Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #7,411
MJRacer said:
Please see:
Those articles are between unclear to confusing.
One discusses Unit 6 and how it is partially imbedded in mudstone down at 17m. What is the other part sitting on?
The other article says a holding tank location has waterproof bedrock down below at 46m. Where do any leaks spread from the bottom of the tanks while traveling down 46 meters?
Might drill a big hole 46m deep and put some metal casing in it to make a holding well. Could get lucky and strike oil.
  • #7,412
Gary7 said:
According to the Tepco site, Fukushima Daiichi is built on bedrock.
http://www.tepco.co.jp/en/challenge/energy/nuclear/plants-e.html
And according to this seismic study, reactor N°6 which is founded 17m below ground level is embedded in MUDSTONE as we already mentioned it here... (see page 1 and 2)
http://www.iitk.ac.in/nicee/wcee/article/9_vol3_733.pdf (oops, sorry some were quicker to post!)
The reactors 1 to 4 are not so deep underground i think, but this confirms that they are not on bedrocks but on mudstone. And mudstone (which is dryied mud basically) is not bedrock. Except for Tepco maybe.
An other example of lies in communication strategy IMO.
To RAZZ and NUCENG:
Re-read the exact sentence in the study linked above: "The reactor is partially embedded and is founded on mudstone", which is different than your wording! It doesn't say it is PARTIALLY FOUNDED on mudstone, it says it is partially embedded!
  • #7,413
Mudstone is a second class bedrock. If exposed, it would erode rather rapidly compared to say, granite.
  • #7,414
etudiant said:
You are surely correct, a pure hydrogen explosion or combustion is a pretty low key event, in fact the flame is invisible, at least afaik.
So the orange fireball from reactor 3 strongly indicates substantial additional combustible/explosive material was involved. Normally flames are luminous because of white or red hot particles, generally of carbon, that are carried in the heated flow. Where these came from in this case is not yet clear.
There is no need for an assumption of the presence of any additional combustible/explosive material. While in a testtube with pure hydrogen you can well produce a near colorless flame, in a Fukushima reactor you can hardly have a hydrogen explosion without producing concrete dust, and concrete dust in the heat zone will glow white, yellow or red depending on its temperature just as good as carbon particles. The blasts in unit 1 and unit 3 glowed just like they would be expected to do when a hydrogen combustion heats concrete dust.
  • #7,415
Once the foundations are in place the site would be backfilled around the foundations to reach current levels, In the US there are extensive provisions for controlled runoff and draining to ensure potential released of ground water are not contaminated or if contamination exists, that it is monitored and reported. Would that help stabilize the mudstone so it wouldn't erode?
  • #7,416
Regarding the article discussing cesium found in Tokyo:
Although I didn't sight the actual Asahi article myself, I read the article that was copy & pasted onto the Japanese website, as well as the newspaper clipping that was linked, and they both look to be legitimate. The samplings were apparently taken at various locations in Tokyo, Chiba, Saitama, Ibaraki, and Fukushima. The earliest sample is from March 19th (Fukushima, 27650 becquerels/kilo). The most recent sample was taken on April 20th from the city of Tateyama in Chiba (127 becquerels/kilo) and the city of Kamisu in Ibaraki (455 becquerels/kilo). Tokyo's highest reading was from Kameido in the suburb of Koto-ku (3201 becquerels/kilo) sampled on April 16th.
  • #7,417
Yes, the article is real. I obtained a copy of yesterday's Asahi Shimbum from a neighbor.
The article is on page 5 from the 15th May. I've scanned the full article for those who are interested.
  • #7,418
Thank you very much indeed.
  • #7,419
Caniche said:
Just can't remember the Hindenberg mushroom cloud and that was a big hydrogen sucker.<..>
source http://www.aerospaceweb.org/question/investigations/q0277.shtml
  • #7,420
pdObq said:
Thanks for looking more closely into that!
1. Yes, that might be true in this case. But another safety feature that seems to be missing are redundant SFP "core spray" lines.
