Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The Fukushima Daiichi nuclear plant is facing significant challenges following the earthquake, with reports indicating that reactor pressure has reached dangerous levels, potentially 2.1 times capacity. TEPCO has lost control of pressure at a second unit, raising concerns about safety and management accountability. The reactor is currently off but continues to produce decay heat, necessitating cooling to prevent a meltdown. There are conflicting reports about an explosion, with indications that it may have originated from a buildup of hydrogen around the containment vessel. The situation remains serious, and TEPCO plans to flood the containment vessel with seawater as a cooling measure.
  • #7,401
rowmag said:
If seawater got into the reactor, wouldn't radiolysis release chlorine gas, which would start corroding things? What are the chances that Hamaoka Unit 5 just retired for good?
Radiolysis applies only on molecules with covalent bonds. NaCl has ionic bonds - as it solved it becomes a mix of separated Na+ and Cl- ions immediately.
  • #7,402
ThomS said:
Question re: measuring radioactive materials in the environment.
Why are there only reports showing levels of Cesium and Iodine (2 kinds)? Almost all of the releases by Tepco, for instance, only show these.
In the beginning of March, they had many other isotopes. Some of which were short-lived, like chlorine-38 and iodine-134. Those were in error. Tepco had to apologize, and say that they would never publish inaccurate data ever again. Since then they have limited themselves to iodine-131 and cesium.
http://www.tepco.co.jp/en/press/corp-com/release/11040408-e.html
"Three nuclides (Iodine-131, Cesium-134 and Cesium-137) that affect more for radioactivity and easy to identified are to be published as fixed figures. Other nuclides figures are to be released as soon as identified."
We have not seen much of those other nuclides.
  • #7,403
Covering the pools to protect them from roof falling down?
Come on, the pool is on the top floor! The cover that has no risk of failing in, combined with instruments to ensure that cooling water level is correct, etc... it'd quickly be much cheaper not to have the spent fuel pool be on top floor next to the reactor in first place, eliminating entirely the risk of cascading failure from reactor to spent fuel pool. But the cascading failures were never considered in the risk assessments (which is imo a case of utter incompetence), hence the pool is found next to reactor, on top floor.
  • #7,404
Speaking of cesium. Apparently an article was pulled from yesterday's (May 15) online edition of the Asahi Shimbun.
It contained, according to readers on the ex-skf blog, a table of results from a study of radioactive contamination in Kanto province (in and around Tokyo that is).
http://ameblo.jp/renatarojp/entry-10892684176.html
google translate link, so English-only readers like me can understand what I am babbling about
http://translate.google.com/transla...//ameblo.jp/renatarojp/entry-10892684176.html
Also from there, an alleged photo of the table of results from the paper's print edition:
http://2ch-ita.net/upfiles/file7582.jpg
Could someone here who reads Japanese confirm?
  • #7,405
BrendaEM said:
Hi, I uploaded some enhanced videos the the explosion and spent fuel ponds:
Explosion:
Spent Fuel Pool:
I might consider doing more, if the result might be as dramatic as the first enhancment.
BTW, does anyone have have a top view plan for the GE MK1; I found the sides here, but not the top. I might do a RhinoCAD 3d Rendering for Wikipedia.
Nice work Brenda :approve:
Just a small mistake in a title i think: this is spent fuel of N°4 reactor, not N°2 (which can not be accessed anyway).
http://www.youtube.com/watch?v=tGuUuGRHlhI&feature=related
  • #7,406
Curium said:
This weekend, Gundersen reiterates the "prompt moderated criticality" hypothesis, does not back away from that concept, despite previous criticism.
He cites high levels of I-131 in the Unit 3 stored fuel pool. Since the explosion was two months ago, and given the half-life of this isotope, says it is hard to explain the current level unless there was an original fission event to produce enough I-131 for several half-lives.
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110514e10.pdf is about the ground water at the different units. Some data points are clearly in error, like I-131 on May 10 at Unit 1 has an error in the exponent.
But the graph of Unit 3 is weirdest. It is very difficult to make sense of the ratios of iodine-131 to the cesium activities. Unless one assumes errors in exponents at several dates.
