Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #6,151
  • #6,152
Rive said:
Ps: now we have enough pictures to make a drawing about the pool and make some count about the assemblies- at least we will know how many were not seen.
Yes. We appear to have seen enough fuel racks to hold the recorded number of assemblies in the pool. Here is a rough lineout of the stacking in the pool, as much as can be gleaned from the two released videos.
  • #6,153
Unit 3 is 314,5C now, this is really big...
  • #6,154
This morning at 0600 it was 202 C :
http://www.tepco.co.jp/nu/fukushima-np/f1/images/00_05080600.pdf
Do you have a link to the source ? I can't find it at the usual locations ...
(and somehow TBS decides to zoom in on unit 1+2 , leaving unit 3 off camera ...)
  • #6,155
Just looking at the stats myself :smile:
Link:
http://www.tepco.co.jp/nu/fukushima-np/f1/images/032_1F3_05081630.pdf"
  • #6,156
AntonL said:
In above table some RPV temperature is exceeding the design limit of 300oC.
Please could a kind knowledgeable person translate the headings
Here's what Google Translate gives for the headers, (change in the temperatures over the last week)
1. N4B Water Nozzle Temperature (93.7 --> 202.1 gr.C)
2. RPV bottom head top (122.3 --> 255.6 gr.C)
3. RPV flange body (99.6 --> 310.1 gr.C)
4. Lower temperature pressure vessel (116.5 --> 151.9 gr.C)
5. RPV stud temperature (98.8 --> 253.6 gr.C)
6. RPV flange body Lower temperature (154.6 --> 173.3 gr.C)
7. Relief safety valve 2-71D Leakage (91.3 --> 158.2 gr.C)
8. Relief safety valve 2-71F Leakage (96.9 --> 108.8 gr.C
9. Main steam isolation valve 2-86A Rikuofu (61.2 --> 63 gr.C)
10. D/W HVH return temperature (101.7 --> 157.6 gr.C)
11. Bellows RPV (137.3 --> 208.6 gr.C)
12. S/C Pool A water temperature (40.6 --> 40 gr.C)
13. S/C Pool B water temperature (40.6 --> 40 gr.C)
  • #6,157
Jorge Stolfi said:
I found this photo somewhere several weeks ago. Google found it again at
http://www.japannewstoday.com/wp-content/uploads/2011/04/FukushimaSpentFuelRodPoolUnit3-1.jpg
By the title, it would seem to be a close-up of the edge of #3's spent-fuel pool, obviously after the explosion, presumably taken by a camera attached to the pump crane. What are those two gray bars at the top left? (They are too smooth and the wrong color to be rebars, and their ends are closed so they do not seem to be conduits.)
I can't see how this motive can be anywhere near the spent fuel pool of unit 3.
It looks more like the edge of a pit or a manhole than a spent fuel pool. For a starter, where's the steel liner?
  • #6,158
Dmytry said:
The cooling water is leaking, which means that they are losing boron, and eventually they will run out of boron, at which point cooling could become impossible as non borated cooling water would cause criticality.
The boron in question is not ordinary boron, but enriched boron-10 which is not readily available.
Why should they use enriched B-11? It would be very expensive and scarce. Natural occurring boron contains 20% B-10 with 80% B-11.
Boric acid H3BO3, Borax Na2B2O7 and even Boron trioxide B2O3 are bulk chemicals and very cheap. (I don't think TEPCO needs high grade qualities anymore ...)
An aqueous solution of the above mentioned chemicals can be prepared either on- or off-site. Really no big deal.
Does anybody know which concentration is needed to effectively absorb neutrons with B to avoid criticality?
  • #6,159
Does anybody know what concentration is needed to effectively absorb neutrons with B to avoid criticality?
From what I've read, boron is used up to a few thousand ppm in the cooling water.
  • #6,160
Link:
The second doc has more readings. The two temps from the first doc map to column #1 and #4 in the second doc. Column #3 has the 300+ C reading but all readings are climbing -- not a good sign.
  • #6,161
One question regarding the SFP #4 video:
There are bubbles rising in the water... where do they come from? Or rather, what's in a SFP that could produce air bubbles?
