Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #6,421
  • #6,422
ascot317 said:
Yeah, I was merely stating that I was unable to identify anything that's "supposed" to be there
Well, anyway i just wonder, considering the mess inside the pool, how some cooling flow can still exist around the fuel rods, assuming they are still below??
A lot of canals and spaces must be completely blocked by dust and debris, creating hotspots, don't you think?
  • #6,423
http://www.youtube.com/user/Anjiin#p/u/15/1Dcg2_YGtZ0
Sorry to go even further off topic, but... I see stuff in that third video that would never fly on a regular construction site. There's one guy who at a point straddles a pulley chain. Some other idiot climbs on the actual container, which is hanging above a two story drop mind you, to remove a hook. A bit after, someone comes from behind the idiot (who's still standing at the lip of the opening, beyond the guardrail) and removes the cable from his safety belt.
During all this, the container they're moving has no lid on... these guys must be selected for demonstrated stupidity, 'cause otherwise they'd realize it's shining out the top as well. Eventually it dawns on them that maybe something ain't quite right so they do the bit with the lead and the hammers. Comedy gold.
Also, where are the counters? I see one on the guy with the camera, one on the guy with the steel neuticles who goes to take contact readings, one hanging on a wall somewhere out of the way and that's all she wrote.
Apparently, one counter per work crew is standard industry practice, not something that only happens in emergencies? Sucks to be them, wouldn't work there for a million bucks a day (I'd be more scared of some idiot dropping something heavy on me than of the radiation, but still).
  • #6,424
MadderDoc said:
However there are physical limits to the mightiness of 20 tons of water vapour. It's lifting power would be at most 20 tons, equal to its own weight. I think the mighty puff we saw lifted substantially more than that.
Where do you get that figure from?
  • #6,425
Interresting is that the radiation in the SFP should come from the reactor core of unit 3 and not from the fuel in the pool.
How is it possible that the explosion at unit 3 could "extract" fuel from the core to the pool?
http://www3.nhk.or.jp/daily/english/10_30.html"
  • #6,426
~kujala~ said:
We could also think that this oil is in responsible for the fire but not for the explosion.
The explosion itself could be explained by AntonL's theory (radiolysis) or something else.
Look at the damages on the unit 4 building, particularly regarding the roof. Propane explosion would have done more damages to one part of the roof, don't you think? It seems the explosion was sort of "uniform", fitting well with a spread hydrogen explosion. The wall near the SFP, south of it, seems to have suffered more damages (pillars thrown away). It could be explained by SFP being the source of hydrogen.
Radiolysis can be an explanation, why not considering also ZR oxydation by steam generated by boiling? SFP4 may have boiled several hours before explosion. Time to heat up water to 100°C was roughly 2 days => Mar. 13th 3PM. Explosion was Mar. 15th 6AM. Fuel assemblies are stored in tight space in casks, and steam may accumulate in the top part of it while going up.
By the way, SFP4 was full after last last spray (May 7th); loss rate from previous refilling went back to 56 tons per day. If my data are correct, SFP4 went back from 120 tons per day to 56 tons per day loss.
Last video may also give an indication about gate status (see attachment). At first sight, if correctly identified, it does not seem to have suffered breaks.
  • #6,427
Unit 2:
March 20th 15:05~17:20 Approximately 40 ton seawater injection to the Spent Fuel Pool (SFP) via the Fuel Pool Cooling Line (FPC)
March 22nd 16:07 Injection of around 18 tons of seawater to SFP
March 25th 10:30~12:19 Sea water injection to SFP via FPC
Unit 3:
March 23rd 11:03 ~13:20 Injection of about 35 ton of sea water to the Spent Fuel Pool
March 24th 05:35~16:05 Injection of around 120 ton of sea water to SFP via FPC
http://www.nisa.meti.go.jp/english/files/en20110509-1-3.pdf
The levels of radiation detected are almost the same as those detected in April in water samples in the fuel pool of the No.2 reactor.
Did they have the hoses connected to the same places when injecting sea water to the SFP?
As for the possible maximum levels of sea water injected this document gives the radiation levels of sea water on April 2nd for I-131 at screen/cable pit:
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110405e31.pdf
  • #6,428
About N°3:
The firm also says the temperature of the plant's Number 3 reactor has been rising this month, and that work to pump water to cool the reactor may be insufficient.