  • #7,407
nothing outstanding or surprising. the clueless are promptly learning that a: the radioactivity is distributed in spots, and VERY much in spots (several orders of magnitude difference between hotspot and area around it) and b: the poorly done monitoring misses those spots. Then they will learn that c: even good monitoring will miss many of those spots.
On to food testing when they will 'discover' that a good chunk of radioactivity is in samples hundreds times above limit, which are rare, and aren't stopped effectively by traditional random sampling.
  • #7,408
TCups said:
<..>Do you believe that the images you added conclusively refute the contention that "fireball" conflagration of the gas cloud occurred mostly or entirely after the gas was ejected?
No, certainly not. I am just saying that the simplest explanation that is consistent with the evidence is not consistent with the claim of anyones seeing the ignition. You can uphold the claim only by adding more assumptions to the explanation, however these assumptions would seem to be added, not to make the explanation consistent with the evidence, but to make it consistent with this extraneous claim.
  • #7,409
MJRacer said:
Please see:
Is it possible that the mudstone is considered bedrock? The seismic sensors discussed in the scientific article are down to 143 m and show consistent accelerations with those at 40m and 17 m. The site discussion says that the new unit is partially embedded in mudstone.
When the news article says "There is bedrock 46 meters underground." does that mean there is no bedrock until you go down 46m or does it mean there is at least 46 m of bedrock in which to put a storage tank?
Look at those old pictures of the construction of Brown's Ferry. They show extensive excavation. In the midwest there was a second plant at Callaway that was cancelled. The foundations had been excavated down to limestone bedrock. In an area as earthquake prone as Japan is it even conceivable that they wouldn't make the foundations as firm as possible?
  • #7,410
Curium said:
Any alternative explanation for where this isotope came from?
There is that stem flow from under the top cover of the reactor...
Curium said:
Also he says that the fact Unit 4 SFP storage racks are intact means that physical fragments of plutonium MOX fuel, found 2 km from the reactor site, could only have come from the explosion of Unit 3 SFP. And calculates that a projectile distance two kilometers implies a supersonic launch velocity in the explosion. (Detonation in which the shock wave expanded faster than the speed of sound)
The only source about all this 'MOX fuel piece found far away' thing is Gundersen himself. Or at least I could not find anything else, and please inform me if anybody could.
  • #7,411
MJRacer said:
Please see:
Those articles are between unclear to confusing.
One discusses Unit 6 and how it is partially imbedded in mudstone down at 17m. What is the other part sitting on?
The other article says a holding tank location has waterproof bedrock down below at 46m. Where do any leaks spread from the bottom of the tanks while traveling down 46 meters?
Might drill a big hole 46m deep and put some metal casing in it to make a holding well. Could get lucky and strike oil.
  • #7,412
Gary7 said:
According to the Tepco site, Fukushima Daiichi is built on bedrock.
http://www.tepco.co.jp/en/challenge/energy/nuclear/plants-e.html
And according to this seismic study, reactor N°6 which is founded 17m below ground level is embedded in MUDSTONE as we already mentioned it here... (see page 1 and 2)
http://www.iitk.ac.in/nicee/wcee/article/9_vol3_733.pdf (oops, sorry some were quicker to post!)
The reactors 1 to 4 are not so deep underground i think, but this confirms that they are not on bedrocks but on mudstone. And mudstone (which is dryied mud basically) is not bedrock. Except for Tepco maybe.
An other example of lies in communication strategy IMO.
To RAZZ and NUCENG:
Re-read the exact sentence in the study linked above: "The reactor is partially embedded and is founded on mudstone", which is different than your wording! It doesn't say it is PARTIALLY FOUNDED on mudstone, it says it is partially embedded!
  • #7,413
Mudstone is a second class bedrock. If exposed, it would erode rather rapidly compared to say, granite.
  • #7,414
etudiant said:
You are surely correct, a pure hydrogen explosion or combustion is a pretty low key event, in fact the flame is invisible, at least afaik.
So the orange fireball from reactor 3 strongly indicates substantial additional combustible/explosive material was involved. Normally flames are luminous because of white or red hot particles, generally of carbon, that are carried in the heated flow. Where these came from in this case is not yet clear.