  • #6,162
Interesting piece of news from Nuclear News concerning the explosion of unit 4:
The building seems to have suffered a hydrogen explosion, but it is possible
that nobody witnessed the event due to a site evacuation prompted by a radiation release from unit 2 on 15 March.
So perhaps nobody has seen the actual explosion?
Nuclear News also offers their alternative explanation:
It may also have been damaged by the explosion at unit 3.
http://www.world-nuclear-news.org/newsarticle.aspx?id=29978
This goes a little bit in the same direction as the https://www.physicsforums.com/showpost.php?p=3289449#post3289449" by AntonL that hydrogen could have been the result of venting in unit 3, except that the explanation of AntonL is better as the explosion of unit 3 and the estimated explosion at unit 4 happened at different time.
At 11:15 JST on 14 March for Unit 3
At 06:00 JST on 15 March for Unit 4
(Wikipedia)
How sure can we be about the time of explosion of the unit 4 if nobody saw it? Could there be even hours of margin in the estimated time and real time if people around there have not been attentive enough? :bugeye:
  • #6,163
Would the rising temp be consistent with a sensor placed just at the boundary between liquid and steam, with a falling liquid level?
  • #6,164
There was a webcam, that pretty much nails the time of the explosion to some time between 6 and 7 am on March 15th
  • #6,165
That's highly implausible in my opinion. Sat images of March 14th (taken a few minutes after the Unit 3 explosion) show no visible damage on north and east side of Unit 4.
http://www.digitalglobe.com/downloads/featured_images/japan_earthquaketsu_fukushima_daiichi_march14_2011_dg.jpg
And the roof of Unit 3 plus the debris laying around don't change over the next weeks, so there's been no other explosion after that event.
  • #6,166
About unit 3: 5/8 11:00 314,5C
  • #6,167
The camera is being boiled - steam bubbles
  • #6,168
You tell me. France and US flew them 95 and 5 tons of enriched boron 10 a few days in. Not sure how much enriched though.
Well, maybe natural boron would work fine. I too know that the boron is very cheap and readily available and is a common chemical, but I also know that they've been flying it in on airplane for some reason. I don't know if that's because of perfectionism or because you can't dissolve enough natural boron in water to definitely prevent the criticality.
Yep, would be good to know for the worst case. It would depend to the fuel burnup. Fresh fuel has a lot of excess reactivity.
edit: see
http://en.wikipedia.org/wiki/Boron#Enriched_boron_.28boron-10.29
i presume that there's some good reason for enriching boron, 'cause it is obviously quite expensive to do isotope separation.
  • #6,169
But they are not coming from the camera... those two for example, they're coming from between the racks.
  • #6,170
Indeed.
As far as official info about this event, the wording was quite poor and tried to downplay things regarding unit 4, but anyway:
March 14th 04:08 Temperature of pool is 84 degrees C.
March 15th 06:14 It was confirmed that a part of wall in the operation area of Unit 4 was damaged
March 15th 09:38 Fire spotted at unit 4
March 15th 11:00 Fire no longer seen - presume it went out of its own accord
For example of this information being presented, see parts of this document: http://www.nisa.meti.go.jp/english/files/en20110316-4.pdf
OK so they were very late spotting the fire, but they reported the damage pretty much on time, although using misleading language, we only learned how badly 4 was damaged once we saw photos/video.
Given the timing of unit 3 explosion, I do not have an alternative explanation for what happened at unit 4. It happened within within minutes of the explosive sound at suppression chamber of unit 2, but I don't see how those events could be related. Given that the temperature of the pool was reported at 84C about 26 hours before the explosive event, I still blame the pool, even if we can't see any obvious damage to fuel (can there be significant damage that is not visible?)
  • #6,171
SteveElbows said:
Indeed.
well yea this translation is a largest nuclear understatement since the Chernobyl's 'electrical equipment fire'.
People near #2 could of misidentified #4's explosion sound as coming from #2 for example.
