Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #2,161
Gilles said:
how to say without saying...
http://www.bloomberg.com/news/2011-03-30/record-high-levels-of-radiation-found-in-sea-near-crippled-nuclear-reactor.html
they exclude the possibility of uncontrolled chain reactions , but not of chain reactions ! obvisously , if some occur, they can be only transient and without much power, since the whole thing has not yet exploded. The intrinsic kinetics of chain reactions implies a negative feedback adjusting the level close to near-criticality. I'm not sure that the scenario I sketched https://www.physicsforums.com/showpost.php?p=3214771&postcount=1697" :) ) but something similar should happen if the presence of neutrons in confirmed.
I looked att the graphs (! very rare in Tepco publications) in http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110330e13.pdf
The ratios of the isotope concentrations are varying a bit, but there is no obvious faster decline of the short-lived ones in the last week. Which may indicate that fission is ongoing.
  • #2,162
rhody said:
Thanks curie,
So these methods can detect all radio-isotopes, (plutonium, cesium, etc...) in soft tissue, like the lung, thyroid, etc... ?
Rhody...
A combination of biological monitoring (which is monitoring of the body's output: faeces, urine, saliva, nasal secretions, etc) and direct external monitoring will be able to detect pretty much any isotopes if they have been taken into the body and not already passed through or decayed. There are some more invasive monitoring techniques like lung lavage which are rarely used. Good estimates of body burden can be made. These techniques have been used not only in routine nuclear/rad work & accident/research purposes but for nuclear medicine procedures too so they are well established.
  • #2,164
|Fred said:
thx artax :)
here is the link to the full res http://cryptome.org/eyeball/daiichi-npp/daiichi-photos.zip
VISIBLE MAJOR STRUCTURAL DAMAGES AFTER EARTHQUAKE BUT BEFORE EXPLOSIONS?
@Fred:
The south face of Bldg 1 has a huge diagonal crack. That looks a lot more like possible damage from the lateral thrust forces of a 9.0 quake than an explosion, IMO.
Addendum CORRECTION:
Bloop! There is wasn't. The "What?" that I wasn't seeing before -- shadows from the stairs.
March 12, March 18 images confirm the crack at the base of the south face of Bldg 2. Look closely at the south face of Bldg 4 before the explosion!
Image source for last two images: DigitalGlobe.com
  • #2,166
AntonL said:
The sea water samples with highest radiation levels are taken 330 metres south - the yellow line is 330 metres according to google.
They need to take their samples out on the end of that rock and cement Quaywall extending to the right in the photo..
Looking at the swell action you can see the waves coming in at the bottom of the photo. That usually equates to water coming in from the ocean at that point. The absence of swells right at the plant effluent area suggests water flowing out to sea (path of least resistance. I'm an avid body surfer and know how to look for rip currents.) I am willing to bet that their strongest radioactive contamination will be along that quaywall
  • #2,167
@Fred:
Addendum:
Bang! There it is! The "What?" that I wasn't seeing before.
That looks more like a pipe or some other manmade structure. It's a straight diagonal line with what may be a shadow that makes it look a little deeper.
EDIT: upon closer inspection all I see is a stairway.
  • #2,168
@Fred:
Addendum:
I think your diagonal crack is where the stairs were ... look at building 2 in your first image there.
still examining these fascinating images!
  • #2,169
I think any theories of the cap being blown off reactor 3 can be put to bed now. You can clearly see the steel girder framework largely intact over most of the building. If you look closely at photo "aerial-2011-3-30-0-50-20.jpg" you can see the greenish color of the SFP (at least I think that's it).
  • #2,170
We could really do with a plan veiw of where the reactor is in relation to the cube. Yes if it's in the centre then I aggree but where you can see the green of possibly the crane... which is what I thought it was, there's an obvious hole been blown through everything. possibly the SFP being so heavily built. strong and deep it directed the hydrogen explosion in an upwards direction, piercing like a shaped charge and sending a bit of the roof up.?
  • #2,171
TCups said:
EXTENT OF DAMAGE TO REACTOR BUILDINGS DUE TO EARTHQUAKE?
Have there been any reports of the extent and types of earthquake damage that occurred at other regional NPP's that didn't suffer catastrophic consequences of complete loss of power?
Perhaps this point was already made, but if so, I make it again. A 9.0 earthquake, in and of itself, could do significant damage to the reactor buildings. The scenarios I and others have considered in most detail follow the consequences of complete loss of all power and subsequent events related to the reactor vessels, primary containment, and spent fuel pools.
The chain of events at Fukushima with the rapid arrival of the tsunami and complete loss of power were such that, if done, there has been little or no reporting of a primary assessment of damages or likely damages due solely to the magnitude of the earthquake. Significant lateral thrusting occurred.
I am reminded of the external crack visible on Bldg 2 and must wonder if they are blast or earthquake-related, or more likely, a combination of both.
Also, in cross-section, the arrangement of a massive concrete and steel primary containment structure nested atop a huge underground torus leads me to wonder what damages the quake might have caused by the extreme forces of lateral thrusting where the two structures meet, so to speak.