2. Oh, ok, that might explain the possibility of pre-existing corrosion on the roof structure. OTOH, isn't the SFP water cooled, so that in principle it shouldn't be hot and moist there?
3. Yes, one probably would need more cooling capacity, if so far one relied on part of the cooling done by evaporation.
4. Agree, you don't want a concrete slab to fall onto your fuel (that's a somewhat recursive requirement...).
5./6. Yes, so additional venting and level sensors might be needed. But isn't the water level in the pool monitored by some sensor anyway?? E.g. that skimmer tank water level sensor?
One possibility that avoids some of those points would be to not cover it completely, but only so much that no big object can fall in.
Interesting, thanks for the link (Haven't had time to read it fully yet, though.). I think they should reconsider such threats in view of Fukushima. I mean it seems pretty obvious now that SFPs "on the attic" are a major possible security and safety risk.
I would hope so to, although that might deserve a different thread, such as lessons learned or reconsidering BWR safety. And my question about SFP shield plugs was not only with regards to the roof collapsing but also to threats such as airplane crashes, as considered in the document linked to by jlduh.
See the attachment in this post by M&M https://www.physicsforums.com/showpost.php?p=3294820&postcount=6534 . I browsed through the whole NRC document now, but I could not find any additional details about the "Fuel Storage Pool Shield Plugs", 4x 4.5 tons, mentioned there. There is also "Fuel Transfer Shield/Cattle Chute", 2x 16.5 tons, and the "Fuel Pool gates", 2x ~1 ton. These sound more related to the shield wall and gate between the reactor well and the SFP.
I found a list of radiation monitoring equipment instead, with detector types and measuring ranges if anyone is interested in that. It's on p. 68 & 69 (one page is missing), Table 11.5-1 "Process and Effluent Radiation Monitors". CAMS seems to be a different sub-system, it is not on that list AFAIKT. There are a whole bunch of lists of other instruments and stuff in that document, as well.
OK, the pool shield plugs referenced are interlocking stacked shield blocks that fill in the area where the fuel transfer chute connects to the reactor cavity. They aren't part of the fuel pool per se. They just fill in the area aroung the drywell cap to provide biological shielding during normal operation. Once these plugs are in place the hemispheric shield plugs are added to top off the reactor cavity above the drywell cap up to ffloor level.
  • #7,421
Dmytry said:
nothing outstanding or surprising. the clueless are promptly learning that a: the radioactivity is distributed in spots, and VERY much in spots (several orders of magnitude difference between hotspot and area around it) and b: the poorly done monitoring misses those spots. Then they will learn that c: even good monitoring will miss many of those spots.
On to food testing when they will 'discover' that a good chunk of radioactivity is in samples hundreds times above limit, which are rare, and aren't stopped effectively by traditional random sampling.
Well, again what you describe has a name and has been proved by experience at Tchernobyl: contamination in leopards spots.
I repost this map of Tchernobyl contaminated zones (Cs-137) because it is very informative about real life contamination transportation and redeposition:
http://www.netimago.com/image_200655.html I would like to know what could be the reasons why this phenomenon wouldn't apply for the Fukushima plant, looking at how things evolve at the reactors?
My feeling is that we start to see appearing, through the various infos and measurements released in the press, that kind of hot spots (first towards North west axis, then recently towards south west axis, maybe including Tokyo), even at high distances from the plant (and much further than the 30 kms zone), and that's why some governors get angry because of lack of fine "tuning data" to identify these spots and decide what to do (see my post here:
https://www.physicsforums.com/showpost.php?p=3304552&postcount=141 )
Then how do deal with that kind of hot spots, that's all the question. 1) Expanding the evacuation zone in a circular manner with increased radius around most of the hotspots is a solution... more easily done in Ukraine than in Japan due to population density, i admit! 2) Do a real fine tuning based on reliable and updated data. But even this could lead in the future to much more evacuations if hotspots multiply...
The other question is, can this second fine tuning be done in a timely and reliable manner?