  • #6,172
Enriched boron (B-10 > 0.5) is quited common in the nuclear industry. For a given amount of boric acid, it would be preferable to have more B-10 than the natural concentration would give.
  • #6,173
but how bad it would be to run out of enriched B-10 ? I imagine it would be fairly easy to calculate what concentration of B-10 in the water would cancel out water's effect as a moderator... then it could be seen if natural boron can achieve this.
  • #6,174
It's mainly the matter of controlling pH. If natural boron is used, more boric acid is needed to get the same reactivity effect, and this makes the pH lower. Depending on the acceptable pH limits and the water chemistry used, this might require addition of base chemicals in order to keep the pH high enough for the core materials.
Regarding the units 1-4 at Fukushima, I don't think the disadvantageous water chemistry resulting from suboptimal pH would make the situation any worse than it already is, taking into account the use of seawater etc.
  • #6,175
That's not really relevant. If they needed a certain level of B-10, then they only need 40% the amount of enrich boron then natural boron. In terms of shipping, the choice would be 95 and 5 tons, as opposed to 250 T and 12 T for natural boron.
The idea is to get as much boron into the system ASAP. Enriched boron is preferred because there is more B-10 especially if one is constrained by solubility limit and/or pH.
  • #6,176
AntonL said:
this new underwater video of SFP4 certainly seems to rule out that SFP4 boiled dry and Hydrogen produced by overheating fuel rods and, so how did the Hydrogen get into reactor 4 building? In my opinion, only two possibilities remain:
1. Hydrogen being pumped into the building during venting of unit 3. Unit 3 and 4 share a common exhaust stack and there was no power for fans to work to aid the exhaust procedure.
2. Radiolysis of water as perhttps://www.physicsforums.com/showpost.php?p=3287847&postcount=6068"
Do you have any other ideas?
If the venting from unit 3 containment used the hardened vent it was a release of pressure directly to the stack. The off-gas stacks are really just support structures for the exhaust pipes from each unit. The pipes are separate and go all the way to the top of the stack. Even without power to the fans, to get hydrogen to then flow back down the pipe for unit 4 seems less than likely. Pictures of unit 3 seem to show the stack piping is broken at the unit 3 building so after the explosion of unit 3 there may not even have been a way to get hydrogen to the stack from unit 3. Whatever happened in Unit 4 happened after the explosion in unit 3.
If there were enough radiation to make radiolysis a legitimate threat in a spent fuel pool with freshly discharged fuel, it would be a problem for every fuel pool during every refueling outage. That just doesn't happen. And the freshly discharged fuel in SFP4 was at least 4-5 months old.
The latest fuel pool pictures from unit 4 seem to confirm TEPCO reports that there was only minor damage to fuel in the pool. We still haven't seen any reports or evidence of an explosive source in unit 4 other than hydrogen. There doesn't appear to be sufficient damage the fuel in the pool to have released much hydrogen. The stack is not a likely path for hydrogen from unit 3 to unit 4. Nobody has reported any fresh damage to unit 3 from a second explosion there that can explain damage to unit 4.
Meteorite?
  • #6,177
Dmytry said:
The second video avoids looking at the damaged racks visible in the first video. Really, you need a sense of scale. How much larger the pool really is than the reactor core. Pool's 20% damaged is a reactor 100% damaged.
You did not demonstrate clearly visible damage of fuel racks in the first video. There could have been damage, but it certainly was not visible in any clear way.
  • #6,178
NUCENG said:
Meteorite?
Osama bin Laden may be another option. He was still alive back in March. Jorge spotted him in the SFP of Unit 4, didn't he...? Chernobyl happened 25 years and we still don't really know yet why the whole reactor went KABOOM.
I don't think we'll find any answers as to what happened in Unit 4 even during the following months and years...
  • #6,179
(Wikipedia)
I had someone point out that the time when 4 likely exploded was right before sunlight so any of the cameras running may have been off. There was a fire reported somewhere between 4am and 6am.
  • #6,180
I discovered some video material of the scene after the explosions. But you can't really see anything:
https://www.physicsforums.com/showthread.php?p=3266278#post3266278
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
