b) in the paragraph related to the reactor: that the confinement vessel is not leaking
BUT as i mentioned earlier, they modified this last statement in their following reports saying after that the confinement vessel IS leaking (direct leak to the atmosphere).
The words "biological protection disappeared over the confinement well of the reactor" are now constantly put on the annotated satellite picture they include.
4) they also say (not new) that the common pool with 6500 fuel rods (which is the closest building full West of reactor 4) has CURRENTLY NO ELECTRIC SUPPLY and that (new) the japanese injected "by prevention" water yesterday in the pool (which means that some was missing/ evaporating?).
5) concerning reactor n°1 (NEW): they write that the cooling flow in the core has been adjusted to 10M3/h to control the temperature over the core, but that had to be decreased because the pressure in the confinement vessel (which is believed to be intact) was increasing. If this continues, they would need to depressurize the confinement vessel to the atmosphere through the vent.
  • #985
BIG PICTURES AND LITTLE PICTURES
It is (was) so easy to think of ground contamination by radioactive debris in only one dimension - what had been scattered by the blast(s) on the ground surface. Now, another lesson is learned (or forgotten and remembered): whatever the level of building and ground contamination initially, dumping water from helicopters, spraying water from fire trucks, and, I believe rain, will have carried some of it into the ground and ground water. The basement water contamination of steam turbine Bldg 3 that has been pointed out drives that point home. So now, two more problems for those of us who are not nuclear engineers to add to our list of problems (and interrelated consequences) for consideration and speculation:
1) reactor integrity and cooling x 5
2) spent fuel rod storage integrity and cooling x 7
3) airborne contamination and dispersion
4) ground contamination and cleanup
5) salt (NaCl) accumulation in the reactor and cooling systems
6) local ground water contamination and dispersion
7) exposure, protection and decontamination of workers and public
8) the ongoing potential risk of additional damage from new quakes/tsunami's
9) compromise, on a national level, of infrastructure and resources available to deal with # 1-8.
A very dynamic situation. I am sure there are other significant problems to add to the list that I haven't thought of yet, or considered, or prioritized. While this may not yet or ever be the worst of all nuclear disasters, it is certainly a complicated, multifaceted disaster scenario. The folks dealing with TMI and Chernobyl had it comparatively easy in that regard.
  • #986
I been very concerned from the moment I read salt water was going to be used as an emergency coolant. But, I wasn't just concerned about the salt. Sea water contains a lot of calcium carbonate and other hard compounds. Boric acid and fresh water will not dissolve calcium carbonate (almost completely sure). If I'm not mistaken the only thing that will make it soluble is nitric acid (making calcium nitrate) and I don't think anybody really wants to play chemistry set with the reactors.
  • #987
2) NEW: Concerning the reactor 3, they talk about the grey smoke of yesterday and add this sentence: "Important smoke production has been observed. IRSN is evaluating the potential causes for confinement damages on reactor n°3. One hypothesis reviewed by IRSN is the possibility of the rupture of the reactor vessel followed by an interaction between the corium and the concrete at the bottom of the confinement well.
This the first time the word Corium is put in their reports. Of course everybody knows how serious is this possible scenario (in sent a mail to IRSN 4 days ago about this hypothesis but got no answer so far...), especially when we know that any abrupt contact with a fair amount of water would then probably a big steam explosion (not really different in essence with a phreatomagmatic explosion) with all the consequences we can imagine in terms of radioactive contamination of the air at a certain altitude depending on the magnitude of the explosion and also in terms of "domino effect" towards the rest of the installations and the other reactors. This is my big fear since the very beginning and would result in a much bigger mess...
I dot not know how the authorities speak in your country ( i can guess...) but what is sure regarding IRSN is that they have to prepare the public to this eventuallity. Tomorow they will say it is the principal scenario. And if IRSN does not say what is the other scenario it means that it is the only one they have in mind.
it is becomming very bad in my opinion.
  • #988
Please check my post on irsn report (previous page) because I'm completing it with additional infos.
  • #989
It's been a long, long time since I even thought about Ksp (?) - solubility constants in water. But do I remember correctly that CaCO3 is less soluble in warm water than in cold?
  • #990
can someone please explain what is producing this so called neutron ray that's been seen (sorry detected)? There was the mention of 1.5km, so I can only assume that it's been detected 1.5km distance from the plant, in a certain direction?
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
470K
21K
  • · Replies 763 ·
283K
  • · Replies 38 ·
17K
12K
