Classical and Quantum Mechanics via Lie algebras
This thread discusses the concepts presented in the draft of a book titled "Classical and Quantum Mechanics via Lie algebras," focusing on the thermal interpretation of quantum mechanics. The discussion encompasses theoretical aspects, interpretations of quantum phenomena, and the relationship between classical and quantum mechanics through the lens of Lie algebras.
  • Some participants express interest in how the thermal interpretation applies to single particles, such as electrons, and suggest that it is generalizable beyond thermal states.
  • One participant proposes that fields should be considered primary, with particles being manifestations of these fields, questioning the traditional particle concept in quantum mechanics.
  • Another participant challenges the validity of Neumaier's interpretation, suggesting it conflicts with modern experimental evidence that supports a probabilistic view of nature.
  • There is a discussion about the coherence of buckyball beams and their ability to demonstrate interference effects, with some participants questioning the feasibility of coherent preparation.
  • Participants discuss the nature of wave functions, with some arguing that electron waves are merely probability waves, while others assert that coherent electron waves are as real as coherent photon waves.
  • Questions arise regarding the role of field operators in determining probabilities and expectation values in quantum measurements, with some participants seeking clarification on how these relate to actual measured values.
  • Neumaier's assertion that all measurements are interpreted as measurements of expectation values is debated, particularly regarding the implications for measurement collapse and the transition from expectation values to actual outcomes.
Participants express a range of views on the thermal interpretation and its implications, with no consensus reached. Some support Neumaier's ideas, while others challenge their validity and relevance to contemporary physics.
Limitations in the discussion include varying interpretations of quantum mechanics, the dependence on specific definitions of terms like "fields" and "particles," and unresolved questions about the coherence of certain quantum states.
A. Neumaier
Insights Author
I'd like to open a discussion thread for version 2 of the draft of my book ''Classical and Quantum Mechanics via Lie algebras'', available online at http://lanl.arxiv.org/abs/0810.1019 , and for the associated thermal interpretation of quantum mechanics, espoused in the book.
The goal of the thread is to obtain reader's feedback that helps me to improve the presentation while I work towards a version for publication.
Abstract: The book fulfils the didactical purpose of showing that
-- quantum mechanics and classical mechanics are much more similar than can be seen from the usual presentations of the subject;
-- in a very significant sense, theoretical classical and quantum mechanics is nothing but applied Lie algebra;
-- quantum mechanics has a common sense interpretation once one takes the thermodynamical findings of statistical mechanics serious in the foundations.
The content of the book is fully mainstream, covering hundreds of publications by others (301 references, too numerous to include them into this opening post), including many references to basic experiments. However, the selection and presentation of the material is very different from what one can find elsewhere.
The importance of the topic is obvious. With exception of the thermal interpretation, nothing is new about the scientific content. The presentation of the book is in intelligible English, complemented by LaTeX (some of it only intelligible by intelligent readers). With exception of historical evidence (and perhaps oversights), everything is defined or derived with mathematical rigor. The empirical equivalence of the presented material to standard mechanics is manifest, and almost the whole body of experimental physics supports the theory presented. [If this paragraph sounds a bit crackpottish - I am required to state all these things in order to conform to the submission rules.]
The thermal interpretation of quantum mechanics was presented first last year in a lecture whose slides (Slide 23-34 define the interpretative core) are available at http://arnold-neumaier.at/ms/optslides.pdf , which in turn is based on insights from Sections 8.4 and 10.3-10.5 of version 2 (or Sections 5.4 and 7.3-7.5 of version 1) of the above book.A short exposition is given in the entry ''Foundations independent of measurements'' of Chapter of my theoretical physics FAQ at http://arnold-neumaier.at/physfaq/physics-faq.html#found0 . See also the following PF posts:
https://www.physicsforums.com/showthread.php?p=3246436#post3246436
https://www.physicsforums.com/showthread.php?p=3187039#post3187039
https://www.physicsforums.com/showthread.php?p=3193747#post3193747
how does the thermal arise for a single electron.
The thermal interpretation does not only apply to thermal states; it is completely general.
I suggest that you begin by reading the slides http://arnold-neumaier.at/ms/optslides.pdf
where the interpretation is explained for a single photon. The electron is essentially the same, except for the different state space.
This post contains replies to posts 1-7 from https://www.physicsforums.com/showthread.php?t=490677
I'll comment on the later posts at another time.
rodsika said:
can you pls create a more layman friendly introduction to it like describing in detail how it explains buckyball made up of 430 atoms that can still interfere with itself?
rodsika said:
One major idea being put forth by Neumaier is that fields are now primary and particles are just momentum of the fields. So particle concept is now outdated and there is no sense of thinking of the double slit experiment as particle that moves in between the emitter and detector but more like field interacting in between (perhaps like Feynman interaction vortexes). If that is true, then the buckyball composing of 430 atoms can be considered as field too.. but does it make sense to think in terms of 430 atom buckyball field??