The company says it is installing new pipes at the reactor and hopes to start pumping water through them on Thursday.
http://www3.nhk.or.jp/daily/english/09_28.html
In fact the temps at N°3 decreased in the last days after a high rise that we commented here extensively...
https://spreadsheets1.google.com/sp...ZDbX39YK-iFb0Iw&hl=ja&authkey=CP6ewJkO#gid=40
https://spreadsheets1.google.com/sp...DZDbX39YK-iFb0Iw&hl=ja&authkey=CP6ewJkO#gid=2
Also the water level in RPV has slightly increased. And we are not Thursday, so what did change to explain this drop? They say they increased the flow since last wednesday from 7 to 9 tons/hour. But the temps continued to rise until this WE: inertia?
http://www3.nhk.or.jp/daily/english/10_18.html
  • #6,429
Borek said:
<..>something occurred to me just now. After the hydrogen explosion there should be an implosion phase - lowering the pressure above water - and that could be enough to start flash boiling.
In theory, perhaps. In this theory, it would seem the implosion phase should follow the explosion, and the expulsion of steam should follow the implosion.
However looking at the video we see that the flash of fire, i.e. the generation of heat, was quite alive and kicking well past the time of the initiation of the massive steam expulsion. Effect cannot precede cause.
  • #6,430
That would be possible, if the explosion opened up a channel for transfer between the core and the pool. It would imply that the explosion breached the RPV and the PCV.
  • #6,431
The company says the radioactive substances may have become attached to debris and entered the pool together.
What the heck? Next they'll say that Osama bin Laden dumped them inside the pool.
http://vimeo.com/22586794" is an old video of Arnie Gunderson regarding the measurements of radioactive substances in the water of SFP #4 and TEPCOs explanation that airborne fallout is responsible.
He's calculating that for an amount of 2000 Bq/cm³ in the water of a SFP, you'll need 30 billion Bq/m² fallout - which's way beyond Chernobyl numbers.
(But that doesn't mean that there's been criticality in the SFP - NUCENG calculated that those numbers could have come from very limited fuel damage inside the SFP).
Now, we're having ~300.000 Bq/cm³ Cesium in SFP Unit 4. If the fuel rods are fine and all of that is coming from the air, there must've been fallout of around 4500 billion Bq/m2...
Here are the TEPCO numbers for the pool:
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110510e12.pdf
"Small" iodine numbers, but incredibly high cesium. I'd say that's an indication of major fuel damage inside the pool.
NUCENG can probably tell us if the I2C-Ratio is consistent with spent fuel.
Edit:
Not so sure about the iodine any more...
NUCENG wrote https://www.physicsforums.com/showpost.php?p=3254871&postcount=4200" that the iodine inventory of a 760 MWe core is about 10^15 Bq I131 six months after shutdown. There are ~500 fuel assemblies inside SFP #3, and Unit 3's core is ~500 assemblies big.
But the fuel there is probably much, much older than six months. Furthermore he's guessing, that the SFP has a size of ~2*10^9 cm³.
Inside Unit #3, we have 11.000 Bq/cm³ I131, if we say that half of the pool is filled with debris, then there's about 10^13 Bq inside, around 1% of the total iodine inventory of a six month old core.
But if the fuel's one year old, it should only have 10^9 Bq of iodine left - and the iodine in the water would be 10.000 times the amount of iodine present in the fuel!
If I remember correctly, fuel is stored up to several years in SFPs, so how old would the fuel in SFP #3 possibly be?
  • #6,432
There was those steam plumes coming from the reactor, maybe? Iodine, Cesium - both can travel by steam, AFAIK.
Wait, they had taken samples from SFP#2??
  • #6,433
this same very limited fuel damage would of released over a thousand times the observed amount of Cs-137 (given the ratio of i-131 to cs-137 in the old fuel), or alternatively, this fuel damage (and chemistry) would have to be over a thousand times more selective in releasing the iodine versus cs-137 than anywhere else. I'm not saying it proves criticality in sfp4, they might have used contaminated seawater for cooling (but if so, why did not TEPCO give it as explanation?). I'm saying that it doesn't cut it to handwave about chemistry when it is over 1000 times more selective than anywhere else (drains, ditches, ocean, fish bodies...) . If there is something this good at scrubbing out cs-137, that's be WONDERFUL news because they could use it to clean their nasty water.
edit: also, note. 1 mol of i-131 has 1360 times the radioactivity (in Bq) of 1 mol of cs-137, this rules out compounds such as CsI as explanation for the ratio.
  • #6,434
From the scenario, a 1000 tons of water in pool, superheated to about 110 deg C.
