What is Charge and Why Do Ions Have Positive or Negative Potential?
  • Context: High School
  • Thread starter Thread starter AudioFlux
    Charge
The discussion revolves around the concept of electric charge, its definition, and the implications of positive and negative charges in the context of electric potential and work done in electric fields. Participants express confusion about these fundamental concepts in electricity and seek clarification.
  • Some participants question the fundamental definition of charge, suggesting that it is not fully understood and can only be described indirectly.
  • There are claims that electric charge is a theoretical construct used to explain observed effects, with no consensus on its true nature or origin.
  • One participant describes charge as the force produced by charged particles on each other, while another refers to it as a coupling constant in electromagnetic interactions.
  • Several participants discuss the implications of moving charged ions within electric fields, noting that work is done due to electrostatic repulsion.
  • There are inquiries about the meaning of specific charge values, such as that of an electron, and whether charge can be considered a physical entity or merely a measure.
  • Some participants emphasize that the definitions of energy and scientific theory are crucial to understanding the context of charge.
  • One participant suggests that charge can be conceptualized in terms of electric field lines and their interactions.
Participants do not reach a consensus on the nature of charge or its definition. Multiple competing views and uncertainties remain regarding the fundamental understanding of electric charge and its implications.
Limitations include the lack of clarity on the origin of electric charge and polarity, as well as the dependence on definitions that may vary among participants. The discussion reflects a range of interpretations and theoretical perspectives without resolution.
AudioFlux
what is a "charge"?
hi,
what exactly is a charge? how do you define it? why is a positively charged ion at a higher potential difference than a negatively charged ion? why is work needed to be done on a positively charged ion to move it out of an electric field of another positively charged ion?
i'm very confused with electricity, and i hope i can understand it better if these doubts get cleared :)
thanks in advance
See this, I think it will shed some light on your questions.
AudioFlux said:
hi,
thanks in advance
Nobody understands charge. We can only describe it, indirectly.
In fact, the entire universe is composed of energy, but nobody has the foggiest idea what regulare energy actually is, much less "dark energy" if that exists. That's why physics is great fun. You can make up the most outlandish theory you want and nobody can prove you wrong. They can only present an argument against your theory.
I think you should look up the definitions of energy and scientific theory. One cannot simply make up theories, they must have very good reasons.
AudioFlux said:
hi,
thanks in advance
A charge is simply the force produced by a charged particle on other charged particles. Electromagnetic charges have a + and a -, aka postitive and negative.
A positive ion that is moved out of an electric field of another ion is having work done to it by that ion. Or more accurately both ions repel each other, performing work on each other and transforming potential energy into kinetic energy.
See here for more info: http://en.wikipedia.org/wiki/Electric_charge
Electric charge is a theoretical given. It is an unexplained starting point for theoretically explaining special effects. Theoretical explanations may or may not be correct. They are educated guesses. No one knows what electric charge is. We do know a great deal about its effects. Those effects are seen as patterns in changes of velocity. We know neither the origin of electric charge or of polarity.
James
James
Please, don't start this again, you will only confuse the OP and others even more. We have a definition of charge which explains what the OP is asking. I suggest you defer to that unless someone wants to talk about theoretical physics or something.
James
Third thread in a row, really? And you ask why they get closed down.
The terms under physics are clearly defined, especially what the OP is asking.
A charge is a coupling constant characterizing the interaction between matter fields with the electromagnetic field.
you can think of charge as where the electric field lines end
thanks for your responses. let me elaborate my question, when we say an electron has a charge of -1.60217646 × 10-19 coulombs, what does it mean? is it like some sort of an energy or a virtual "thing"(or assumption) or is it something you can weigh?
The coulomb (symbol: C) is the SI derived unit of electric charge. It is defined as the charge transported by a steady current of one ampere in one second.
The problem with measuring charge, is that the closer you get to the particle the larger the force is. So instead of just saying the force is X amount at X distance, it was defined by the number of charged particles that move across a point when 1 volt is applied for 1 second.
Charge is just a name to describe the properties of electrostatic interactions. Just like mass, what can you say about mass?
Positive charges do work when they move closer is due to the electrostatic repulsion between charges. When forces move a distance in the direction work is done. Again you cannot explain why, just like why gravity is always attractive? Yes, you can use quantum mechanics (Relativity also for gravity) and string theory, but still you cannot explain quantum mechanics.
Coulomb is just a SI unit from convention, derived from Ampere defind by Ampere times second. Again and again you cannot ask why, just like asking what does it mean by I have mass of 60kg. It's just measured using the unit. If you use a banana to describe the charge of a proton, then electron just have -1banana of charge. It's just a relative measure used to compare the property of objects.
it means that that is how many electric lines of force end at that point
each line can be thought of as having a tension along its length and it repels all other lines.
all lines must end at charges.
http://www.google.com/search?q=electric lines of force
http://en.wikipedia.org/wiki/Line_of_force
OK, here's what WIKI says:
https://secure.wikimedia.org/wikipedia/en/wiki/Energy
There doesn't seem to be any "scientific theory of energy."
Energy is an abstract concept that helps us conceptualize theories based on the results of scientific experiments.
Theories do one thing and one thing only: they predict future events.