Some knowledge of the specific types and locations of damages that might have been in play at Fukushima at the time power was lost would surely be helpful in sorting out what has followed.
According to this site, which keeps a running tally, as of my posting time there have been
851 quakes >4M
402 quakes >5M
51 quakes >6M
and 3 quakes >7M just since March 11, 2011.
http://www.japanquakemap.com/
By the time you go to the site it will have increased.
Over the 40 years of their operation how many quakes have the Daiichi plants endured? What ever the number it is remarkable. It may also have taken a toll that would have been very informative to analyze after decommissioning. What we cannot know is if those cumulative stresses brought some components too close to failure to withstand the latest combination of events.
liam
  • #2,172
Yeah, that could be what happened. I'm still a bit puzzled over the #3 explosion. In the video you can clearly see a large fireball come out of the south side (supposedly where the SFP is) and then it gets sucked back in before a large upward blast that seemed more centered in the building. In the photos the roof is pretty much gone over the north and south ends but still over the middle.
  • #2,173
VISIBLE STRUCTURAL CRACKS IN SOUTH FACE OF BLDG 2, 4 - NOT CORRECT
#artax:
Oops. Must agree. Stairs. Shadows account for the apparent differences. Back to the drawing board, I guess. . .
SEE ATTACHED IMAGES:
  • #2,174
AT Fukushima the degree of shaking was not anywhere near a 9.0.
It might have been equivalent to a 6.0 or less.
  • #2,175
Joe you 100% correct , a rip will be set up along the breakwater due to the swell action, the sampling point is such as not to expose the sampler unnecessarily to radiation, you can actually see a track leading down to the beach on the land side. Any way nobody will be body-surfing there for a very very long time, cesium being heavy will settle and embed itself into the moving sand
Body surfing, reading the waves and staying safe in a ocean with 3 meter plus waves is also one of my specialties :smile:
  • #2,176
Concerning the Tcups remark about the possible weak point being at the junction between the torus and the "pear" vessel, especially if you consider the necessity to "float" to some extent for resisting to quakes, as a mechanical engineer i must admit that for me, as i feel it, there is probably a weak point at the radial pipes connecting the torus and the vessel.
The way this design works, which has to be at the same time floating (to be resilient) and very rigid because of the mass of concrete around the vessel to make it resistent from the containment standpoint, is not clear for me...
I saw on several drawings that the torus sits on some strange supports (like fins below it) and I'm wondering if this would be to allow for some movement of it in case of quake? Also i see on this sketch some parts (orange) at the middle of the pipes joining the vessel and the torus: are these some kind of "joints" allowing for some kind of expansion or relative movement?
http://www.netimago.com/image_184623.html
We see these kind of "articulated" joints (or thermal expansion joints) on this picture:
http://i700.photobucket.com/albums/ww1/indoorcarnivore/Browns_Ferry_Unit_1_under_construction.jpg
Something to consider, maybe it has been documented in the past studies, and maybe that was one of the reasons to get rid of the torus in newer designs...
I've seen written that the concerns where about loads at the suppression chamber that were not taken into account in the first design, but it was more about thermodynamic loads it seems (when transient spikes happen in terms of temperature and pressure), that's why they added elements in the SP to diminish the size of the steam bubbles and so the loads. Don't know about the quake loads.
I think you saw this info some days ago, from IAEA revealed by wikileaks:
http://www.indianexpress.com/news/iaea-warned-japan-over-nuclear-quake-risk-wikileaks/763709/
An other remark on the black and white picture above showing the pressure vessel and the torus being built: many many pipes going out of the containment vessel, this is also a weak design from this standpoint.
A different subject with an other confirmation on this plot: the core pressure in reactor N°1 continues to rise dangerously...
http://www.ic.unicamp.br/~stolfi/EXPORT/projects/fukushima/plots/v6/plot-un1-full.png
  • #2,177
DO WE KNOW THE FORCE OF THE EARTHQUAKE AND EXTENT OF POSSIBLE DAMAGES TO THE FUKUSHIMA SITE BEFORE THE TSUNAMI?
Really? References? It would help to know for sure.
6.0 vs 9.0 would certainly have been one helluva difference - what? a factor of 32 for each full point on the Richter scale, correct? or 1024X less powerful at the Fukishima site than the reported 9.0 quake at the epicenter. Maybe.
Is the magnitude on the Richter scale related to the total duration of the quake event? That is, does a "6.0 quake" that lasts for 2 full minutes instead of 30 seconds measure higher on the Richter scale?
Does anyone know what the quake-resistant structure of a NPP might be? It doesn't appear to be a floating slab foundation at first glance.
Is complete loss of the primary power grid and water sloshing out of the SFP in large quantities, dousing one of the workers (as per his first hand account) common in a 6.0 quake? If not, what brought down the power lines or power before the tsunami hit? Didn't I read that the shore line had shifted almost a meter after the quake in some places along the coast?