And as you said, can statistical sampling on food detect properly the consequences of these hotspots, which are probably like fractals shapes: from macro hotspots to very local hotspots because of local redeposition conditions and concentrations? Japan has lots of mountains which also create a much more complex redeposition pattern scenario than on flat lands i think, because of local geography/meteorology which are characteristics of mountains areas.
  • #7,422
Thanks. At the end of the article, it is mentioned that these results will be communicated at http://www.icas2011.com/ on May 24th (1). I guess the press will be more talkative about them from that date on.
(1) The program for "S22) Urgent Symposium Analytical Sciences Facing Radioactive Pollutions" is available at http://www.icas2011.com/program/program_list.html#24PS22 ; See also http://www.icas2011.com/program/program_list.html#23pB2 for May 23rd
  • #7,423
Rive said:
Radiolysis applies only on molecules with covalent bonds. NaCl has ionic bonds - as it solved it becomes a mix of separated Na+ and Cl- ions immediately.
Thank you. So mostly a mess to clean up, then, from getting seawater in a reactor, and not necessarily a corrosion concern?
  • #7,424
The word 'mudstone' by itself doesn't tell us much. It just means that once upon a time it was a muddy, i.e. fine-grained, sediment. Without further qualification it doesn't say anything about hardness, strength or resistance to weathering and erosion. Mudstones with a silica-rich matrix, subjected to relatively high pressures and temperatures millions of years ago, can be almost as strong as granite and certainly good enough for building power stations upon. Others might not be. Any sort of mudstone is likely to be pretty impermeable to water, at least before being fractured by earthquakes.
  • #7,425
Well again, even if this a slightly different subject from the Daichi plant, I have a hard time understanding how seawater can enter so easily (i say "easily" just because it just happened...) into a BWR reactor. But I understand that unlike a PWR, in a BWR there is no real secondary circuit (i mean closed loop), so the steam is condensed into water in the condenser (which is cooled by seawater if my understanding is ok) and goes back into the reactor right?
So any leak between the two (the sea water/the steam or condensed water) can theoretically (and practially in this case) lead to either seawater entering the reactor or contaminated water going back to the sea?
I would be surprised if this Hamaoka event was the first in BWR history with that kind of problem. Any knowledge on that?
If i rely on what has been said for Daichi reactors, it seems that the experts have very few data on the effects of seawater inside BWR reactors. And by a very surprising collision of events, we just learn that 500 tons of seawater has probably enter one of the reactors of Hamaoka plant during cold shutdown procedure!
Can someone confirm if this seawater actually entered the reactor (I mean the pressure vessel)? Or is it somewhere else?
If it's the case, and as i said yesterday, it seems god is recently playing dices in the nuclear game and wins much more than calculated by experts, don't you think?
  • #7,426
Corrosion in salty water is in general much faster than in fresh water, so it can be a problem - but not because of the radiolysis.
  • #7,427
Cl- ions are always a primary corrosion concern, but radiolysis is not relevant in this case: Cl- ions are present in saltwater by default.
  • #7,428
MadderDoc said:
No, certainly not. I am just saying that the simplest explanation that is consistent with the evidence is not consistent with the claim of anyones seeing the ignition. You can uphold the claim only by adding more assumptions to the explanation, however these assumptions would seem to be added, not to make the explanation consistent with the evidence, but to make it consistent with this extraneous claim.
The observations I make are these: the southeast corner of Building 3 three (roof and south wall) visibly expands, blows out, and ejects a relatively small white puff of gas laterally, which almost immediately turns to a somewhat larger, self-consuming orange fireball.
This is followed temporally by the more generalized explosion of the entire upper portion of the building and a rising column of dense gas, apparently steam and smoke, directly over the spent fuel pool (as in pool of hot water) -- a column of smoke with a large amount of "lift", and an appearance consistent with a littoral explosion.
The post-mortem images of Building 3 seem to confirm both localized thermal and mechanical damages at the southeast corner, over the SFP as well as more generalized lateral and vertical blast damages, consistent with those observations.