If a beam of buckyballs is coherently prepared so that it shows interference effects (which is not easy at all - typical buckyball beams are not coherent)
then its quantum field oscillates in a wave manner.
unusualname said:
A Neumaier is clearly a very erudite and impressive scholar, but his interpretation is unlikely to be correct as modern experiments urge a fundamental probabilistic character to Nature which his interpretation is not in agreement with.
Why not?
unusualname said:
He is a genius clinging to old school deterministic ideas about nature
The thermal interpretation explains the conditions under which a stochastic interpretation of QM is valid, the conditions under which a determinstic interpretation is valid, and the conditions under which neither is valid.
See Chapter 10.3-5 of version 2 of the draft of my book.
No other interpretation can do that.
unusualname said:
And also I'm not sure he should be allowed to promote such a non peer reviewed philosophy so strongly on these forums.
about 10 of my over 1300 contributions to PF mention the thermal interpretation. Everything else is orthodox physics.
unusualname said:
the interpretation stuff is really not scientific
Before making such unsupported negative comments you should first read and understand what my interpretation consists of.
rodsika said:
Arnold, can you please write a Wikipedia article about it and give the basics
I write here, and leave Wikipedia to those active there.
rodsika said:
as your articles are so vague and disorganized.
where the interpretation is explained. They contain the material of a well-organized lecture in which nothing is left vague.
rogerl said:
Neumaier gives example of beam of photon. But a beam of photon has real wave, whereas electron wave is just probability wave. So one can't argue whether before observation, a beam of photon is there or not. It has real wave. Whereas matter waves are not actual waves.
Coherent electron waves are as real as coherent photon waves, as the many interference experiments show. In QFT they are actual waves in the most real sense of the word.
rogerl said:
Feynman mentions in his book "The Strange Story of Light and Matter" about reflections of light. He said that in reflections in a glass, 4% of the photons are always deflected. How do the photons know how to be 4% Feynman asks. What I want to know is, can reflections be done with matter wave too like electron wave such that you can also see 4% of electron being deflected?
Electron fields are not so different from photon fields as you might think. There is a whole discipline of physics called electron optics http://en.wikipedia.org/wiki/Electron_optics where the optical properties of electrons are studied in close analogy to the optical properties of light.
JesseM said:
would the field operators at a given point in spacetime give the probabilities or expectation values for the outcome of some measurement at that point?
The field operator evaluated at a point x in space-time defines the probability distribution of the magnitude of the quantum field at that point. But field operators are only distributions, not ordinary functions, which means that only smeared values of the field make sense. What is measurable is usually the expectation value of the field smeared over the region in space time determined by the active part of the detector and the duration of the measurement.
JesseM said:
Neumaier goes on to say that expectation values are the basic elements of his interpretation:
Yes. In the thermal interpretation, _all_ measurements are interpreted as measurements of expectation values.
JesseM said:
But if he wants to avoid collapse, how does he go from expectation values to actual measured values of microscopic systems? (or macroscopic 'pointer states' associated with those measurements)
Here is the main difference to the traditional interpretations.
The thermal interpretation doesn't change anything in the theory. What is changed is _only_ the interpretation of measurements. All measurements are primarily measurements of the macroscopic object that is actually inspected when measuring something.
To be valid, any inference about the value of some microscopic object must be
(ideally) backed up by an argument that the microscopic object influences the macroscopic object in a way that the observed macroscopic behavior results.
Leaving aside the interpretation, and looking instead at how you formulate QM,
starting with an algebra of observables, then states and relying on a list of
axiomatic (Whittle-style) properties of expectations, I'm wondering whether one
can indeed account for all features of QM that way...
Consider the Cauchy (or Breit-Wigner) distribution that gives the probability
distribution of the lifetime of unstable particles. The usual expectation, variance,
etc, are undefined for that distribution but it's clearly an important part of quantum
physics. How then do you get a Breit-Wigner distribution if you've started the
theory from expectations?
Only _bounded_ quantities _must_ have an expectation. For unbounded quantities the expectation need not exist. Thus (as in C^*-algebras), one can always go to the exponentials e^{is A} of a self-adjoint but unbounded quantity. in probability theory, the function defined by the expectations f(s):=<e^{isa}> is called the characteristic function of A. it completely characterizes the distribution of functions of A, and is the right thing to study in case of cauchy-distributed A.