This system is unstable, the excess temperature 10 deg. C it is above the boiling point represents the energy available to suddenly vaporize some part of the water.
Water has a heat capacity of 4.18 MJ/ton/degree Celsius, so with 10 degrees and 1000 tons of water, that gives you 4.18*10*1000= 41.8E3 MJ of energy available for vaporization of water.
It takes 2.257E3 MJ/ton to vaporize water, so with 41.8E3 MJ available, this would suffice to vaporize 41.8/2.257 = 18 tons of the water in the pool.
  • #6,435
yakiniku said:
I don't recall seeing mention of the data published on April 23rd by the Center for the Promotion of Disarmament Non-Proliferation Japan. It contains data for a number of radioactive isotopes that might be interesting from the CBTO Takasaki station in Gunma:
http://www.cpdnp.jp/pdf/110427Takasaki_report_Apr23.pdf
http://www.ctbto.org/verification-regime/featured-stations/types/radionuclide/rn38-takasaki-japan/page-1-rn38/
I had a closer look at those data now.
The ratio of I-134 to I-137 is almost constant (almost always between 0.85 and 0.90), so there do not seem to be too many typos in those numbers.
The table contains some short-lived isotopes like Te-129 with its 70 minute half-life. But it is present because of Te-129m, which has a 34 days halflife. Generally, the tables show Te-129 activity at about half that of Te-129m. Except for March 15, when it is only 10 %. This could be a typo?
There is also I-132 with its 2.28 hour lifetime. It is the daughter of Te-132 (3.27 day halflife). Generally, the I-132 activity is about half that of Te-132. The largest deviation from that is March 16, when I-132 is listed with a higher activity than Te-132.
The ratio of I-131 to Cs-132 is rather variable. Probably this depends on rain etcetera. But the data point for I-131 on March 22 does not seem reliable.
So what is wrong with the Japanese? Why don't they make plots like the German test ban monitoring people do? Why not provide some interpretation?
  • #6,436
AntonL said:
"That just doesn't happen" under normal circumstance when the pool is cooled,
and H2 and O in solution quickly recombine, but
[PLAIN]http://k.min.us/invwtS.JPG
https://www.physicsforums.com/attachment.php?attachmentid=35318&d=1304876672" Light Water Reactor Hydrogen Manual by Allen L Camp
Wouldn't it also happen in BWR cores then? Boiling water, high radiation would generate lot of hydrogen, which would not recombine (boiling + steam environment). This means cores would generate a lot of hydrogen, a lot more than observed, don't you think?
BTW same for Zirconium oxydation by steam in boiling environment.
  • #6,437
Borek said:
...I never liked the idea of superheating, as there is plenty of objects in the water that should easily help to start local boiling (see http://en.wikipedia.org/wiki/Boiling_chips - that's all about rough surface) and remove excess heat. ...
(all this in reference to SPF4)
Isn't another problem with the superheating scenario the fact that the site was experiencing almost constant aftershocks of varying degrees throughout this time period which would have created disturbances in the water which, along with the many nucleation sites mentioned by Borek, would inhibit/prevent superheating?
  • #6,438
http://img39.imageshack.us/img39/705/containment.jpg
https://netfiles.uiuc.edu/mragheb/www/NPRE%20457%20CSE%20462%20Safety%20Analysis%20of%20Nuclear%20Reactor%20Systems/Containment%20Structures.pdf
"Steam being quenched from the primary vessel into the torus under high pressure would act as a rocket and could cause vessel displacement"
Has the idea that the full top of the unit 3 RPV was blown off already been debunked ?
It would be consistent with the 1 atm pressure reading
[URL]http://i705.photobucket.com/albums/ww51/Moshpet/Exploded-veiw.jpg[/URL]
source : http://www.abovetopsecret.com/forum/thread693571/pg2#pid11221435
  • #6,439
There are still living personnel on site, after a month. Such damage would make that site like Chernobyl -> some seconds at work, and then run for safety...
  • #6,440
rowmag said:
Also heard on radio that they are going to try feeding water through a different line at Unit 3 later today, due to the rising temperatures there, since merely increasing the flow rate through the current one is not working, suggesting that the water is not getting where it needs to go for some reason.
It has been suggested salt buildup (from the seawater injection period) at the bottom of the RPV could be insulating corium that deposited there from the partial melting.
  • #6,442
StrangeBeauty said:
Isn't another problem with the superheating scenario the fact that the site was experiencing almost constant aftershocks of varying degrees throughout this time period which would have created disturbances in the water...?
