Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #8,011
tsutsuji said:
Is it possible to locate the seawater pumps of Fukushima Daiichi precisely on satellite views or on the map at http://www.tepco.co.jp/en/nu/fukushima-np/f1/images/f1-sv-20110323-e.pdf ? According to http://www.yomiuri.co.jp/dy/national/T110410003477.htm they are "near water intake outlets". According to http://www.asahi.com/english/TKY201104060126.html they were "not located within a sealed structure" and had been designed at a time prior Hitachi and Toshiba gained the experience that would lead them to locate seawater pumps "within buildings".
Ok, on google maps i checked but it is very difficult to see it due to the poor resolution. On the picture below, you see on the right the four water intakes (one for each reactor, N°1 is smaller because the reactor is smaller in fact). Then if you move a little bit on the left, then you will see some spherical grey objects, aligned parallel to the intake, these are the pumps: 2 for N°1, 3 for N°2 to 4 but at N°4, because they were doing maintenance on the core, it seems they were also doing maintenance on the pumps because they seem to be removed on this picture. You can see that they are very vulnerable from tsunami standpoint (they must be close to the sea to some extent of course!) and they are also critical in order to keep the cold source working!
http://www.netimago.com/image_202942.html
I add this other satellite view, you see very well the difference between the N°1 and the others (size of intake and N° of pumps)
http://www.netimago.com/image_202943.html
I add a picture showing how they look like -these are from N°5 reactor and got hit by this big blue structure, but they look similar to the others:
http://www.netimago.com/image_202944.html
Do you see them?
Note 1 : I add this other picture showing the all 6 reactors from the sea, so you see very well the size of the various intakes and the grey pumps in the alignment:
http://www.netimago.com/image_202948.html
Note 2: At DAINI plant, which is newer, they added some buildings close to the sea but to me, these pumps are still outside, close to these buildings (the 3 aligned white/grey circles each time)
http://www.netimago.com/image_202950.html
  • #8,012
  • #8,013
MiceAndMen said:
The images look just as distorted as they did 2 weeks ago. Is there something new and noteworthy there?
Hm? What distorsion?
EDIT: the camera was focused on unit #4 and panning left to right, then back again.
  • #8,014
jlduh said:
Do you see them?
Thank you. Thanks to your pictures, I think I could see all of them, except those for unit 4. Have they been wiped out by the tsunami, or have they already been removed for cleanup or repair ?
Their absence is conspicuous on :
Are you sure ? Looking at that picture, it is difficult to say if the blue structure is close or far enough behind.
  • #8,015
SteveElbows said:
More detailed analysis of accumulated turbine building water from march sampling finally published:
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110522_04-e.pdf
Any comments?
Yep. Ruthenium, Strontium, Uranium and Plutonium present. That's used fuel, basically. It needs to have melted down for this stuff to be mobilized, I think.
  • #8,016
Well, on this other picture taken March 12, after the tsunami, you see that in the area close to intake N°4, there were some blue covers at the intake, and i think this tend to make e think that they were doing some repair in this area when the tsunami hit.
http://www.netimago.com/image_202962.html
But this is a guess, also based on the fact that N°4 was stopped.
For the blue structure, i don't know if it hit or not the pumps at N°5 but fore sure there has been some damage on this structure.
At first, when the accident happened, i heard in the news that they lost first the cold source, then the electrical power. I don't know if all the pumps were still fully functionnal after the tsunami, in addition to loss of electrical power, in fact...
  • #8,017
jlduh said:
I agree. I was talking about the withe dots for example in this picture already posted, which are a totally different subject than the fringing in the satellite image, as i mentionned it...
http://www.netimago.com/image_202891.html
Yeah, I kind-of ignored that subject because those white dots are definitely an image artifact that I have never seen before. The color white comes when the bayer-filter registers all three color channels as fully saturated. The only artifact that comes close is hot pixels when shooting with high ISOs and long exposure, but they aren't white, or very rarely are.
  • #8,018
Any comments?