A large increase in measured radiation accompanied the explosion(s), perhaps consistent with explosive venting of the primary containment, or some portion of the contents of the spent fuel pool, or some combination of both.
Time does not permit me to again append the supporting visual images as I must be off to work just now. Perhaps I can do so in an "edit" at a pater time, or perhaps the content of several thousand preceding posts will suffice.
Therefor, please, I ask, do excuse any extraneous or inaccurate claims I have made or implied in my perhaps deeply flawed and sometimes incoherent attempts to arrive at a "simple" explanation to a complex set of events. If "ignition" is the incorrect term for a white puff of gas turning fiery orange, then I stand humbly corrected. Thank you for your patience and thoughtful critique in any case.
  • #7,429
Even if it could, you're much better off drawing a line around areas with hotspots, because the hotspots move all the time. Bio-accumulation sucks. The water cycle blows.
Yes, even radioactive badgers.
http://chornobyl.in.ua/en/badger-meles-meles.html
  • #7,430
SteveElbows said:
There are only a few images from the period after 3 blew but before 4 went up.
I don't think the resolution is high enough to be 100% sure, but it looks to me like there was already debris fallen onto the pipe in the place where it is later shown to be broken. And I think its always been a pretty likely bet that it was falling walls of reactor 3 that caused the damage.
Thanks for finding those. They don't look conclusive to me whether the pipe was damaged or not. I'll keep looking.
  • #7,431
In an article dated March 25th dealing with Fukushima Daiichi seawater corrosion issues, Euan Mearns made the following quote :
In this earlier post I quoted TOD commenter donshan who spoke authoritatively on corrosion issues:
" I do question the use of seawater cooling. I hope the Japanese have considered the danger they have created by introducing oxygenated seawater into this stainless steel piping and pressure vessel at boiling temperatures. These stainless steels are extremely susceptible to chloride stress corrosion cracking:
Since residual weld stresses and tensile stress in piping, valves, control tubing, etc. are always present, Standard Operating Reactor water quality standards require keeping chlorides at parts per billion levels. Seawater has about 3.5% or 35 grams per liter of salinity! (i.e. 35,000,000 parts per billion)
I have no way of knowing how many days they have before a stainless steel component suddenly cracks, but if it were me, I would be advocating an emergency program to get pure deionzied cooling water back into this stainless steel system ASAP. In laboratory tests in boiling chlorides, cracking of stainless in tensile stress can occur within days- they have at most a few months if they keep boiling sea water in this system and yet another disaster occurs."
http://www.energybulletin.net/stories/2011-03-25/fukushima-dai-ichi-status-and-slow-burning-issues
  • #7,433
Second-hand information: cesium has a habit to travel with water and easily deposited in the top soil. So: hot spots on top soil will be formed around every rain-, waste-, interrogation-pipes, ducts, canals. Roads, roof-drainings. This works like a kind of 'enrichment', so such hot spots will appear in less contaminated areas too.
Such hot spots can be neutralized by replacing/removing of top soil. But they might reappear later.
So: evacuations are not practical as most of Japan might be affected up to various levels. They must do regular checks and frequent soil-replacement.
I hope they can develop some really effective soil-decontamination process. They will need it.
  • #7,434
I found, on a different but somewhat related topic concerning the Daichi reactors, this article (and the links at the bottom of the page) informative about the effects of radiations on aging process of materials:
http://www.lucaswhitefieldhixson.com/accelerated-aging-effects-radiation-materials-fukushima-daiichi
One of the most impressive is the huge increase of thermal expansion effects of irradiated steel:
http://www.nuc.berkeley.edu/courses/classes/NE-220/Introduction%20PDF%20format.pdf SEE PAGE 6/30)
  • #7,435
It is most certainly in the reactor, at least part of it. You see, these reactors only have ONE cooling loop. The water is heated in the pressure vessel, becomes steam which drives a turbine and is then cooled in a condenser, later to be pumped back into the reactor. The condenser itself is cooled with seawater. The seawater is pumped into the condenser, chills the pipes through which coolant flows and goes out back into the sea. Some of the seawater found its way into the coolant loop.