  • #2,178
I read somewhere actually around 7 for the site
but https://www.physicsforums.com/showpost.php?p=3218366&postcount=1989"
so the horizontal acceleration due the earthquake at Daiichi was 507 gal, 1 gal being 1 cm/s^2 that means an acceleration of 5m/s^2. That is a lot.
  • #2,179
T, I live in southern California. I have been through hundreds and hundreds of 5.0 earthquakes just a hundred miles away that I could not even feel. Distance definitely dampens the effect. Now, if a building is built upon fill or soft soil (clay and water) a building fifty miles from the quake can rock and roll and collapse if it is not structurally sound.
A 5.0 earthquake can bring down power lines if it unleashes boulders from a hillside and they take out the electrical grid transmission tower. Anything like that can happen.
The biggest issue, of course in Japan was that their grid fell apart with all of the nuclear power plants on the north side of that large island going to shutdown mode (SCRAMS) during a part of the day when demand was high. Circuit breakers open and whole regions are without power.
  • #2,180
J:
I lived in Cape Giradeau, MO for 13 years near the epicenter of the New Madrid fault. The fault lines on the west coast of North America, particularly in California, are in a geographic region where the substructure is basically crushed rock. Like Japan, I believe, the fault line is a subduction zone with the Pacific plate diving under the NA Plate. Major earthquakes on the west coast don't have linear propagation of energy for long distances. On the other hand, major earthquakes along the New Madrid Fault are on a substructure of granite, and the fault line is along abutting plates. When they break loose, like in the early 1800, quakes in Missouri rang church bells in Philadelphia. An 8.0 in New Madrid would be an 8.0 in Memphis and St. Louis. I don't know that you can draw the conclusion that the force of the quake was diminished at Fukushima, but in any case, the hard data would be good to know.
You are of course correct about the probable reasons for loss of power.
  • #2,181
Hi, new in this very useful forum.
Can somebody help me understanding what is happening in reactor 1 these days/hours. The Temperature dropped a little, but the core pressure keeps rising. What could be the explanation?
  • #2,182
Some information on TMI Upgrades that Units 1, 2, 3, and 4 should have implemented by TEPCO. There is no reason or information that they did not implement these modifications. This data can give insight to reasons for the uncontrolled hydrogen releases and why reactor vessel water levels could not be ascertained after the Station Blackout hit.
From NUREG-0737, POST-TMI REQUIREMENTS FOR OPERATING REACTORS
http://www.nrc.gov/reading-rm/doc-collections/nuregs/staff/sr0737/final/sr0737.pdf"
These requirements cover, among other things, RPV and Containment relief valves, hydrogen gases control, reactor water level determination, high range radiation monitors in-plant and quantative radiochecmistry analysis off reactor coolants, auxillary feed water system improvements, reactor containment isolation, back up emergency AC and Battery power for possible Station Black Out conditions, etc. Due to the plants experiencing a prolonged Station Blackout, most of the system failed safe.
Excerpt from Table of Contents:
II.F.2 Instrumentation for
detection of
inadequate core
cooling
II.F.1 Accident-monitoring
1. Noble gas monitor
2. Iodine/particulate sampling
3. Containment high-range monitor
II.F.2 Instrumentation for detection of
inadequate core cooling
4. Containment pressure
5. Containment water level
6. Containment hydrogen
  • #2,183
They are pumping more water in.
  • #2,184
Sorry if this subject has already been put to bed. I thought I'd use the latest hi-res images to locate the position of the suspected sf-rods from an earlier video.
So, here they are. Any idea what the feature hi-lighted might be?
  • #2,185
No Idea, How much has the pressure increased or how quickly is it rising, and where are they measuring it... the last I heard (Wiki) they thought 1,2 and 3 had cracks in the containment, or was it the pressure vessel I just read.
Anyone know how high the reactor buildings are...(were!) I want to work out how high that concrete went in the blast at number 3.
  • #2,186
TCups, I can't find the "fuelrods" on the new hi-res images...
Can you?
If they are gone, someone knows what they were...
TCups said:
I have now . . . Here are some enhanced stills from the video.
  • #2,187
https://www.physicsforums.com/attachment.php?attachmentid=33787&stc=1&d=1301584597
Well we've sort of come to the conclusion that all four buildings have the Spent Fuel Pool at the south side of the building/reactor. So if that's true I don't know what those rods are as they are on the North side... but they sure look like the way they were described on Radio 4 last week, about as thick as your finger and 4 meters long!
So maybe they had so many they were storing them everywhere in the less robust tanks around the place. It seems the Americans and no doubt many countries are just saving them up for a rainy day!
It's a shame they can't just hand them out to housholds to chuck in the bath when you need some hot water!
  • #2,188
Fits our latest photography competition perfectly.
Looks like a pipe to me. Tons of pipes around.
  • #2,189
Well they certainly aren't near the sfp. Do we have a schematic to overlay on this aerial photo? Maybe they're other elements used to space-out/organise the actual rods; ie benign?
  • #2,190
@ Jenskabob, I'm pretty sure curious ! has located the place... they're just too small to see.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