This post contains replies to the remaining posts from https://www.physicsforums.com/showthread.php?t=490677
JesseM said:
But Neumaier says that his interpretation "acknowledges that there is only one world", and that it "is consistent with assigning a well-defined (though largely unknown) state to the whole universe", shouldn't that mean the interpretation has to give more than just a collection of probabilities for different states at different points in spacetime, since in our "one world" we see "states" consisting of definite outcomes rather than just probabilities?
We see definite outcomes whenever we look at a system large enough that the assumptions of statistical mechanics apply. In particular, this holds for all the things that are _actually_ measured, such as pointers of instruments, colors of pixels on a screen, developped photographic plates, sounds in a Geiger counter,
currents in a photodetector.
We _infer_ from these raw measurements properties of systems that we cannot ''read'' directly, and the inference is as good or as bad as the causal link provided by quantum mechanical theory in the respective case.
JesseM said:
But there are plenty of cases where var(A) would be large even for macroscopic systems, like the state of macroscopic "pointers" which show the results of experiments on quantum particles
Yes. This implies that the macroscopic pointer gives only unreliable information about the quantum particle, unless many repeated measurements are made under sufficiently idenitcal conditions.
rogerl said:
Do you guys agree that the Ensemble Interpretation (a requirement for Neumaier Interpretation) is already falsified?
The thermal interpretation does not _require_ the ensemble interpretation.
Instead, it gives the conditions under which an ensemble interpretation is valid.
See Section 10.3 of my book.
rogerl said:
I presume that the Ensemble Interpretation is the same as the Statistical Interpretation?
Yes.
rogerl said:
Both these can't handle single system. But Neumaier Interpretation (actually not an Interpretation but just a QFT way of looking at it or from a QFT point of view) can handle single system. Why is that Neumaier's can handle single system while the Ensemble and Statistical can't since they are identical? What are the differences?
The difference is that I discard the so-called eigenvalue-eigenstate link,
and give the quantum expectation a different interpretation. See Sections 10.3-10.5 of my book.
JesseM said:
if Neumaier's interpretation only gives probability distributions for such macro-states rather than definite values,
It gives definite values to macroobservables of macrostate, within some tiny uncertainly level.
JesseM said:
the simulation yielding a series of macroscopic pointer states whose overall statistics should match the results of analogous experiments performed in the real world. If we require that the simulation be a "local" one
A valid simulation must be as nonlocal as QM itself.
JesseM said:
So, I think it's misleading to call Neumaier's interpretion a "local" one
It isn't local; I nowhere claimed that. The thermal interpretation shares all nonlocal features with orthodox quantum mechanics.
Thanks. I still have more questions but let me ask you this. I understand you that you claim that the wavefunction and its derived probability is not real in standard QM interpretation, it is just a mashinary to interpret experiments. But, in QFT and QM any time we want to calculate something (like energy) we take the whole wavefunction into account which to me it says that all aspects of wavefunction (at least the probabilities) is real and it exists at the same time. Am I saying things correctly?
Quote from chapter A5 section 1 -
"Note that a measurement does not need a conscious observer.
A measurement is any permanent record of an event, whether or not
anyone has seen it. Thus the terabytes of collision data collected
by CERN are measurements, although most of them have never been
looked at by anybody."
Consider a "Schroedinger's cat" scenario - the particles generating the tracks and the "permanent record" are inside an isolated box - How is the "permanent record" described by a scientist outside the box? I expect it would be a mixed state, but does this mixed state constitute a measurement?
qsa said:
I understand you that you claim that the wavefunction and its derived probability is not real in standard QM interpretation, it is just a mashinery to interpret experiments. But, in QFT and QM any time we want to calculate something (like energy) we take the whole wavefunction into account which to me it says that all aspects of wavefunction (at least the probabilities) is real and it exists at the same time.
In the standard interpretation probabilities are not observables, but propensities for observing something.
This makes the standard ontology quite weird.
In the thermal interpretation (as in real life), many expectations are measurable (to some limited degree of accuracy), and so are many probabilities (as expectations of projectors). Thus these are real in the thermal interpretation, making things much more intelligible.
A permanent record is typically a macroscopic state in local equilibrium, changing so slowly that the techniques of statistical mechanics are applicable.
Whether it constitutes a measurement depends on one's definition of a measurement. The thermal interpretation has the huge advantage that one doesn't need to know what a measurement is, and still has a perfectly valid interpretation. Measurement is a difficult subject, so it should not figure in the foundations.
