Block striking a horizontal spring
The discussion revolves around a physics problem involving a block colliding with a horizontal spring, where the block's mass, spring constant, and coefficient of friction are provided. Participants explore the work done by the spring and friction, as well as the initial speed of the block upon impact with the spring.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationship between kinetic and potential energy in the context of the spring's work and friction's impact on the block's motion. There are attempts to apply energy conservation concepts, and some participants express confusion about the correct application of formulas and signs in their calculations.
Some participants have provided guidance on using the work-energy principle and the definition of work, while others have shared their attempts and corrections regarding the signs in their calculations. There is an ongoing exploration of the relationships between the different parts of the problem, with no explicit consensus reached on the final answers.
Participants note the importance of considering friction in a non-conservative system and question the assumptions made in their calculations. There is mention of using specific applications for homework, which may influence the formatting of answers.
TraceBusta
A moving 8.07 kg block collides with a horizonal spring whose spring constant is 372 N/m. The block compresses the spring a maximum distance of 6.87 cm from its rest position. The coefficient of kinetic friction between the block and the horizontal surface is 0.752.
(a) How much work is done by the spring in bringing the block to rest?
(b) How much mechanical work is done by the force of friction while the block is being brought to rest by the spring?
c) What was the speed of the block when it hit the spring?
for this problem I don't know whether I should start with (a) or not, because the information from the other parts might be useful. I tried to solve (a) but I get the wrong answer.
This is what I did. 1/2 kx^2=.5(372 N/m)(.0687)^2=0.8779 J. <--That is the wrong answer.
bump...anyone?
I've tried to solve for c) by doing 1/2 kx^2=1/2mv^2 and solve for v=.4664 m/s but that is wrong.
While the block is sliding in contact of the spring, it's true the spring will bring it to rest, but there's also friction opposing the block's movement.
Thinking about it... solve it using
[tex]\Delta E = W_{f}[/tex]
Thinking about again... your answer for a looks right to me :confused:, what's the books answer?
with deltaE do you mean change from Kinetic energy to potential energy of the spring?
By [tex]\Delta E[/tex] i mean change of mechanical energy, this is not a conservative system you cannot apply conservation of mechanical energy.
[tex]E - E_{o} = W_{f}[/tex]
I will try E when the block stops, and there's only potential spring energy, and of course then the block hits the spring, there's only kinetic energy. Are you using an app like Webassign? try putting a - in your answer.
for part a i put a - in the answer and it was right..thnks.
i'm still confused as to continue on with parts b) and c)
Heh, i know the feeling, i hate those apps too :smile:
With the equation i gave you, i practically solved the problem for you.
Find the friction force magnitude and use it in the definition of work, you know the radius vector magnitude.
i think i could solve b) if i knew the answer to c) because then I could use 1/2kx^2-1/2mv^2=(b)?
Ok. I did Wf=(mu)mg*.0687m and got 4.0899J which is wrong.
/edit I put a - sign and it was right. edit/
Let's go back to the definition of Work
[tex]dW = \vec{F} \cdot d \vec{r}[/tex]
so
the result for W will be [tex]|\vec{F}||\vec{r}|cos\theta[/tex]
where [tex]\theta[/tex] is the angle between them
What si the force you want to find its work? Friction force, use the definition for magnitude of friction force
[tex]F_{f} = \mu N[/tex]
You already know the magnitude of the radius vector, and you can know the angle between them.
Let me explain you the minus sign... the angle between the radius vector and the force vector is 180 degrees and cosine of 180 degrees is -1, now you know why.
Awesome, thanks for your help. I figured out c) by doing -(a)-(b)=1/2 mv^2 and solved for v=1.11 m/s
It's was a pleasure to be of assistance, :smile:
  • · Replies 27 ·
11K