It occurred to me that *IF* the situation depicted below occurred in an SFP, and *IF* it led to the occurrence of some chain fission, then the water level would be unstable and could start to oscillate. Namely
water level inside assemblies rises --> moderation of neutrons increases --> chain fission increases --> fuel heats up --> steam pressure inside the assemblies rises --> water inside assemblies get pushed down
I presume that if water is boiling inside the assemblies the pressure there would be higher than atmospheric, since the top support plates and the assembly head impede the flow somewhat. Since it would take some time for the extra heat of fission to travel from the fuel to the cladding, the pressure within the assemblies would oscillate in sync with the water level but with some delay --- i.e., the push would be stronger on the way down --- tending to amplify the oscillation rather than to oppose it.
EDIT In fac,t the water level may start oscillating even if there is no chain reaction at first, just from the delay of heating and boiling the water. However, as the top of the wave gets some distance above the surviving boral, then the chain reaction should restart, no?
  • #6,443
Aren't cesium and iodine volatile components that would travel with the vented steam? It seems to me (lay opinion) that this is entirely consistent with steam venting from the reactor vessel into the primary containment (damaged lines or vessel?) and then into the SFP3 (ie, through the fuel transfer chute).
As for the superheated water being very unstable, heck yes -- but the hypothesis was that the "critical" moment of superheating was immediately followed by the steam explosion, and that the explosion and venting of the contents within the primary containment was, in fact, the "last straw" impetus for the steam explosion that caused that criticality.
Is it also possible that criticality occurred, the water/steam was ejected from the SFP, and the contamination with cesium and iodine occurred either as a consequence of the criticality in the SFP or after the pool was refilled? Maybe. A lot of steam was still leaking at the apparent location of the transfer chute after the explosion.
Irrespective of the exact cause initiating the steam explosion, an open connection from the primary containment of Unit 3 to the contents of SFP3 seems to be supported by the water analysis, right?
  • #6,444
They did:
It said the radioactive materials detected in the latest check could have come from seawater sprayed into the pool to cool the reactor.
http://www.asahi.com/english/TKY201104300099.html
Now the really interesting question is are they going to admit this might also have happened in SFP 2 and SFP 3 but in a larger scale. It's a possibility if the hoses for SFP 4 and SFP 2&3 sprayings were located on different places. But not the only theory.
But if they admit it they must also admit that their calculations concerning the leak into the sea might be heavily underestimated. Which might be the problem? :rolleyes:
  • #6,445
From various reports that I have read, it seems that many nuclear plant workers are temporary people "from all walks of life, bartenders etc.", often unemployed or in financial straits; with no special training or previous construction work experience, hired for a very short time and trained to do a very specific task only. Thus it is not surprising if they are clumsy, inefficient and unsafe when faced with an unforeseen event --- such as a stuck crane hook.
  • #6,446
The analysis this guy is giving is wrong based on the picture on which he is drawing the supposed reactor, simply because he places it at the wrong place! The reactor is normally centered in the middle of the North/South axis (it's normally offset towards the East on the East/West axis) , but the part of the picture where he is drawing the circle is completely offset to the North side.
See there is no metallic structure over the place where he is drawing the circle, while this remaining structure from the roof is present in the middle of the building after the explosion.
http://www.netimago.com/image_198661.html
I'm not saying anything about the actual condition of the reactor (but at least it seems that some sensors for temps are still working!) but for sure the stuff the guy is showing is NOT the remains of the reacto because it's clearly at the wrong place!
  • #6,447
Things are at the wrong place in a lot of places ...
Thought so already , good to have that cleared up
  • #6,448
One thing that hasn't been mentioned:
D/W radiation sensors are at the top of the containment, near the cap. They wouldn't give any data, not even bogus data, if that part of the reactor would be gone.
  • #6,449
You're referencing information from a ufo-magiccrystals-NWO-aliens conspiracy site. There may be some useful info posted there but I wouldn't trust the dialogue.
  • #6,450
quark42 said:
Here's the link to the PDF at the NRC's site: http://www.nrc.gov/reading-rm/doc-collections/fact-sheets/prv.pdf"
First post here. I've been reading this thread since around the #350th post and I'd like to thank all the contributors. I've learned an incredible amount about nuclear physics and the engineering of nuclear reactors.
Keep up the good work. Back to lurking...
I guess it's just me that couldn't get to that .pdf. Thanks for the link.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