For experts: how can you interpret that water from N°1 is significantly less contaminated (orders of magnitude lower for most isotopes) than N°2 and N°3, and that Ba-140, La-140 (short half life) and Sr 89 and 90 are much lower in this N°1 water (see page 3 of pdf)?
Is La-140 a daughter isotope in the decay process of other elements?
  • #8,019
The "funny" pixels are not always white. It looks like impulse noise affecting one or more color components to me. I've seen artifacts like these when the CCD power source had noise or when there was some RF interference. There can be several places where the noise could be introduced: in CCD, in ADC converter or when transfering digital data from imager to the processing system. Sometimes the data transfers are done using YUV data channels, so a single bit off could change the overall luminance or color. It's not at all certain that radiation is causing this.
  • #8,020
The U, Pu and Ru are below detection limits as the are all reported as < X.
While there certainly is Radioactive Sr present in large amounts (3rd table), most of the Sr in table 2 (by mass) will be stable Sr from sea water.
Sea water will also contain trace amounts of U, though that leads me to my 3rd point, the detection limits in table 2 are two high to be useful from the point of view of detecting fuel failure etc.
Crap load of 134/137Cs and 90Sr to deal with for long-term clean up though. Pity the table didn't give volume estimates of the various "pools" so we could easily convert this to total inventories of the isotopic activities.
  • #8,021
I never said it was ;) I tried to ignore the subject because my knowledge of how an image is formed on a sensor and it's path to becoming a RAW or JPG is quite limited. I do know that it is not caused by the cameras normal operation under normal operating conditions.
  • #8,022
I'd like to hear an expert on this too,
My non-expert thinking is the I and Cs isotopes are more volatile and more readily escape the fuel than Sr so the increased Sr in # 2 and 3 likely means much greater damage to fuel and containment for those units.
  • #8,023
One can question this "<". For U in page 2 they explicitly stated "ND" (not detected?). Moreover for Zr in page 2, the detection limits would not be the same for each sample analyzed ... (I understand Italic numbers as being recalculated from analysis of diluted solutions).
Is it plausible that JAEA may not be able to detect concentration lower than 1.2 mg per liter for Pu?
  • #8,024
Some details about Daini are provided in this article :
Unit 3 was undamaged and continued to cold shutdown status, but the other units suffered flooding to pump rooms where equipment transfers heat from the reactor circuit to the sea - the ultimate heat sink.
http://www.world-nuclear-news.org/RS_Insight_to_Fukushima_engineering_challenges_1803112.html
I wonder how enough seawater pumps at Daini unit 3 could remain safe after being flooded by the OP+6m ~ OP+14m wave reported and depicted on dramatic pictures at http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110409e10.pdf, if they are located outdoors. How can we explain the Daini unit 3 miracle ?
The following attachments are from , a video explaining how the Tokai NPP (located further South in Ibaraki prefecture) survived the March 11th tsunami. The video says that the seawater pumps are enclosed in "more than 6 m" high walls, while the tsunami wave was only "more than 5 m" high. Two pumps survived. The third pump didn't survive because its wall was still under construction and not finished.
Tokai NPP's pump protecting wall is also depicted on a diagram at http://www.asahi.com/photonews/gallery/infographics/110330_toukai2.html and on photographs at http://mytown.asahi.com/areanews/ibaraki/TKY201104190562.html (according to that article, the seawater pumps are also providing cooling for the emergency diesel engines ; One diesel engine stopped because the seawater pump for that engine was flooded through a hole in the wall. The reason for the existence of the hole is that the wall was under construction ; If the wall had been 70 cm lower, the Tokai NPP might have had the same destiny as Fukushima Daiichi)
  • #8,025
Oh I thought it was odd that U was given as ND while most others are reported as <X. The analsyis here is evidently a relatively rough chemical analysis as only the major ions of sea water are given values (Na, Ca, Cl etc) as even expected minor ions like Si are only given <X. From my own experience an analyitical lab will give you an actual value OR give you <X where x is the detection limit in question.
I'm not sure I follow you on the Zr, the < X value is the same for all straight samples and reduced by the dilution factor as appropariate for dilution runs.