It's not what you are taught in high school, but that's the truth about theories.
Nobody has the foggiest idea what energy actually is.
That's not a theory, it's an opinion.
Please do not CHANGE this thread into ANOTHER ad nauseum thread on "what is energy?".
Zz.
Zz.
OK, sorry.
delete, dupe
"...A charge is simply the force produced by a charged particle on other charged particles. ..."
Electric charge is not a force. Coulomb's equation defines electric force. Electric charge appears in that equation as a part of that which is believed to produce electric force. Electric charge is not understood and that is why it is one of the indefinable properties of physics along with distance, duration, mass, and temperature.
James
James
No, do NOT start this again. Charge IS defined in science:
Electric charge is a physical property of matter which causes it to experience a force when near other electrically charged matter. Electric charge comes in two types, called positive and negative.
That IS what it is. If you want to talk about what it is or isn't go somewhere else.
"Electric charge is a physical property of matter which causes it to experience a force when near other "
This is a description of a fundamentally 'given' property. It is not an explanation of what it is. There is no explanation. It is simply there and cannot be defined in terms of previously existing properties. We have good reason to believe in its existence because of definite, repetitive, special patterns in changes of velocity for some particles. You said it was 'the force'. It is not a force.
James
There is nothing in nature that is not described by its properties. "Charge", "dog", "evaporation", all are described by their properties. There's no difference.
It can be defined in terms of gauge symmetry per Noethers theorem.
This does not disagree with or counter what I have said.
James
I'll give you my 2 cents.
In fact, I still have a vague souvenir of having had questions like the OP, and then this got slowly brainwashed out of me, like by drinking Dyonisos' wine, but it still comes to me in my dreams :smile:
It's about the transition of a pre-scientific apprehension of things, with or without some mystical flavor to it, and the (erroneous) conception of science (as a kind of Revelation) that goes with it, and the bare bones actual science that you learn afterwards (if you decide to do so).
It might be very disappointing, but in fact, each time in science, especially in physics, when you ask what something "really is", you'll get two kind of answers:
- this is how we measure it / this is how we observe it / this is what it does
- this is the mathematical concept by which we define it in this theory
depending on whether you're experimentally or theoretically inclined.
You'll never hear, to your great frustration, that Charge is the yellow stuff that came out of the Right Ear of the God Coulombys when he made love to the Goddess Sparkina at the beginning of the world and permeated the universe or something.
What you'll find out is that people introduced the concept of "electrical charge" to explain a phenomenon which was electrostatic repulsion and attraction. They saw that you could associate a *number* to a piece of matter and that that number could be used, together with distance, to quantify the electrostatic repulsion. What that number stood for was not said. It was just the number that could be associated to matter to explain a phenomenon: electrostatic repulsion.
An arbitrary but clearly stated "calibration" was introduced to define the scale, or the unit, of that number.
Later it was found out that there were other phenomena, and that that *same* number turned up. From that point on, "charge", or the number we originally associated with a piece of matter to explain one phenomenon, namely, electrostatic repulsion, became a concept by itself, that was a "property" of matter, and that entered into several descriptions of several phenomena.
Several theories describe, on several levels of "microscopicity" and on several levels of sophistication, matter, and several of them use a mathematical quantity, namely a number, that they define as "electrical charge". It is used in circuit theory, it is used in electrostatics (Coulomb law), it is used in classical electromagnetics (Maxwell theory), it is used in quantum field theory... and although details can sometimes differ, it is grossly always about the same "stuff" we're talking.
So charge gets a kind of individual life of its own: it is clearly "something" that is physically meaningfull, as it enters the quantitative description of several different phenomena, and it enters several theories of physics in a kind of "unity".
But at no point, we say anything about what IS charge, except for all of this together: it is a number that is associated to matter and appears in the explanation of several phenomena, and it is a theoretical concept that is "robust" against the change in theoretical description level, so it must represent something with a strong physical meaning.
And that's it.
For some physical concepts, we can go further, because our biological senses have given us a primitive apprehension of it, a concept we already possessed since our early childhood. "Space" or "distance" is such a concept. "speed" is another one. But for charge, we don't have such a "pre-intellectual" primitive understanding, so we have to "build" one with the myriad of properties and theoretical constructs which differ in detail, but all point to a common physical "reality" of the concept at hand.
And that's the best we can do, contrary to what we (I ?) thought science would be teaching me when I didn't know any of it.
To "unlearn" or to "brainwash" yourself so that you can accept that physical concepts are nothing else but a cloud of properties and some persistent concepts in "nested" theories, or at least, that you won't know more than that about it, is an important conceptual step in becoming a physicist I'd say.
"I'll give you my 2 cents."
I read this messages more than once. I see nothing wrong with it. It was good to read.
James
thank you, i understand it better now :)
Excellent vanesch! I wish I had your skills when it comes to explaining things.
Iron and oxygen really are described by their properties. But clearly there's a lot of internal structure and additional physics that leads to these properties.
The question is better asked as "what if anything is known about how a charge does what it does?"
Can we define charges as "a Property of matter"?
Neutral particles are simply thhe result of equal amount of positive and negative charges in matter, not void of charges.
Charges can not exist withoout a carrier (matter) is another indication of charge as a property of matter.
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 20 ·