There is no need for an assumption of the presence of any additional combustible/explosive material. While in a testtube with pure hydrogen you can well produce a near colorless flame, in a Fukushima reactor you can hardly have a hydrogen explosion without producing concrete dust, and concrete dust in the heat zone will glow white, yellow or red depending on its temperature just as good as carbon particles. The blasts in unit 1 and unit 3 glowed just like they would be expected to do when a hydrogen combustion heats concrete dust.
  • #7,415
Once the foundations are in place the site would be backfilled around the foundations to reach current levels, In the US there are extensive provisions for controlled runoff and draining to ensure potential released of ground water are not contaminated or if contamination exists, that it is monitored and reported. Would that help stabilize the mudstone so it wouldn't erode?
  • #7,416
Regarding the article discussing cesium found in Tokyo:
Although I didn't sight the actual Asahi article myself, I read the article that was copy & pasted onto the Japanese website, as well as the newspaper clipping that was linked, and they both look to be legitimate. The samplings were apparently taken at various locations in Tokyo, Chiba, Saitama, Ibaraki, and Fukushima. The earliest sample is from March 19th (Fukushima, 27650 becquerels/kilo). The most recent sample was taken on April 20th from the city of Tateyama in Chiba (127 becquerels/kilo) and the city of Kamisu in Ibaraki (455 becquerels/kilo). Tokyo's highest reading was from Kameido in the suburb of Koto-ku (3201 becquerels/kilo) sampled on April 16th.
  • #7,417
Yes, the article is real. I obtained a copy of yesterday's Asahi Shimbum from a neighbor.
The article is on page 5 from the 15th May. I've scanned the full article for those who are interested.
  • #7,418
Thank you very much indeed.
  • #7,419
Caniche said:
Just can't remember the Hindenberg mushroom cloud and that was a big hydrogen sucker.<..>
source http://www.aerospaceweb.org/question/investigations/q0277.shtml
  • #7,420
pdObq said:
Thanks for looking more closely into that!
1. Yes, that might be true in this case. But another safety feature that seems to be missing are redundant SFP "core spray" lines.
2. Oh, ok, that might explain the possibility of pre-existing corrosion on the roof structure. OTOH, isn't the SFP water cooled, so that in principle it shouldn't be hot and moist there?
3. Yes, one probably would need more cooling capacity, if so far one relied on part of the cooling done by evaporation.
4. Agree, you don't want a concrete slab to fall onto your fuel (that's a somewhat recursive requirement...).
5./6. Yes, so additional venting and level sensors might be needed. But isn't the water level in the pool monitored by some sensor anyway?? E.g. that skimmer tank water level sensor?
One possibility that avoids some of those points would be to not cover it completely, but only so much that no big object can fall in.
Interesting, thanks for the link (Haven't had time to read it fully yet, though.). I think they should reconsider such threats in view of Fukushima. I mean it seems pretty obvious now that SFPs "on the attic" are a major possible security and safety risk.
I would hope so to, although that might deserve a different thread, such as lessons learned or reconsidering BWR safety. And my question about SFP shield plugs was not only with regards to the roof collapsing but also to threats such as airplane crashes, as considered in the document linked to by jlduh.
See the attachment in this post by M&M https://www.physicsforums.com/showpost.php?p=3294820&postcount=6534 . I browsed through the whole NRC document now, but I could not find any additional details about the "Fuel Storage Pool Shield Plugs", 4x 4.5 tons, mentioned there. There is also "Fuel Transfer Shield/Cattle Chute", 2x 16.5 tons, and the "Fuel Pool gates", 2x ~1 ton. These sound more related to the shield wall and gate between the reactor well and the SFP.
I found a list of radiation monitoring equipment instead, with detector types and measuring ranges if anyone is interested in that. It's on p. 68 & 69 (one page is missing), Table 11.5-1 "Process and Effluent Radiation Monitors". CAMS seems to be a different sub-system, it is not on that list AFAIKT. There are a whole bunch of lists of other instruments and stuff in that document, as well.