The inability to detect Pu I think is another reflection of this being a wet chemical method and not a radiometric method which would be far superior at detecting Pu.
In all honesty the detection limits seem piss poor for the question that will obviously be asked from the data (fuel failure?) but more appropriate for asking what % is sea water and water % is fresh water sourced in each sampling pool.
For a comparison I recently have gotten some chemical elemental (30 elements) analysis data back for some work I'm doing and looking at it the reported detection limits vary by element but for example they have a detection limit of 0.05 mg U /kg soil and 0.5 mg Mo/kg soil for the lab we went with. Seems far better than Tepcos lab sadly.
  • #8,026
Yes. It is daughter of Ba-140, which in turn can be found in the decay chains of both U-238 and U-235, iirc. But I can't find a chart so... let's wait for the experts.
  • #8,027
Er.. you mean fission product of U I expect.
  • #8,028
  • #8,029
zapperzero said:
This. From the live feed. No zooming and no cropping on my part.
Sigh. Try to locate the *pillars*. Do NOT use the outline of the building (walls, corners and roof) since it is obscured by hanging debris, sagging beams, paint spots and such. Then check the pipes in the tower.
  • #8,030
I think that the missing pumps were swept away by the tsunami. One of them (an isolated pump due west from unit #2) is still lying on its side, not far away from its presumed base. I would guess that the other missing ones were rolled into the sea by the receding wave.
  • #8,031
[PLAIN]http://www.yomiuri.co.jp/photo/20110419-495936-1-L.jpg
Diagram from http://www.yomiuri.co.jp/science/news/20110419-OYT1T01008.htm
It shows that in order that the contaminated water moved from unit 2 does not leak into the ground water, it will not be allowed to fill more than the second basement floor of the process main building.
  • #8,032
I see I have a reputation which is following me , and it's not a good reputation
Anyway. I was interested in the pictures because you can just make out a gantry crane and the huge beam it travels on. Second pic shows a tower that is rarely present in the feed.
  • #8,033
[URL]http://www.asahi.com/national/update/0405/images/TKY201104050670.jpg[/URL]
This diagram is taken from http://www.asahi.com/national/update/0405/TKY201104050625.html
The upper part is Fukushima Daiichi.
The lower part is Fukushima Daini.
The horizontal red rectangles are the emergency diesel generators.
The small vertical red pins are named "seawater pump"
The quadrilateral shape around Daini's seawater pump is named "seawater pump building"
扉 is "door".
According to this diagram, at least the pumps sending seawater to provide cooling for the diesel generators are indoors at Daini. Perhaps only these pumps are indoors while the other pumps are outdoors ?
  • #8,034
I am a non-expert but still trying to answer this one as I have a theory.
They did not spray sea water to unit #1 SFP.
AFAIK the first spray they did (and all sprays after that) were done using fresh water.
March 31st 13:03~16:04 Water spray by Concrete Pump Truck (Fresh water) ...
The really contaminated water in the unit #1 could be in the basement of the reactor building whereas the water in the basement of the turbine building could have come mainly from tsunami/SFP sprayings. Also perhaps some groundwater has leaked in but not enough to affect the levels of contamination heavily.
Once they measure SFP contamination levels in #1 it could further confirm this kind of theory.
The expected result would be to see low-level contamination in #1 SFP.
  • #8,035
http://atmc.jp/plant/rad/
Where in each plant are those outrageous Sieverts per Hour readings coming from? Is it in the control centers? Is there something wrong with the data? Does Sv/hr in Japan mean something different from what I think it means. The readings from Unit Five and Unit Six are frightening considering that they were in cold shutdown at the time of the Tsunami.
  • #8,036
Where in each plant are those outrageous Sieverts per Hour readings coming from. Is it in the control centers? Is there something wrong with the data? Does Sv/hr in Japan mean something different from what I think it means.
