How Do You Calculate Molar Mass from Concentration Data?
  • Thread starter Thread starter 3riefs
    Concentration
This discussion focuses on calculating molar mass from concentration data using a spectrophotometer. The user successfully tracked absorbance values for various dilutions and calibrated the device with a water blank. Key steps include determining concentration from the line of best fit or linear regression and calculating molar mass by using the number of moles derived from concentration and the mass of the sample.
  • Understanding of spectrophotometry and absorbance measurements
  • Knowledge of linear regression for data analysis
  • Familiarity with molarity and its calculations
  • Basic chemistry concepts related to moles and molar mass
  • Learn how to perform linear regression in Excel or Python
  • Study the principles of spectrophotometry and its applications in chemistry
  • Explore calculations involving molarity and molar mass
  • Investigate data visualization techniques for creating effective charts
Chemistry students, laboratory technicians, and educators involved in teaching or conducting experiments related to concentration and molar mass calculations.
3riefs
Hello! I'm completing a lab for chemistry and would like some help on the last bit figuring out concentration then converting to molar mass. I need to make a data chart with a line of best fit on it with the dependent/independent variables. I understand that concentration is on the X-axis and the absorption is on the Y-axis. I used a spectrophotometer to track the different absorbency values of the different dilutions we made. I calibrated the machine using a "Blank" which was water in a test tube. I made a test solution, then made different dilutions using a stock solution provided to my class.
The observation chart that was produced looked like:
{Solutions}{Absorbency}{Wavelength (Blue)}​
Blank (H2O) 0.00 470nm
Test Sol'n 5g solute/25mL H2O 1.41 470nm
Stock Sol'n 0.83 470nm
0.40 mol/L sol'n 12mL S.S./3mL H2O 0.70 470nm
0.30 mol/L sol'n 9mL S.S./6mL H2O 0.58 470nm
0.20 mol/L sol'n 6mL S.S./9mL H2O 0.40 470nm
0.10 mol/L sol'n 3mL S.S./12mL H2O 0.21 470nm​
**Sol'n = solution**
**S.S. = stock solution**
**[ ] = concentration**
1. How do you find concentration?
2. How do you convert concentration to molar mass?
Read it from the line of the best fit. Or, if you use linear regression, calculate concentration from absorbance. That's the same.
Knowing concentration you will be able to calculate number of moles, knowing number of moles and mass of the sample you will be able to get molar mass.