OK, the pool shield plugs referenced are interlocking stacked shield blocks that fill in the area where the fuel transfer chute connects to the reactor cavity. They aren't part of the fuel pool per se. They just fill in the area aroung the drywell cap to provide biological shielding during normal operation. Once these plugs are in place the hemispheric shield plugs are added to top off the reactor cavity above the drywell cap up to ffloor level.
  • #7,421
Well, again what you describe has a name and has been proved by experience at Tchernobyl: contamination in leopards spots.
I repost this map of Tchernobyl contaminated zones (Cs-137) because it is very informative about real life contamination transportation and redeposition:
http://www.netimago.com/image_200655.html I would like to know what could be the reasons why this phenomenon wouldn't apply for the Fukushima plant, looking at how things evolve at the reactors?
My feeling is that we start to see appearing, through the various infos and measurements released in the press, that kind of hot spots (first towards North west axis, then recently towards south west axis, maybe including Tokyo), even at high distances from the plant (and much further than the 30 kms zone), and that's why some governors get angry because of lack of fine "tuning data" to identify these spots and decide what to do (see my post here:
https://www.physicsforums.com/showpost.php?p=3304552&postcount=141 )
Then how do deal with that kind of hot spots, that's all the question. 1) Expanding the evacuation zone in a circular manner with increased radius around most of the hotspots is a solution... more easily done in Ukraine than in Japan due to population density, i admit! 2) Do a real fine tuning based on reliable and updated data. But even this could lead in the future to much more evacuations if hotspots multiply...
The other question is, can this second fine tuning be done in a timely and reliable manner?
And as you said, can statistical sampling on food detect properly the consequences of these hotspots, which are probably like fractals shapes: from macro hotspots to very local hotspots because of local redeposition conditions and concentrations? Japan has lots of mountains which also create a much more complex redeposition pattern scenario than on flat lands i think, because of local geography/meteorology which are characteristics of mountains areas.
  • #7,422
Thanks. At the end of the article, it is mentioned that these results will be communicated at http://www.icas2011.com/ on May 24th (1). I guess the press will be more talkative about them from that date on.
(1) The program for "S22) Urgent Symposium Analytical Sciences Facing Radioactive Pollutions" is available at http://www.icas2011.com/program/program_list.html#24PS22 ; See also http://www.icas2011.com/program/program_list.html#23pB2 for May 23rd
  • #7,423
Thank you. So mostly a mess to clean up, then, from getting seawater in a reactor, and not necessarily a corrosion concern?
  • #7,424
The word 'mudstone' by itself doesn't tell us much. It just means that once upon a time it was a muddy, i.e. fine-grained, sediment. Without further qualification it doesn't say anything about hardness, strength or resistance to weathering and erosion. Mudstones with a silica-rich matrix, subjected to relatively high pressures and temperatures millions of years ago, can be almost as strong as granite and certainly good enough for building power stations upon. Others might not be. Any sort of mudstone is likely to be pretty impermeable to water, at least before being fractured by earthquakes.
  • #7,425
Well again, even if this a slightly different subject from the Daichi plant, I have a hard time understanding how seawater can enter so easily (i say "easily" just because it just happened...) into a BWR reactor. But I understand that unlike a PWR, in a BWR there is no real secondary circuit (i mean closed loop), so the steam is condensed into water in the condenser (which is cooled by seawater if my understanding is ok) and goes back into the reactor right?
So any leak between the two (the sea water/the steam or condensed water) can theoretically (and practially in this case) lead to either seawater entering the reactor or contaminated water going back to the sea?
I would be surprised if this Hamaoka event was the first in BWR history with that kind of problem. Any knowledge on that?
If i rely on what has been said for Daichi reactors, it seems that the experts have very few data on the effects of seawater inside BWR reactors. And by a very surprising collision of events, we just learn that 500 tons of seawater has probably enter one of the reactors of Hamaoka plant during cold shutdown procedure!
Can someone confirm if this seawater actually entered the reactor (I mean the pressure vessel)? Or is it somewhere else?
If it's the case, and as i said yesterday, it seems god is recently playing dices in the nuclear game and wins much more than calculated by experts, don't you think?