The 400 ton figure is suspect to me. In my mind's eye, I can see them measuring concentration of salts in the coolant loop and saying "oh that's the equivalent of about 400 tons of seawater". No need to tell you how many things may be wrong with that, no?
Also highly suspect is the lack of any mention of radioactive releases into the sea. There should be all sorts of interesting activation products in that condenser, I can't believe that water was going into the coolant loop, but not out again... The reactor (or at least the steam condensation chamber) would have been flooded right sharpish.
Or perhaps that's what happened? They detected the hole by abnormally high water level somewhere?
Those playing dice are the penny-pinchers who defer maintenance and write bogus safety analyses, not the gods.
  • #7,436
Dmytry said:
Covering the pools to protect them from roof falling down?
Come on, the pool is on the top floor! The cover that has no risk of failing in, combined with instruments to ensure that cooling water level is correct, etc...
So there might not be so much value in having a cover on the pool. I doubt the prompt criticality thing is legitimate concern, but I'm no physicist. I'm not sure what a cover is going to do to protect the spent fuel from terrorist attack either.
Dmytry said:
... it'd quickly be much cheaper not to have the spent fuel pool be on top floor next to the reactor in first place, eliminating entirely the risk of cascading failure from reactor to spent fuel pool. But the cascading failures were never considered in the risk assessments (which is imo a case of utter incompetence), hence the pool is found next to reactor, on top floor.
I'm guess the fuel pool is located there out of necessity. They can't get the hot fuel out any other way. The location near the reactor allows refueling without removing the fuel from the boric acid. Otherwise there would be an extended shutdown while waiting for the spent fuel to 'cool down.'
  • #7,437
pdObq said:
I have used this link to check the Japanese text.
It is not a document from TEPCO (maybe nobody has ever claimed that it was, but I want to mention this just to make sure there are no misunderstandings).
The text is a critical (no, condemning) description of how TEPCO, 40 years ago, after realizing that the weak clay and sandstone in the upper 25m of the building site would have made it necessary to drive foundations as far down as the layer of relatively firm mudstone (泥岩層) below, removed the top portion of the building site, which made for easier access to cooling water and loading facilities for fuel easier. The current design is based on the assumption that a tsunami would at most have a height of 5.7m. The included drawing is self-explanatory.
Respectfully submitted for your consideration, but it seems that none of this is new information or a revelation.
  • #7,438
That is the concern. Basically introducing seawater into the cores probably lead to some damage by corrosion, and even if they had successully cooled the reactor cores, they would have had to decommission the fuel, control rods and core internals. Stainless steel 304 would suffer pitting corrosion and stress corrosion cracking. Zircaloy-2 would be normally resistant to seawater unless there was a fair amount of ferric chloride formed in the cooling water, in which case, Zircaloy would corrode. It is suspected that the seawater did enhance the corrosion of Zircaloy and consequential hydrogen production. However, unit 1 exploded before they introduced seawater, whereas unit 3 exploded after introduction of seawater.
There have been a couple of BWRs with saltwater intrusion. One through some low pressure turbine blades through the condenser which then allowed saline river water to enter the reactor. The salt content was very low (perhaps a few thousand ppm), but the reactor was a reduced power and quickly shutdown. I believe they flushed the system and restarted after they removed the low pressure turbine stage. I don't remember the details of the other since it happened more than 20 years ago.
  • #7,439
Insufficient decontamination of workers and lack of adherence to related rules is being described in this article:
http://mdn.mainichi.jp/mdnnews/news/20110514p2a00m0na014000c.html
  • #7,440
So, we now have two facts:
1. having a spent fuel pool on the topmost floor is stupid risky and
2. it is unavoidable in this reactor design.
The conclusion must be that this reactor design is stupid risky. Which means they all should have been scrapped a long time ago or at least not allowed to go on operating past their design lives (but I'm politicizing again, aren't I? At which point does engineering fact become subject to political debate?).
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
470K
21K
  • · Replies 763 ·
283K
  • · Replies 38 ·
17K
12K
