Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #3,091
tadjik said:
Apparently, whatever phenomena increases pressure in reactor 1, it seems progressive.
http://www.ic.unicamp.br/~stolfi/EXPORT/projects/fukushima/plots/v6/plot-un1-full.png
Any hope this could just be some H2O vapor ?
And (if the question has not been raised yet) : 7 atm is a very high pressure, I thought the desin was for 4 atm ... why inject nitrogen under such circumstances ?
Hope this is not a stupid comment...
7 atm, isn't that the reading inside of the RPV!? And I thought the operating pressure in the RPV is something like 10 times that!?
  • #3,092
Thank you.
ps: I'm i the only one with the google doc linked in the article displaying upside down?
  • #3,093
If there is ample communication between the RPV and containment, then the pressure is more or less equal. The RPV is designed to handle much higher pressures (operational ~ 72 atm, but should withstand much higher) than containment (~ operating limit of 4 atm). The RPV is afterall a 'pressure vessel', and containment is only a low pressure container.
  • #3,094
|Fred said:
Thank you.
No - it's copied upside. Just print or flip the pages 180 degrees.
  • #3,095
Firework Colorants
  • #3,096
Has anyone seen an estimate of how much total radioactive material has leaked (or still is leaking!?) or been dumped into the sea? I suppose most interesting is the amount of Cs-137.
Maybe someone here would like to maka a personal estimate?
The ocean is vast but not infinite...
  • #3,097
new http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110406e23.pdf"
a lot of te-129m, but *no* te-129.
any explanation for that?
  • #3,099
It's difficult to say at this point, because the source term (how much fuel has failed) is not well known. And there are 4 units with various degrees of damage.
As for fuel release, it would be useful to find out if there are any detections of:
Nd isotopes, and Ce144, Zr95, Ru103, Ru106, Ba140, Eu154 in addition to the volatile Cs isotopes, which are gamma emitters. Other than the Cs which can easily get out of the fuel because of low melting temperatures and solubility, the others are harder to get out and therefore their presence in the environment would support loss of fuel from damaged/breached fuel rods.
  • #3,100
I expect it is because they are doing gamma spectroscopy to identify elements. Te-129m decays to Te-129 by gamma emission, which is easily detectable. Te-129 is a beta emitter, with lower energies of 540 keV (89%), 350 keV (9%), and others.
Ref: http://www.nndc.bnl.gov/chart/decaysearchdirect.jsp?nuc=129TE&unc=nds
Sb-129 beta decays to Te-129m/Te-129.
http://www.nndc.bnl.gov/chart/decaysearchdirect.jsp?nuc=129SB&unc=nds
  • #3,101
Encapsulation? I can understand attempted purging using nitrogen but encapsulation due to leaks would have to be a continuous inputting, for months. Of course, what the hell do I know.
  • #3,102
Meltdown?
"The fuel rods remain nearly half exposed as the coolant water inside the reactor has not yet risen high enough"
http://www3.nhk.or.jp/daily/english/07_01.html
  • #3,103
But another new weird one: Be-7 at 32 kBq/kg.
http://nucleardata.nuclear.lu.se/nucleardata/toi/nuclide.asp?iZA=040007
I would not trust that result. Natural levels in soil can be a picocurie/cm3 (37 Bq/liter), produced by cosmic radiation.
  • #3,104
|Fred said:
I found this one http://forum.atominfo.ru/index.php?showtopic=575 It's in Russian.. could not make much of it .. but I don't think they conjectured anything like aou Fuel Handling Machine bullet. (speaking of witch we can identify above SFP roof debrit on the ground between unit 3 and 4.
Now my small visit to the Russian board concurred that the blueprint I found on a patent site match Fukushima plant ..
Yahoo Babel Fish will translate the text from Russian to English quite well if you paste in the http address.
(I've only read a few of their threads, but someone there states that only Fuku 1 is if GE mk1 design and Fuku 2,3 and 4 are of GE mk2 design. Here on PF its been established that all Fuku units are of GE mk1, correct?)
  • #3,105
thanks for the explanation.
this means, that if SR-90 would be present, it would not show up. right?
  • #3,106
|Fred said:
Now my small visit to the Russian board concurred that the blueprint I found on a patent site match Fukushima plant .. as they were able to get the file.. 69Megapixel ... I'll just link you to the scaled down version 2mo 17Mega pixel
http://min.us/mvbsHCv
Thank you!
I was looking for such a blueprint for long time.
It is very helpful identifying the crap lying around in the damaged reactor buildings.
Some elements spread better by air than water because of insolubility. Afaik Sr belongs to them, like Pu. Both also have in common that most of the emissions fall down in the near vicinty, little of it travels long distances. But, long term spreading eventually occurs through erosion and wind.
Giordano said:
http://www.tepco.co.jp/en/press/corp-com/release/11040613-e.html
"Injection of nitrogen to reactor containment vessel of Fukushima Daiichi Nuclear Power Station Unit 1"
Thanks, the text explains the negative pressures observed in the reactors with production of hydrogen.
I fear that there will be worrying hydrogen bubbles in the containment for long time, as the schematic does not show where the hydrogen should be vented off.
And they must also take care of not blowing the vacuum breakers...
TEPCO said:
... atmosphere susceptible to reach combustible limit...
Cherry blossoms fireworks?