A. Neumaier;3247879[B said:
Abstract:[/B] The book fulfils the didactical purpose of showing that
I have positve criticism of your abstract in presentation. Consider me just a reader, trying to understand and see if I am interested in reading further.
didactical
I'm a physicist not a philosopher, so I need some added reminder or hint about what didactic means.
Give an example with motivational argument to show similarity. Get rid of the (--) and use standard English.
-- in a very significant sense, theoretical classical and quantum mechanics is [sic.: are] nothing but applied Lie algebra;
Again, show by comparison of the usage of Lie algebra's in classical and quantum physics to motivate comparison.
This one is a giant step. You need more motivation for making this claim within your abstract. Give a few more details and defer it to the main body of the text using a phrase such as "as will be demonstarted". This should be a good half of your abstract.
I hope this helps on the frontier of written communication.
http://en.wikipedia.org/wiki/Didactic_method
This is done leisurely in Chapter 1 of the book, and comes across at many other places in the book. The abstract is not intended to make looking at the actual text. superfluous. It just summarizes what someone can expect to get out from reading the book.
In a nutshell:
Poisson brackets define Lie algebras. Commutators define Lie algebras.
But to appreciate how far this goes, you need to study the book, not the abstract. It will be worth your time.
Phrak said:
This one is a giant step. You need more motivation for making this claim. Give a few more details and defer it to the main body of the text using a phrase such as "as will be demonstrated". This should be a good half of your abstract.
The main body of the text is the whole book. Innovations on old subjects can usually not be described in a few paragraphs. Please criticize the book (or the FAQ, or the lecture quoted), not the abstract.
A. Neumaier said:
An electron behaves as a particle only in situations where an approximate semiclassical description is applicable. This is _not_ the case for a tightly bound electron such as in an ordinary atom or molecule, but it is often the case for an electron in a beam, when one doesn't aske too detailed questions. (Electron beams in full generality are treated in electron optics, where the Dirac equation is treated as a classical field.)
Depending on the preparation, you may regard it as a particle before it passes the screen, but afterwards no longer - passing the screen turns the electron into a delocalized object - the more delocalized the further away from the slits.
Indeed. There is no quantum mystery.
Not as a fundamental quantum law. But the Born rule has limited validity, which can be discussed in the framework of the thermal interpretation.
Talking about it hear is the first part of spreading it. I am gathering experience in how people respond and what must be said to make the case. For publishing it, the Scientific American is not the right place - this is a journal for expaining things to the interested public, not for describing new results to the scientific community.
But sooner or later, my thermal interpretation will be published - a full, convincing account of it is not written in a few pages, but takes time.
And in 10 years time, it will be the consensus of the scientific community, since unlike with all other interpretations, there is nothing weird about the thermal interpretation.
Varon said:
Let us focus on the double slit experiment as Feymann said it's the main mystery. If it's solved, the entire quantum mystery solved.
I can't understand what you meant by "passing the screen turns the electron into a delocalized object". You said the electron is a particle before it passes the screen. Since it is already a particle, how can it turned into a delocalized particle at the screen?
The electron is always a quantum field. The quantum field can be regarded to describe a particle if and only if the field has a nonzero expectation only in a region small compared to the whole system considered. Thus we may say that the field is a particle as long as this condition is satisfied. Because of the dispersion of the field caused by the slits, this condition stops to be satisfied almost immediately after the field (with support large enough to cover both slits) passed the double slit. Thus it is no longer justified to talk about a particle.
The situation is similar as with a sphere of glass. If you throw it, you may regard it as a particle. But if it hits an obstacle and fragmentizes, it is no longer localized enogh to deserve the name of a particle.
Varon said:
Let's go from the beginner in the emission. So the electron is emitted. You believed it travels as particle? But where does it pass, the left or right slit? And what caused the interferences in the screen. Standard explanation says it interferes with itself because it is a wave after it is emitted.. and only become a particle at the detection screen. Pls. elaborate what happened to your electron after emission.. before it reaches the slits.. after it exits the slits and after detection in the screen.
The field passes the doulbe slit in a fashion similar as a water wave would do, except with quantum corrections.
Interesting. But how come the detector detects one electron and not the fragmentized parts (after passing thru the slits)?
The quantum field does not fragmentize like a broken glass sphere. It just expands into a superposition of two spherical waves. The outer electrons of the detector respond to the incident quantum field by an approximate Poisson process with rate proportional to the incident density. This accounts correctly for the simple statistics obtained for an ordinary electron beam. See post #4 of this thread, and the longer discussion of the case of photons in
and in the thread
https://www.physicsforums.com/showthread.php?t=480072
and in the thread
What "outer electrons"? I'm talking about single electron. So when your single electron is emitted. It is a particle before reaching the slits. After it reach the slits. The single electron become delocalized or spread into a field. Now the mystery is how the detector is able to detect single electron again. So don't talk about "outer electrons" in the detector because we are only dealing with a single-electron at a time double slit experiment. Pls. explain what goes on between the slits and the detector and how the detector only detects one electron. My example is not the same as your electron beam and statistics for the ensemble. I'm referring to a single electron emission and detection.