First plot is for unit 1, and if you will read tepco data you will see that there was big radiation jump in drywell, but we don't know if this is correct, sensor can be damaged, if data is correct than this could be corium which get into drywell from RPV
http://www.tepco.co.jp/nu/fukushima-np/f1/images/11052306_level_pr_data_1u-j.pdf
  • #8,037
The following article http://astand.asahi.com/magazine/judiciary/articles/2011051100015.html?iref=chumoku expresses the view that most diesel generators at Fukushima Daiichi are water-cooled : "The tsunami hit the seawater pumps and water intake became impossible. As a consequence, the 10 water-cooled emergency diesel generators stopped (...) Unit 2, unit 4 and unit 6 have one air-cooled emergency diesel generator each. (...) Those at unit 2 and unit 4 failed too. They are located high above sea level, which raises the possibility that what failed was the metal-clad switchgear which acts as the electric power receiving end at the building"
A photograph showing seawater pumps being removed for inspection at Ikata NPP can be viewed at : http://mytown.asahi.com/areanews/ehime/OSK201105190135.html
  • #8,038
Maxion said:
The "fringin" on the highlights in the photo is with 99% certancy an optical effect caused by the Earth's atmosphere coupled with the extreme optics needed to get images like this from Earth orbit.
Thanks for your interpretation. So there is 1% left those colored sparkles are optical effects simply from oil? ;-)
I have to look for similar fringed spots in satellite photos of the mexican gulf desaster ...
EDIT: Colored sparkles found here, American Samoa Tsunami, no radioactivity needed :
http://www.flickr.com/photos/digitalglobe-imagery/3969593680/sizes/l/in/photostream/
  • #8,039
Ouch. Let's hope only the sensor broke. We'll know soon.
Btw.: Can such values be reached without recriticality?
  • #8,040
radiation measurement live from Japan
μSv/h
Iitate village, Fukushima pref
39.5 km away from Fukushima Daiichi
http://www.ustream.tv/channel/8000164
Fukushima city, Fukushima pref
67 km away from Fukushima Daiichi
http://www.ustream.tv/channel/8060606
Hokida, Fukushima city, Fukushima pref
http://www.ustream.tv/channel/8073183
Miyagi pref
http://www.ustream.tv/channel/7954538
near Sendai station, Miyagi pref
http://www.ustream.tv/channel/8126354
Mito city, Ibaraki pref
http://www.ustream.tv/channel/7574817
Adachi ward, Tokyo
seismometer(L) & radiation measurement(R)
http://www.ustream.tv/channel/7754813
Shinjuku ward, Tokyo
http://www.ustream.tv/channel/7943728
Tsurumaki, Setagaya ward, Tokyo
http://www.ustream.tv/channel/8278742
Asakusa, Taito ward, Tokyo
http://www.ustream.tv/channel/7658661
Asakusabashi, Taio ward, Tokyo
http://www.ustream.tv/channel/7873981
Katsushika ward, Tokyo
http://www.ustream.tv/channel/7373757
north Tokyo
200km away from Fukushima Daiichi
http://www.ustream.tv/channel/7485012
Kashiwa city, Chiba pref
http://www.ustream.tv/channel/7555976
Chiba city, Chiba pref
http://www.ustream.tv/channel/7960747
Inage ward, Chiba pref
http://www.ustream.tv/channel/7691874
Yachimata city, Chiba pref
http://www.ustream.tv/channel/8211793
Ichinomiya seaside area, Chiba pref
http://www.ustream.tv/channel/7817633
Kuki city, Saitama pref
http://www.ustream.tv/channel/7800484
Yamato city, Kanagawa pref
http://www.ustream.tv/channel/8315787
Tsuru city, Yamanashi pref
http://www.ustream.tv/channel/8244010
Ueda city, Nagano pref
http://www.ustream.tv/channel/7545780
Shijokarasuyama, Kyoto city, Kyoto
http://www.ustream.tv/channel/7752205
Kita ward, Osaka
http://www.ustream.tv/channel/7752284
Kakogawa city, Hyogo pref
http://www.ustream.tv/channel/8207434
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
469K
21K
  • · Replies 763 ·
283K
  • · Replies 38 ·
16K
12K