  • #3,107
jensjakob said:
Meltdown?
explanation to water level -1600 to -2300 which is -62 to -88inches
which is well above active fuel level according to diagram below
(interesting it corresponds to an outlet port of the reactor vessel)
core is exposed at 158" = -4013
http://min.us/mvbjpP8/gallery.zip"
  • #3,108
I apologize for a newbee question, but could somebody clarify what is behind Minimum Debris Retention Injection Rate (MDRIR) from NRC report ?
  • #3,109
|Fred said:
some one mentioned looking to see if other group of reflexion came up with different ideas..
Could be the print for unit 1
Unit 2,3,4 as well as unit 5 re improved Mark1 1100MW design and
Unit 6 is a Mark 2
[PLAIN]http://k.min.us/imBdts.JPG
  • #3,110
The schematic shows the active core is 150" tall. This is almost 4 meters.
If "half covered" means a water level of 1600-2300mm (equivalent to mentioned 62-88"), then could this mean that Tepco counts "water level" from top of active zone down?
And, this and the melting of the upper core in mind, could this mean that in fact most of the fuel is now underwater, in form of a melt cake as it happened in TMI?
A melt cake lying on the RPV floor?
Well insulating its liquid, convecting violently hot corium by a fragile ceramic crust from the water?
And so creating the imminent danger of steam explosion if the crust cracks and tons of liquid corium and water get in touch?
Or softening, eroding and bulging the steel RPV until failure point is reached?
Maybe already corium already began dripping/flowing thru control rod borings into the containment vessel causing this mysterious pressure increase observed?
What happens if this mass breaks through the RPV floor?
Remember, in TMI the RPV cracked and almost broke at a hot spot, as you can verify impressive photo on page 30 on this interesting presentation: http://www.tec-sim.de/images/stories/severe-accident-phenomenology.pdf (Very interesting link, I think i found it about 1000 posts earlier in this thread)
  • #3,111
I'll give you some what ifs...I live near a shipyard (worked there once for a month) and the noise(s) on that Unit 3's launch soundtrack (even though I can't confirm it to be the matching soundtrack), before the flash and after the fallout, has the same sounds that emanate from a shipyard. I guarantee that a shipyard has metal structures make dwarf this nuclear contraption...with that in mind, first sounds on video are after our pressure capsule has/is venting to oversize metal doughnut echoing inside metal voids, water flashing to steam taking place, more venting then a explosion (probably hydrogen) releases any captured water bound nuke particles in the doughnut to air which gets caught in the updraft. Flash in video doesn't necessarily have to be an explosion, could be a burn. More water to steam flashing until water source is exhausted (take that both ways, up and sideways through constrictions). Finally last metallic sounds (lack of a better description) on video is either the crane beam landing or vessel and torus interacting or both. When I mention red cloud, I think you know what I mean. Our capsule survives but resembles a sieve, flight time unknown.
http://www.youtube.com/watch?v=nw2Aw3komgc"
Thanks for the tolerance.
  • #3,112
Yes. The RST assessment believes that recirculation pump seals may have failed.
  • #3,113
Based on footnote 2 for RPV water level in the status updates: http://www.nisa.meti.go.jp/english/files/en20110404-5-1.pdf
it seems to indicate that the zero reference is at the top of the fuel strings and thus anything negative means exposed fuel elements?
  • #3,114
FK-I Units 1-5 are MK I containment, but FK-I Unit 6 is Mk II.
Unit 1 is a BWR/3, Units 2-5 are BWR/4 and Unit 6 is a BWR/5.
  • #3,115
I believe that MDRIR is the minimum flow rate to keep the bottom plenum of the RPV flooded such that any core debris does not melt the RPV shell. I'll try to confirm that.
  • #3,116
RealWing said:
... zero reference is at the top of the fuel strings and thus anything negative means exposed fuel elements?
That is my understanding too.
  • #3,117
I also found that one : http://www.tiede.fi/keskustelut/geologia-maa-meri-ja-ilma-f7/japanin-tsunami-ja-ydinvoimalaonnettomuus-sen-jatkona-t50031-2415.html which is in Finnish.
  • #3,118
I was talking somewhere else about control rods, in other designs I was reading if the power is cut as the control rods are attached at the top by electromagnets, the rods will fall back into the reactor and shut the reaction down, whereas on BWR's the rods are inserted from underneath by gas pressure. I assume that the control rods must be mounted fairly rigidly to enable them to line up with the fuel assemblages. If these things are true, let us say you have a partial core meltdown, now I was reading somewhere else that the melting point of the fuel rods is about 1800 C whereas the melting point of the control rods is around 2500 C, So in another type of reactor, the detached control rods would fall into the molten fuel mix as the structure of the rods melted and collapsed. but in A BWR if all is as I've put together, as the fuel melts you'd get less and less of the control rods moderating the reaction as the fuel slumps around the vertical rods.
Am I missing something obvious? or will the molten fuel start to react more readily as the moderation gradually disappears due to height and distance?
  • #3,119
"Tsernobyl muuten oli reaktori joka pystyi tuottamaan aseplitoniumia."
Yep, that is Finnish alright. They are behind this board in summation. Above, I can easily identify Chernobyl...Reactor...Plutonium.
  • #3,120
Fascinating!
1) those three bangs are definitely not echoes, and
2) the sound track contains more information than the video.
Thank you for the post, very much.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
