Projectile Motion with Basketball
The discussion focuses on calculating the projectile motion of a basketball released from a height of 1.3 meters while walking at a speed of 1.45 m/s. At 0.25 seconds, the ball's position is calculated to be x = 0.36 m and y = 0.99 m. At 0.5 seconds, the vertical position is y = -1.23 m, leading to a total velocity of 4.8 m/s and a direction of 73.5 degrees below the horizontal. The calculations utilize kinematic equations and trigonometric functions to determine the ball's trajectory.
  • Kinematic equations for projectile motion
  • Basic trigonometry (sine, cosine, tangent)
  • Understanding of gravitational acceleration (9.81 m/s²)
  • Coordinate system for motion analysis
  • Study the derivation and application of kinematic equations in projectile motion
  • Learn about the effects of air resistance on projectile trajectories
  • Explore advanced projectile motion simulations using tools like PhET Interactive Simulations
  • Investigate real-world applications of projectile motion in sports physics
Students studying physics, educators teaching projectile motion concepts, and sports analysts interested in the dynamics of basketball trajectories.
wolves5
A person walking with a speed of 1.45 m/sec releases a ball from a height of h = 1.3 m above the ground. Use the point on the ground, directly below where the ball is initially released at the origin of your coordinate system.
Picture: https://wug-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?cc/DuPage/Phys1201/fall-evening/homework/Ch-03-04/wt-bouncing-ball/bouncing-ball.jpg
(a) What is the ball's position at 0.25 seconds after it is released in the x and y direction?
x =
y =
(b) What is the ball's position at 0.5 seconds after it is released in the x and y direction?
x =
y =
(c) What is the ball's total velocity, speed and direction of motion at 0.5 seconds after it is released?
vx =
vy =
v =
Θ =
For a, I tried using vf= vi + at. I used gravity (9.81) for the acceleration. However, its not right. For part b, I understand that you would use the same equation as part A, but you would just switch the 0.25 seconds to 0.5 seconds. For part c, I understand you use sin and cosine in order to solve for vx and vy.
a) Finding the horizontal distance after 0.25 s is fairly straightforward:
Given: vx = 1.45 m/s
dx = vxt
= (1.45 m/s)(0.25 s) = 0.36 m
Finding the vertical height at 0.25 s:
Given: v1y = 0
dy = 0 + 0.5a(t)^2
= 0.5(-9.8)(0.25)^2
= -0.31 m
1.3 m - 0.31 m = 0.99 m
b) ... same process
c) dy = 0 + 0.5at^2 = 0.5(-9.8)(0.5)^2
= -1.23 m
v2y2 - v1y2 = 2aydy
v2y2 = 2(-9.8)(-1.23) + (0)
v2y = 4.9 m/s
v2x = 1.45 m/s (horizontal speed is constant through)
Then do a Pythagorean triangle:
v^2 = (4.9)^2 + (1.45)^2
v = 4.8 m/s
tanx = 4.9/1.45
x = 73.5 degrees below the horizontal
  • · Replies 18 ·
  • · Replies 35 ·