  • #7,426
Corrosion in salty water is in general much faster than in fresh water, so it can be a problem - but not because of the radiolysis.
  • #7,427
Cl- ions are always a primary corrosion concern, but radiolysis is not relevant in this case: Cl- ions are present in saltwater by default.
  • #7,428
The observations I make are these: the southeast corner of Building 3 three (roof and south wall) visibly expands, blows out, and ejects a relatively small white puff of gas laterally, which almost immediately turns to a somewhat larger, self-consuming orange fireball.
This is followed temporally by the more generalized explosion of the entire upper portion of the building and a rising column of dense gas, apparently steam and smoke, directly over the spent fuel pool (as in pool of hot water) -- a column of smoke with a large amount of "lift", and an appearance consistent with a littoral explosion.
The post-mortem images of Building 3 seem to confirm both localized thermal and mechanical damages at the southeast corner, over the SFP as well as more generalized lateral and vertical blast damages, consistent with those observations.
A large increase in measured radiation accompanied the explosion(s), perhaps consistent with explosive venting of the primary containment, or some portion of the contents of the spent fuel pool, or some combination of both.
Time does not permit me to again append the supporting visual images as I must be off to work just now. Perhaps I can do so in an "edit" at a pater time, or perhaps the content of several thousand preceding posts will suffice.
Therefor, please, I ask, do excuse any extraneous or inaccurate claims I have made or implied in my perhaps deeply flawed and sometimes incoherent attempts to arrive at a "simple" explanation to a complex set of events. If "ignition" is the incorrect term for a white puff of gas turning fiery orange, then I stand humbly corrected. Thank you for your patience and thoughtful critique in any case.
  • #7,429
Even if it could, you're much better off drawing a line around areas with hotspots, because the hotspots move all the time. Bio-accumulation sucks. The water cycle blows.
Yes, even radioactive badgers.
http://chornobyl.in.ua/en/badger-meles-meles.html
  • #7,430
SteveElbows said:
There are only a few images from the period after 3 blew but before 4 went up.
I don't think the resolution is high enough to be 100% sure, but it looks to me like there was already debris fallen onto the pipe in the place where it is later shown to be broken. And I think its always been a pretty likely bet that it was falling walls of reactor 3 that caused the damage.
Thanks for finding those. They don't look conclusive to me whether the pipe was damaged or not. I'll keep looking.
  • #7,431
In an article dated March 25th dealing with Fukushima Daiichi seawater corrosion issues, Euan Mearns made the following quote :
In this earlier post I quoted TOD commenter donshan who spoke authoritatively on corrosion issues:
" I do question the use of seawater cooling. I hope the Japanese have considered the danger they have created by introducing oxygenated seawater into this stainless steel piping and pressure vessel at boiling temperatures. These stainless steels are extremely susceptible to chloride stress corrosion cracking:
Since residual weld stresses and tensile stress in piping, valves, control tubing, etc. are always present, Standard Operating Reactor water quality standards require keeping chlorides at parts per billion levels. Seawater has about 3.5% or 35 grams per liter of salinity! (i.e. 35,000,000 parts per billion)
I have no way of knowing how many days they have before a stainless steel component suddenly cracks, but if it were me, I would be advocating an emergency program to get pure deionzied cooling water back into this stainless steel system ASAP. In laboratory tests in boiling chlorides, cracking of stainless in tensile stress can occur within days- they have at most a few months if they keep boiling sea water in this system and yet another disaster occurs."
http://www.energybulletin.net/stories/2011-03-25/fukushima-dai-ichi-status-and-slow-burning-issues
  • #7,433
Second-hand information: cesium has a habit to travel with water and easily deposited in the top soil. So: hot spots on top soil will be formed around every rain-, waste-, interrogation-pipes, ducts, canals. Roads, roof-drainings. This works like a kind of 'enrichment', so such hot spots will appear in less contaminated areas too.
Such hot spots can be neutralized by replacing/removing of top soil. But they might reappear later.
So: evacuations are not practical as most of Japan might be affected up to various levels. They must do regular checks and frequent soil-replacement.
