Taylor Series for Any (x) = Function (x) for Any (x) ?
The discussion centers on the relationship between Taylor Series and the original functions they represent. It is established that for polynomial functions, the Taylor expansion will equal the function if enough terms are included. However, for non-polynomial functions like sin(x), the Taylor series converges to the function but does not equal it unless all terms are included. Notably, the Taylor series for functions such as log(x) and f(x) = e^{-1/x} demonstrate cases where the series fails to approximate the function well, highlighting that not all functions are analytic.
  • Understanding of Taylor Series and their derivation
  • Knowledge of polynomial functions and their properties
  • Familiarity with trigonometric functions, specifically sin(x)
  • Basic concepts of analytic functions and convergence
  • Study the properties of analytic functions and their Taylor Series
  • Explore the convergence of Taylor Series for non-polynomial functions
  • Investigate the Taylor expansion of log(x) and its limitations
  • Examine the behavior of the Taylor series for f(x) = e^{-1/x} near x = 0
Mathematicians, students studying calculus, and anyone interested in the properties of Taylor Series and their applications in approximating functions.
Point Conception
When a Taylor Series is generated from a functions n derivatives at a single point,
then is that series for any value of x equal to the original function for any value x ?
For example graph the original function (x) from x= 0 to x = 10.
Now plug into the Taylor Expansion for x , values from 0 to 10 and graph.
Are the two plots approximate or equal ?
Numerical example not to be worked but just for question :
Suppose f(x) = 4x^3 + 8x^2 - 3x +2
Hi morrobay! :smile:
In your example, you just have a polynomial, which means that the Taylor expansion will equal the function if the expansion is taken far enough (i.e. if you take 4 terms in the expansion).
In general, a polynomial will always equal the Taylor expansion if you take the expansion far enough.
A more interesting case are things like sin(x). The Taylor expansion of sine will never really equal the sine but it will converge to it. That is, the more terms in the expansion you take, the better the expansion will approximate the sine.
For example, if you take 6 terms, then you get quite a good approximation:
[tex]sin(x)\sim x-\frac{x^3}{3!}+\frac{x^6}{6!}[/tex]
When you take the entire Taylor series (that is: when you take all the terms), then you get equality:
[tex]\sin(x)=\sum_{k=0}^{+\infty}{\frac{(-1)^nx^{2n+1}}{(2n+1)!}}[/tex]
However, there are certain functions in which the Taylor expansions do not approximate the function well. Take the Taylor expansion of log(x) at 1. For points larger than 2, the Taylor expansions form very, very bad approximations of the function.
Even more interesting is the Taylor series for [itex]f(x)= e^{-1/x}[/itex] if x is not 0, 0 if x= 0. That is infinitely differentiableat x= 0 and repeated derivatives are rational functions time [itex]e^{-1/x}[/itex] if x is not 0, 0 if x is 0. That is, the Taylor series for this function exists and is identically 0 for all 0. Clearly, f(x) is not 0 except at x= 0 so this is a function whose Taylor series exist for all x but is not equal to the function value except at x= 0.
So, no, for general functions, the Taylor's series is not necessarily equal to the function value. The "analytic functions" are specifically defined to be those for which it is true: a function is analytic, at x= a, if and only if its Taylor's series at x= a is equal to the function value for all x in some neighborhood of a.
17K
  • · Replies 17 ·
  • · Replies 19 ·