This is an improper question. Only in classical physics can you describe what goes on, because you can make a measurement of what goes on which does not affect the outcome of the experiment. In QM, you cannot, so you cannot know what "goes on". To ask a question for which there is no answer is improper.
But in Neumaier Interpretation, everything is taken into account. It is enhanced quantum-classical hybrid where he can precisely state what happens in between. This is not your typical QM, that is why Neumaier said his model wil someday rock the world and be part of textbook and face out the Copenhagen and other interpretations.
I have not read all of the web page at http://arnold-neumaier.at/physfaq/physics-faq.html - should I keep reading this to find what you are saying or do you have another source?
Just try to understand Neumaier version of the double slit experiment. Here he can model precisely what happens in between. This is in contrast with orthodox QM where we don't know.
The detector wouldn't be able to respond if it hadn't loosely bound electrons that could be freed when responding to the impinging quantum field formed by your single electron. The response of the detector to the field is a multibody problem, and solving it in the semiclassical approximation gives the desired effect.
Are you saying your interpretation only work for an ensemble of electrons? I want only one electron at a time. What do you mean "The detector wouldn't be able to respond if it hadn't loosely bound electrons that could be freed when responding to the impinging quantum field formed by your single electron." Please rephase it in clearer words. As I understand it. The emitter emits one electron. After it pass thru the slits, it became smeared. Now how does the smeared field converge back into a single electron detected at the screen?
No. I am considering your situation: precisely one elctron moving theough the double slit. But once this electron reaches the detector is meets a host of electrons in the detector. The latter are responsible for the measurable response (since ultimately a current is measured, not the single electron).
It doesn't. It remains smeared. But one of the electrons in the detector fires and (after magnification) gives rise to a measurable current.. This will happen at exactly one place. Thus it _seems_ that the electron has arrived there, while in fact it has arrived everywhere within its extent.
If a water wave reaches a dam with a hole in it, the water will come out solely through this hole although the wave reached the dam everywhere. A detector is (in a vague way) similar to such a dam with a large number of holes, of which only one per electron can respond because of conservation of energy.
But your theory doesn't explain one electron at a day double slit experiment or in instance where only one buckyball is sent out in a year. It still interferes with itself. Because after 20 years. The 20 buckyball would still form interference patterns added up one year at a time.
Hence your model may not tally with reality.
Each electron capable of responding has a response rate proportional to the intensity of the incident field. This is enough to correctly account for the interference pattern. No memory is necessary to achieve that.
If you send one buckyball a year in a coherent fashion (I doubt that one can prepare this, but suppose one could) then at positions of destructive interference the response rate would be zero while at positions of constructive interference, the resonse rate would be zero except once a year where it would be maximal. Thus it is most likely that the yearly recorded event comes from an electron sitting at a point of constructive interference. After 20 years, one would see the pattern emerging.
Something that puzzles me greatly.
First of all. How many electrons do typical detectors have? Let's say there are a thousand. How can the uniform quantum wave after the slits trigger just one of the electrons in the detectors and not others. How can the principle of energy conservation cause it? Pls. elaborate. Thanks.
That seems incomplete. First of all, it is not a simple matter of a detector registering an electronic "click" ... the actual buckyball molecule impinges on the detector .. its landing position can be measured .. for example if you cooled the detector to very low temperature, and then ran an STM over the surface, you would see the buckyball localized in one place. You could also measure an interference pattern in similar fashion by by running the experiment multiple times.
So, in order for your theory to be consistent, it seems like you need to explain how the wave representing the buckyball can hit the detector "all at once", but then end up with a buckyball localized in just one discrete position. Your proposed explanation is plausible for electrons or photons because they are detected "destructively", but massive particles can be measured in other ways ... how can your theory account for this.
Its more like 10^20.
Each electron feels just the piece of the quantum wave reaching it. The electron responds by random ionization, with a rate proportional to the intensity. It takes the energy from its surrounding.
The detector as a whole receives the energy everywhere, also with a rate proportional to the intensity. This energy is redistributed (fast, but with a speed slower than that of light) through the whole detector, roughly according to hydrodynamic laws.
Thus there is no violation of conservation of energy.
  • · Replies 47 ·
  • · Replies 22 ·
  • · Replies 218 ·
18K
  • · Replies 42 ·
9K