I hope they can develop some really effective soil-decontamination process. They will need it.
  • #7,434
I found, on a different but somewhat related topic concerning the Daichi reactors, this article (and the links at the bottom of the page) informative about the effects of radiations on aging process of materials:
http://www.lucaswhitefieldhixson.com/accelerated-aging-effects-radiation-materials-fukushima-daiichi
One of the most impressive is the huge increase of thermal expansion effects of irradiated steel:
http://www.nuc.berkeley.edu/courses/classes/NE-220/Introduction%20PDF%20format.pdf SEE PAGE 6/30)
  • #7,435
It is most certainly in the reactor, at least part of it. You see, these reactors only have ONE cooling loop. The water is heated in the pressure vessel, becomes steam which drives a turbine and is then cooled in a condenser, later to be pumped back into the reactor. The condenser itself is cooled with seawater. The seawater is pumped into the condenser, chills the pipes through which coolant flows and goes out back into the sea. Some of the seawater found its way into the coolant loop.
The 400 ton figure is suspect to me. In my mind's eye, I can see them measuring concentration of salts in the coolant loop and saying "oh that's the equivalent of about 400 tons of seawater". No need to tell you how many things may be wrong with that, no?
Also highly suspect is the lack of any mention of radioactive releases into the sea. There should be all sorts of interesting activation products in that condenser, I can't believe that water was going into the coolant loop, but not out again... The reactor (or at least the steam condensation chamber) would have been flooded right sharpish.
Or perhaps that's what happened? They detected the hole by abnormally high water level somewhere?
Those playing dice are the penny-pinchers who defer maintenance and write bogus safety analyses, not the gods.
  • #7,436
So there might not be so much value in having a cover on the pool. I doubt the prompt criticality thing is legitimate concern, but I'm no physicist. I'm not sure what a cover is going to do to protect the spent fuel from terrorist attack either.
I'm guess the fuel pool is located there out of necessity. They can't get the hot fuel out any other way. The location near the reactor allows refueling without removing the fuel from the boric acid. Otherwise there would be an extended shutdown while waiting for the spent fuel to 'cool down.'
  • #7,437
pdObq said:
I have used this link to check the Japanese text.
It is not a document from TEPCO (maybe nobody has ever claimed that it was, but I want to mention this just to make sure there are no misunderstandings).
The text is a critical (no, condemning) description of how TEPCO, 40 years ago, after realizing that the weak clay and sandstone in the upper 25m of the building site would have made it necessary to drive foundations as far down as the layer of relatively firm mudstone (泥岩層) below, removed the top portion of the building site, which made for easier access to cooling water and loading facilities for fuel easier. The current design is based on the assumption that a tsunami would at most have a height of 5.7m. The included drawing is self-explanatory.
Respectfully submitted for your consideration, but it seems that none of this is new information or a revelation.
  • #7,438
That is the concern. Basically introducing seawater into the cores probably lead to some damage by corrosion, and even if they had successully cooled the reactor cores, they would have had to decommission the fuel, control rods and core internals. Stainless steel 304 would suffer pitting corrosion and stress corrosion cracking. Zircaloy-2 would be normally resistant to seawater unless there was a fair amount of ferric chloride formed in the cooling water, in which case, Zircaloy would corrode. It is suspected that the seawater did enhance the corrosion of Zircaloy and consequential hydrogen production. However, unit 1 exploded before they introduced seawater, whereas unit 3 exploded after introduction of seawater.
There have been a couple of BWRs with saltwater intrusion. One through some low pressure turbine blades through the condenser which then allowed saline river water to enter the reactor. The salt content was very low (perhaps a few thousand ppm), but the reactor was a reduced power and quickly shutdown. I believe they flushed the system and restarted after they removed the low pressure turbine stage. I don't remember the details of the other since it happened more than 20 years ago.
  • #7,439
Insufficient decontamination of workers and lack of adherence to related rules is being described in this article:
http://mdn.mainichi.jp/mdnnews/news/20110514p2a00m0na014000c.html
  • #7,440
So, we now have two facts:
1. having a spent fuel pool on the topmost floor is stupid risky and
2. it is unavoidable in this reactor design.
The conclusion must be that this reactor design is stupid risky. Which means they all should have been scrapped a long time ago or at least not allowed to go on operating past their design lives (but I'm politicizing again, aren't I? At which point does engineering fact become subject to political debate?).
  • #7,441
Good point. I live near Fukushima and I'm wondering if there is any way I can test for radiation on my own. My spouse and I are particularly concerned about the health of our young children.
We want to know if we can test food, water, ground surfaces and background radiation on our own, or if we can only trust the government to keep us safe.
  • #7,442
To contribute to the mud stone / bed rock discussion, I would imagine the the soil beneath the NPP to be very much the same as that what has been evacuated from the mountan, and judging by the steep unprotected slopes it is a fairly solid geological structure, no soil with bolders but a tending towards a homogeneous structure. So ground water leakage would be slow in cracks and layers within this mud stone massif I presume.
  • #7,443
A cover would only serve to keep foreign material or debris out of the pool. The Mk I containment is really to keep the weather/storms/high winds away from the reactor service floor.
Irradiated fuel must be moved under water in order to protect the workers from radation. That is the main reason for the location of the spent fuel pool. The Mk III containment design has the SFP in a separate building and an improved containment structure.
The spent fuel pools are normally cooled. They must accommodate a full core offload which would have significant decay heat compared to fuel which has been permanently discharged.
  • #7,444
If you run a windows XP operating system you can simulate and watch the plant parameters unfolding. Download for free PCTRAN pre-configured for Fukushima, or other reactor types, from this site http://www.microsimtech.com/ (It does not work for Vista and above!)
(I think Tepco might have used this for their latest unit 1 meltdown simulation.)
Hers are the studies for unit 1 and 3
http://www.microsimtech.com/Fukushima.html
http://www.microsimtech.com/downloads/Fuku3.htm
and SFP-4 simulation
http://www.microsimtech.com/downloads/Fuku4.html
however it has a mistake, they assumed the unloaded core to be 15 days old instead of 90+days (unit 4 was shut down end November If my memory serves me right)
  • #7,445
Establishes purchasing groups, and tests everything that counts as food.
We did that in Germany in 1986.
The state will not help.
You need an expensive instrument. This can be paid only in communities.
Draws conclusions from the measurements.
regards from germany and sorry my bad english.
  • #7,446
One would need to have a Geiger counter with which one could monitor radioactivity, but it will not indicate which isotopes. To discern which isotopes are present requires a gamma spectrometer, which might be available at some universities. Gamma spectrometers are rather expensive.
http://en.wikipedia.org/wiki/Gamma_spectroscopy
One must also have experience in using a gamma spectrometer including how to set it up, calibrate it and use it. A Na-I type would be sufficient.
  • #7,448
This article from Asahi gives an explanation of how the leakage could be one-way:
http://www.asahi.com/special/10005/NGY201105150003.html
According to the article, the seawater is used to cool steam. So a leak in the barrier would lead to water going into the steam side, but not vice versa. The article includes a speculative leakage path sketch:
They mention that the leak was detected by noticing a rise in saline concentration in the re-condensed water. Then they switched to a different cooling system. No explanation of where the 400 ton estimate came from.
  • #7,449
That's also one of the main subjects the documentary from Adam Curtis cited above is considering:
https://www.physicsforums.com/showpost.php?p=3304718&postcount=7448
  • #7,450
Default_user has it entirely right.
This is not a problem that is effectively addressed at the individual family level, because even if you check the food with a geiger counter, it gives no insight regarding the outside exposure levels.
This is very much a community issue, particularly as the contamination will be patchy, with local hot spots, something the central government with its need for simple measures cannot easily adapt to.
There may be a role for the central government to help localities to add monitoring equipment, but the real work will have to be done locally, to make sure playgrounds and public sites are adequately clean.
The food supply will inescapably be more radioactive than before. Expect maximum permissible levels to be raised, perhaps substantially. Unless Japan is willing to import much more of its food and to shut down farming in a large part of Honshu, the margin of safety will be less.
49K
448K
273K
16K
11K
